TDA2平台部署linux系统无法进入系统
Other Parts Discussed in Thread: PCF8575, PGA460
HI,  你好
我官方参考文档VisionSDK_Linux_UserGuide.pdf, 进行编译linux系统并从SD卡启动,却无法进入系统:
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.19.73 (lewis@ubuntu) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #1 SMP PREEMPT Mon Nov 23 23:20:13 PST 2020
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: TI DRA742
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000040300000, size 3 MiB
[ 0.000000] OF: reserved mem: initialized node cmem@40300000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: regions without no-map are not yet supported
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 80 MiB
[ 0.000000] OF: reserved mem: initialized node ipu2-memory@95800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009e000000, size 32 MiB
[ 0.000000] OF: reserved mem: initialized node ipu1-memory@9d000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000000a1000000, size 32 MiB
[ 0.000000] OF: reserved mem: initialized node dsp1-memory@99000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000000a3000000, size 32 MiB
[ 0.000000] OF: reserved mem: initialized node dsp2-memory@9f000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 32 MiB
[ 0.000000] OF: reserved mem: initialized node cmem@A9000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000000b0000000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node gpu-memory@c0000000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 64 MiB at 0x00000000bbc00000
[ 0.000000] OMAP4: Map 0x00000000bfd00000 to (ptrval) for dram barrier
[ 0.000000] DRA752 ES2.0
[ 0.000000] random: get_random_bytes called from start_kernel+0xb4/0x470 with crng_init=0
[ 0.000000] percpu: Embedded 16 pages/cpu s36492 r8192 d20852 u65536
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 251456
[ 0.000000] Kernel command line: console=ttyO0,115200n8 vram=16M root=PARTUUID=d6ac753a-02 rw rootwait ip=none mem=1024M cma=64M
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 280708K/1012736K available (10240K kernel code, 341K rwdata, 2804K rodata, 2048K init, 269K bss, 420732K reserved, 311296K cma-reserved, 128000K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (12256 kB)
[ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (2048 kB)
[ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 342 kB)
[ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 270 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] OMAP clockevent source: timer1 at 32786 Hz
[ 0.000000] arch_timer: cp15 timer(s) running at 6.14MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[ 0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[ 0.000018] Switching to timer-based delay loop, resolution 162ns
[ 0.000295] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[ 0.000304] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000756] Console: colour dummy device 80x30
[ 0.000776] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.000784] This ensures that you still see kernel messages. Please
[ 0.000791] update your kernel commandline.
[ 0.000823] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[ 0.000840] pid_max: default: 32768 minimum: 301
[ 0.000966] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000981] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001528] CPU: Testing write buffer coherency: ok
[ 0.001567] CPU0: Spectre v2: using ICIALLU workaround
[ 0.001781] /cpus/cpu@0 missing clock-frequency property
[ 0.001801] /cpus/cpu@1 missing clock-frequency property
[ 0.001814] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.059916] Setting up static identity map for 0x80200000 - 0x80200060
[ 0.079928] rcu: Hierarchical SRCU implementation.
[ 0.100123] EFI services will not be available.
[ 0.119994] smp: Bringing up secondary CPUs ...
[ 0.200345] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.200351] CPU1: Spectre v2: using ICIALLU workaround
[ 0.200473] smp: Brought up 1 node, 2 CPUs
[ 0.200485] SMP: Total of 2 processors activated (24.59 BogoMIPS).
[ 0.200493] CPU: All CPU(s) started in HYP mode.
[ 0.200501] CPU: Virtualization extensions available.
[ 0.200994] devtmpfs: initialized
[ 0.219078] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.219341] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.219359] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.224205] pinctrl core: initialized pinctrl subsystem
[ 0.224732] DMI not present or invalid.
[ 0.225011] NET: Registered protocol family 16
[ 0.226172] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.227096] omap_hwmod: l3_main_2 using broken dt data from ocp
[ 0.420687] cpuidle: using governor ladder
[ 0.420723] cpuidle: using governor menu
[ 0.430798] OMAP GPIO hardware version 0.1
[ 0.456510] No ATAGs?
[ 0.456586] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.456600] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.457133] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.457145] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 0.457790] OMAP DMA hardware revision 0.0
[ 0.469401] edma 43300000.edma: memcpy is disabled
[ 0.472848] edma 43300000.edma: TI EDMA DMA engine driver
[ 0.479985] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[ 0.481588] evm_3v3: supplied by evm_12v0
[ 0.481879] evm_5v0: supplied by evm_12v0
[ 0.482182] evm_3v6: supplied by evm_5v0
[ 0.485392] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[ 0.485563] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[ 0.485813] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 0.486047] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.486424] omap-iommu 41501000.mmu: 41501000.mmu registered
[ 0.486603] omap-iommu 41502000.mmu: 41502000.mmu registered
[ 0.486880] iommu: Adding device 58820000.ipu to group 1
[ 0.486961] iommu: Adding device 55020000.ipu to group 2
[ 0.487088] iommu: Adding device 40800000.dsp to group 0
[ 0.487328] iommu: Adding device 41000000.dsp to group 3
[ 0.488448] SCSI subsystem initialized
[ 0.489674] palmas 0-0058: IRQ missing: skipping irq request
[ 0.510891] palmas 0-0058: Muxing GPIO 2e, PWM 0, LED 0
[ 0.512555] SMPS123: supplied by regulator-dummy
[ 0.514422] SMPS45: supplied by regulator-dummy
[ 0.516265] SMPS6: supplied by regulator-dummy
[ 0.517968] SMPS7: supplied by regulator-dummy
[ 0.519819] SMPS8: supplied by regulator-dummy
[ 0.521522] SMPS9: supplied by regulator-dummy
[ 0.522510] LDO1: supplied by regulator-dummy
[ 0.531358] LDO2: supplied by regulator-dummy
[ 0.541225] LDO3: supplied by regulator-dummy
[ 0.551235] LDO4: supplied by regulator-dummy
[ 0.551422] random: fast init done
[ 0.551972] LDO5: supplied by regulator-dummy
[ 0.552698] LDO6: supplied by regulator-dummy
[ 0.553410] LDO7: supplied by regulator-dummy
[ 0.554135] LDO8: supplied by regulator-dummy
[ 0.554856] LDO9: supplied by regulator-dummy
[ 0.561271] LDOLN: supplied by regulator-dummy
[ 0.571287] LDOUSB: supplied by regulator-dummy
[ 0.583501] pcf857x: probe of 0-0020 failed with error -121
[ 0.583753] pcf857x: probe of 0-0021 failed with error -121
[ 0.583918] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[ 0.584382] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
[ 0.584604] media: Linux media interface: v0.10
[ 0.584643] videodev: Linux video capture interface: v2.00
[ 0.584714] pps_core: LinuxPPS API ver. 1 registered
[ 0.584723] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.584744] PTP clock support registered
[ 0.584775] EDAC MC: Ver: 3.0.0
[ 0.585567] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[ 0.585815] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[ 0.586324] Advanced Linux Sound Architecture Driver Initialized.
[ 0.587140] clocksource: Switched to clocksource arch_sys_counter
[ 0.595211] NET: Registered protocol family 2
[ 0.595785] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.595813] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.595877] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.596003] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.596072] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.596106] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.596245] NET: Registered protocol family 1
[ 0.616691] RPC: Registered named UNIX socket transport module.
[ 0.616702] RPC: Registered udp transport module.
[ 0.616710] RPC: Registered tcp transport module.
[ 0.616718] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.617809] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 0.618033] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.619015] Initialise system trusted keyrings
[ 0.619146] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 0.624023] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.634514] NFS: Registering the id_resolver key type
[ 0.634537] Key type id_resolver registered
[ 0.634546] Key type id_legacy registered
[ 0.634584] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.636156] Key type asymmetric registered
[ 0.636169] Asymmetric key parser 'x509' registered
[ 0.636223] bounce: pool size: 64 pages
[ 0.636257] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.636268] io scheduler noop registered
[ 0.636276] io scheduler deadline registered
[ 0.636371] io scheduler cfq registered (default)
[ 0.636382] io scheduler mq-deadline registered
[ 0.636391] io scheduler kyber registered
[ 0.642226] pinctrl-single 4a003400.pinmux: 282 pins, size 1128
[ 0.646179] dra7-pcie 51000000.pcie: Linked as a consumer to phy-4a094000.pciephy.1
[ 0.646427] dra7-pcie 51000000.pcie: WA for Errata i870 not applied
[ 0.646517] dra7-pcie 51000000.pcie: host bridge /ocp/axi@0/pcie@51000000 ranges:
[ 0.646558] dra7-pcie 51000000.pcie: IO 0x20003000..0x20012fff -> 0x00000000
[ 0.646586] dra7-pcie 51000000.pcie: MEM 0x20013000..0x2fffffff -> 0x20013000
[ 1.646867] dra7-pcie 51000000.pcie: Phy link never came up
[ 1.647001] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
[ 1.647015] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.647027] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 1.647038] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[ 1.653147] PCI: bus0: Fast back to back transfers disabled
[ 1.658743] PCI: bus1: Fast back to back transfers enabled
[ 1.658786] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff 64bit]
[ 1.658806] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 1.659127] pcieport 0000:00:00.0: Signaling PME with IRQ 176
[ 1.659259] pcieport 0000:00:00.0: AER enabled with IRQ 176
[ 1.663379] evm_1v8: supplied by smps9
[ 1.663633] evm_3v3_sw: supplied by sysen1
[ 1.663872] aic_dvdd: supplied by evm_3v3_sw
[ 1.663957] vtt_fixed: supplied by sysen2
[ 1.708692] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 1.712257] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 45, base_baud = 3000000) is a 8250
[ 2.913436] console [ttyS0] enabled
[ 2.917863] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 46, base_baud = 3000000) is a 8250
[ 2.927508] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 47, base_baud = 3000000) is a 8250
[ 2.938638] omap_rng 48090000.rng: Random Number Generator ver. 20
[ 2.938960] random: crng init done
[ 2.958848] brd: module loaded
[ 2.968149] loop: module loaded
[ 2.971971] vmemexp device MAJOR num = 244
[ 2.976099] vmemexp class registered
[ 2.979821] /dev/vmemexp device registered
[ 2.983937] ioctl DBUFIOC_EXPORT_VIRTMEM = -1072899120
[ 3.014881] m25p80 spi0.0: found n25q00, expected s25fl256s1
[ 3.020857] m25p80 spi0.0: n25q00 (131072 Kbytes)
[ 3.025673] 10 fixed-partitions partitions found on MTD device spi0.0
[ 3.032163] Creating 10 MTD partitions on "spi0.0":
[ 3.037067] 0x000000000000-0x000000010000 : "QSPI.SPL"
[ 3.042960] 0x000000010000-0x000000020000 : "QSPI.SPL.backup1"
[ 3.049514] 0x000000020000-0x000000030000 : "QSPI.SPL.backup2"
[ 3.056036] 0x000000030000-0x000000040000 : "QSPI.SPL.backup3"
[ 3.062581] 0x000000040000-0x000000140000 : "QSPI.u-boot"
[ 3.068689] 0x000000140000-0x0000001c0000 : "QSPI.u-boot-spl-os"
[ 3.075377] 0x0000001c0000-0x0000001d0000 : "QSPI.u-boot-env"
[ 3.081837] 0x0000001d0000-0x0000001e0000 : "QSPI.u-boot-env.backup1"
[ 3.088988] 0x0000001e0000-0x0000009e0000 : "QSPI.kernel"
[ 3.095063] 0x0000009e0000-0x000002000000 : "QSPI.file-system"
[ 3.102169] libphy: Fixed MDIO Bus: probed
[ 3.167170] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 3.174866] davinci_mdio 48485000.mdio: no live phy, scanning all
[ 3.214130] libphy: 48485000.mdio: probed
[ 3.218888] cpsw 48484000.ethernet: Detected MACID = b4:52:a9:5d:f6:dc
[ 3.225491] cpsw 48484000.ethernet: initialized cpsw ale version 1.4
[ 3.231897] cpsw 48484000.ethernet: ALE Table size 1024
[ 3.237200] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies)
[ 3.245193] cpsw 48484000.ethernet: cpsw: Detected MACID = b4:52:a9:5d:f6:dd
[ 3.253836] i2c /dev entries driver
[ 3.262477] cpu cpu0: Linked as a consumer to regulator.10
[ 3.268091] cpu cpu0: Linked as a consumer to regulator.32
[ 3.274964] sdhci: Secure Digital Host Controller Interface driver
[ 3.281221] sdhci: Copyright(c) Pierre Ossman
[ 3.286527] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.293466] omap_gpio 4805d000.gpio: Could not set line 27 debounce to 200000 microseconds (-22)
[ 3.302347] sdhci-omap 4809c000.mmc: Got CD GPIO
[ 3.307188] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.31
[ 3.314254] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.16
[ 3.321333] sdhci-omap 4809c000.mmc: Dropping the link to regulator.16
[ 3.328225] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.16
[ 3.335114] sdhci-omap 4809c000.mmc: Dropping the link to regulator.16
[ 3.341748] sdhci-omap 4809c000.mmc: Dropping the link to regulator.31
[ 3.349121] sdhci-omap 480b4000.mmc: Linked as a consumer to regulator.2
[ 3.355905] sdhci-omap 480b4000.mmc: Dropping the link to regulator.2
[ 3.362463] sdhci-omap 480b4000.mmc: Linked as a consumer to regulator.2
[ 3.395058] mmc0: SDHCI controller on 480b4000.mmc [480b4000.mmc] using ADMA
[ 3.402965] ti-iodelay 4844a000.padconf: Set reg 0x840 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[ 3.411935] ti-iodelay 4844a000.padconf: Set reg 0x848 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[ 3.420936] ti-iodelay 4844a000.padconf: Set reg 0x84c Delay(a: 307 g: 0), Elements(C=0 F=8)0x29008
[ 3.430120] ti-iodelay 4844a000.padconf: Set reg 0x850 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[ 3.439081] ti-iodelay 4844a000.padconf: Set reg 0x854 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[ 3.448133] ti-iodelay 4844a000.padconf: Set reg 0x870 Delay(a: 785 g: 0), Elements(C=1 F=8)0x29028
[ 3.457332] ti-iodelay 4844a000.padconf: Set reg 0x874 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[ 3.466340] ti-iodelay 4844a000.padconf: Set reg 0x878 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[ 3.475391] ti-iodelay 4844a000.padconf: Set reg 0x87c Delay(a: 613 g: 0), Elements(C=1 F=3)0x29023
[ 3.484594] ti-iodelay 4844a000.padconf: Set reg 0x880 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[ 3.493621] ti-iodelay 4844a000.padconf: Set reg 0x884 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[ 3.502669] ti-iodelay 4844a000.padconf: Set reg 0x888 Delay(a: 683 g: 0), Elements(C=1 F=5)0x29025
[ 3.511871] ti-iodelay 4844a000.padconf: Set reg 0x88c Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[ 3.520914] ti-iodelay 4844a000.padconf: Set reg 0x890 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[ 3.529972] ti-iodelay 4844a000.padconf: Set reg 0x894 Delay(a: 835 g: 0), Elements(C=1 F=9)0x29029
[ 3.539114] ti-iodelay 4844a000.padconf: Set reg 0x898 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[ 3.548053] ti-iodelay 4844a000.padconf: Set reg 0x89c Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[ 3.557302] sdhci-omap 480d1000.mmc: Linked as a consumer to regulator.8
[ 3.564087] sdhci-omap 480d1000.mmc: Dropping the link to regulator.8
[ 3.570667] sdhci-omap 480d1000.mmc: Linked as a consumer to regulator.7
[ 3.577473] sdhci-omap 480d1000.mmc: Linked as a consumer to regulator.8
[ 3.667175] sdhci-omap 480d1000.mmc: no pinctrl state for sdr104 mode
[ 3.673648] sdhci-omap 480d1000.mmc: no pinctrl state for ddr50 mode
[ 3.680078] sdhci-omap 480d1000.mmc: no pinctrl state for sdr50 mode
[ 3.686466] sdhci-omap 480d1000.mmc: no pinctrl state for hs200_1_8v mode
[ 3.718957] mmc1: SDHCI controller on 480d1000.mmc [480d1000.mmc] using PIO
[ 3.726862] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.737363] tlv320aic3x-codec 0-0019: Linked as a consumer to regulator.3
[ 3.744262] tlv320aic3x-codec 0-0019: Linked as a consumer to regulator.4
[ 3.752943] davinci-mcasp 4847c000.mcasp: invalid tdm slots: 0
[ 3.760368] NET: Registered protocol family 10
[ 3.765772] Segment Routing with IPv6
[ 3.769794] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 3.776211] NET: Registered protocol family 17
[ 3.780929] Key type dns_resolver registered
[ 3.785388] Registering SWP/SWPB emulation handler
[ 3.790276] omap_voltage_late_init: Voltage driver support not added
[ 3.796683] Power Management for TI OMAP4+ devices.
[ 3.802315] Loading compiled-in X.509 certificates
[ 3.832445] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.839161] [drm] No driver support for vblank timestamp query.
[ 3.845481] [drm] Initialized vdrm 1.0.0 20191105 for 44000000.ocp:vdrm@0 on minor 0
[ 3.930339] Console: switching to colour frame buffer device 240x67
[ 3.953288] vdrm 44000000.ocp:vdrm@0: fb0: DRM emulated frame buffer device
[ 3.960804] dmm 4e000000.dmm: workaround for errata i878 in use
[ 3.968404] dmm 4e000000.dmm: initialized all PAT entries
[ 3.974687] [drm] Initialized omapdrm 1.0.0 20110917 for omapdrm.0 on minor 1
[ 3.983111] omap_gpio 4805d000.gpio: Could not set line 27 debounce to 200000 microseconds (-22)
[ 3.991979] sdhci-omap 4809c000.mmc: Got CD GPIO
[ 3.996830] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.31
[ 4.003968] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.16
[ 4.010881] sdhci-omap 4809c000.mmc: Dropping the link to regulator.16
[ 4.017747] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.16
[ 4.024646] sdhci-omap 4809c000.mmc: Dropping the link to regulator.16
[ 4.031283] sdhci-omap 4809c000.mmc: Dropping the link to regulator.31
[ 4.039952] asoc-simple-card sound0: tlv320aic3x-hifi <-> 48468000.mcasp mapping ok
[ 4.047719] asoc-simple-card sound0: ASoC: no DMI vendor name!
[ 4.056278] omap_gpio 4805d000.gpio: Could not set line 27 debounce to 200000 microseconds (-22)
[ 4.065140] sdhci-omap 4809c000.mmc: Got CD GPIO
[ 4.069999] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.31
[ 4.077083] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.16
[ 4.084003] sdhci-omap 4809c000.mmc: Dropping the link to regulator.16
[ 4.090848] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.16
[ 4.097765] sdhci-omap 4809c000.mmc: Dropping the link to regulator.16
[ 4.104384] sdhci-omap 4809c000.mmc: Dropping the link to regulator.31
[ 4.112383] omap_gpio 4805d000.gpio: Could not set line 27 debounce to 200000 microseconds (-22)
[ 4.121245] sdhci-omap 4809c000.mmc: Got CD GPIO
[ 4.126034] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.31
[ 4.133142] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.16
[ 4.140063] sdhci-omap 4809c000.mmc: Dropping the link to regulator.16
[ 4.146880] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.16
[ 4.153807] sdhci-omap 4809c000.mmc: Dropping the link to regulator.16
[ 4.160437] sdhci-omap 4809c000.mmc: Dropping the link to regulator.31
[ 4.167985] hctosys: unable to open rtc device (rtc0)
[ 4.173824] aic_dvdd: disabling
[ 4.177174] ldousb: disabling
[ 4.180427] pbias_mmc_omap5: disabling
[ 4.184232] ALSA device list:
[ 4.187263] #0: DRA7xx-EVM
[ 4.190962] Waiting for root device PARTUUID=d6ac753a-02...
<卡死在这里,没有反应>
制作系统命令如下:
lewis@ubuntu:~/ti/PROCESSOR_SDK_VISION_03_08_00_00/ti_components/os_tools/linux/targetfs$ ls $INSTALL_DIR/vision_sdk/binaries/apps/tda2xx_evm_linux_all/hlos/linux/boot
MLO tisdk-rootfs-image-dra7xx-evm.tar.xz u-boot.img uenv.txt
lewis@ubuntu:~/ti/PROCESSOR_SDK_VISION_03_08_00_00/ti_components/os_tools/linux/targetfs$ cd $INSTALL_DIR/vision_sdk/build
lewis@ubuntu:~/ti/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/build$
lewis@ubuntu:~/ti/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/build$ sudo ./hlos/scripts/linux/mksdboot.sh --device /dev/sdb --appname apps --makeconfig tda2xx_evm_linux_all
-- Main device is: /dev/sda1
* THIS WILL DELETE ALL THE DATA ON /dev/sdb *
* WARNING! Make sure your computer does not go *
* in to idle mode while this script is *
* running. The script will complete, *
* but your SD card may be corrupted. *
* Press <ENTER> to confirm.... *
unmounting device '/dev/sdb1'
unmounting device '/dev/sdb2'
1024+0 records in
1024+0 records out
1048576 bytes (1.0 MB) copied, 0.601153 s, 1.7 MB/s
Device contains neither a valid DOS partition table, nor Sun, SGI or OSF disklabel
Building a new DOS disklabel with disk identifier 0xd6ac753a.
Changes will remain in memory only, until you decide to write them.
After that, of course, the previous content won't be recoverable.
Warning: invalid flag 0x0000 of partition table 4 will be corrected by w(rite)
Command (m for help): Partition type:
p primary (0 primary, 0 extended, 4 free)
e extended
Select (default p): Partition number (1-4, default 1): First sector (2048-31116287, default 2048): Using default value 2048
Last sector, +sectors or +size{K,M,G} (2048-31116287, default 31116287):
p primary (1 primary, 0 extended, 3 free)
e extended
Select (default p): Partition number (1-4, default 2): First sector (526336-31116287, default 526336): Using default value 526336
Last sector, +sectors or +size{K,M,G} (526336-31116287, default 31116287): Using default value 31116287
Command (m for help): Partition number (1-4): Hex code (type L to list codes): Changed system type of partition 1 to c (W95 FAT32 (LBA))
Command (m for help): The partition table has been altered!
Calling ioctl() to re-read partition table.
WARNING: If you have created or modified any DOS 6.x
partitions, please see the fdisk manual page for additional
information.
Syncing disks.
Press enter to continue.
./hlos/scripts/linux/mksdboot.sh: 156: read: arg count
Formating /dev/sdb1 ...
mkfs.fat 3.0.26 (2014-03-07)
mkfs.fat: warning - lowercase labels might not work properly with DOS or Windows
mke2fs 1.42.9 (4-Feb-2014)
Filesystem label=rootfs
OS type: Linux
Block size=4096 (log=2)
Fragment size=4096 (log=2)
Stride=0 blocks, Stripe width=0 blocks
956592 inodes, 3823744 blocks
191187 blocks (5.00%) reserved for the super user
First data block=0
Maximum filesystem blocks=3917479936
117 block groups
32768 blocks per group, 32768 fragments per group
8176 inodes per group
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208
Allocating group tables: done
Writing inode tables: done
Creating journal (32768 blocks): done
Writing superblocks and filesystem accounting information: done
Copying filesystem on /dev/sdb1,/dev/sdb2
Creating card from ../binaries/apps/tda2xx_evm_linux_all/hlos/linux/boot
Extracting filesystem on /dev/sdb2 ...
unmounting /dev/sdb1,/dev/sdb2
completed!
  • 感谢您对TI产品的关注!为更加有效地解决您的问题,我需要询问更了解这款芯片的TI资深工程师,再为您解答,一旦得到回复会立即回复给您。
  • 请问您使用的是TI的EVM还是您自己的板子呢?
    如果是TI EVM,您是否可以尝试使用SDK中的预构建图像或者尝试其他SD卡?
  • HI, Annie Liu
    很高兴收到你的回复。
    我使用的是TI的EVM, 板子型号为MMWCAS_DSP_EVM。
    在采购EVM时配送的SD卡中自带的系统,可以正常启动。
    目前我使用参考文档VisionSDK_Linux_UserGuide.pdf进行自己配置编译系统,然后制作SD卡,在将SD卡插入卡槽,无法启动。
    使用资源列表如下:
    lewis@ubuntu:~/ti/PROCESSOR_SDK_VISION_03_08_00_00/ti_components/os_tools/linux$ ls
    arm kernel linaro sgx targetfs u-boot xdctools_3_32_01_22_core
    lewis@ubuntu:~/ti/PROCESSOR_SDK_VISION_03_08_00_00/ti_components/os_tools/linux$ ls kernel/omap/
    arch Documentation ipc MAINTAINERS scripts virt
    block drivers Kbuild Makefile security
    certs firmware Kconfig mm sound
    COPYING fs kernel net ti_config_fragments
    CREDITS include lib README tools
    crypto init LICENSES samples usr
    lewis@ubuntu:~/ti/PROCESSOR_SDK_VISION_03_08_00_00/ti_components/os_tools/linux$ ls u-boot/u-boot/
    api Documentation lib spl u-boot-dtb.bin
    arch drivers Licenses System.map u-boot-dtb.img
    board dts MAINTAINERS test u-boot.img
    cmd env Makefile tools u-boot.lds
    common examples MLO u-boot u-boot.map
    config.mk fs net u-boot.bin u-boot-nodtb.bin
    configs include post u-boot.cfg u-boot.srec
    disk Kbuild README u-boot.cfg.configs u-boot.sym
    doc Kconfig scripts u-boot.dtb
    lewis@ubuntu:~/ti/PROCESSOR_SDK_VISION_03_08_00_00/ti_components/os_tools/linux$ ls sgx/omap5-sgx-ddk-linux/
    eurasia_km
    lewis@ubuntu:~/ti/PROCESSOR_SDK_VISION_03_08_00_00/ti_components/os_tools/linux$ ls kernel/cmem/ludev
    Android.mk config.status include Makefile products.mak
    build-aux configure libtool Makefile.am src
    config.log configure.ac lu.mak Makefile.in
    lewis@ubuntu:~/ti/PROCESSOR_SDK_VISION_03_08_00_00/ti_components/os_tools/linux$ ls targetfs/
    bin boot dev etc home include lib linuxrc media mnt opt proc run sbin sys tmp usr var
  • ——请问您是否可以尝试使用EVM随附的SD卡上构建的映像吗?
    或者
    ——尝试在其他SD卡上构建的图像吗?
  • HI, Annie Liu
    好!
    尝试使用过新的SD卡构建,或过几个SD卡(包括随付的SD卡), 都是一样的现象。
    就是在启动的时候,显示如上的日志信息。
    目前感觉到是不是我下载的资源版本不对? 但是在编译过程中,也没有报错呀。
    整个流程操作下来还是挺顺利的。目前我无法判断问题症结在哪里?
  • 请问是否方便提供EVM随附SD卡的工作日志?
  • HI
    日志如下:
    [08:31:33][20201204 08:31:33]
    [08:31:37]
    [08:31:37]U-Boot SPL 2016.05-00018-g6bc25a5 (Aug 05 2019 - 14:43:03)
    [08:31:37]DRA752-GP ES2.0
    [08:31:37]no pinctrl for hs200_1_8v
    [08:31:37]no pinctrl for ddr_1_8v
    [08:31:38]Card did not respond to voltage select!
    [08:31:38]*** Warning - MMC init failed, using default environment
    [08:31:38]
    [08:31:38]Trying to boot from MMC1
    [08:31:38]reading dra7-ipu2-fw.lzop
    [08:31:38]spl_load_file_fat: error reading file dra7-ipu2-fw.lzop, err - -1
    [08:31:38]spl: error reading image dra7-ipu2-fw.lzop, err - -1
    [08:31:38]Error loading remotecore IPU2!,Continuing with boot ...
    [08:31:38]reading dra7-dsp1-fw.lzop
    [08:31:38]spl_load_file_fat: error reading file dra7-dsp1-fw.lzop, err - -1
    [08:31:38]spl: error reading image dra7-dsp1-fw.lzop, err - -1
    [08:31:38]Error loading remotecore DSP1!,Continuing with boot ...
    [08:31:38]reading dra7-dsp2-fw.lzop
    [08:31:38]spl_load_file_fat: error reading file dra7-dsp2-fw.lzop, err - -1
    [08:31:38]spl: error reading image dra7-dsp2-fw.lzop, err - -1
    [08:31:38]Error loading remotecore DSP2!,Continuing with boot ...
    [08:31:38]reading dra7-ipu1-fw.lzop
    [08:31:38]spl_load_file_fat: error reading file dra7-ipu1-fw.lzop, err - -1
    [08:31:38]spl: error reading image dra7-ipu1-fw.lzop, err - -1
    [08:31:38]Error loading remotecore IPU1!,Continuing with boot ...
    [08:31:38]spl: falcon_args_file not set in environment, falling back to default
    [08:31:38]reading single-stage-boot.dtb
    [08:31:38]spl_load_image_fat_os: error reading image single-stage-boot.dtb, err - -1
    [08:31:38]reading u-boot.img
    [08:31:38]
    [08:31:38]
    [08:31:38]U-Boot 2016.05-00018-g6bc25a5 (Aug 05 2019 - 14:43:03 +0530)
    [08:31:38]
    [08:31:38]CPU : DRA752-GP ES2.0
    [08:31:38]Model: TI DRA742
    [08:31:38]Board: DRA74x Cascade EVM REV H.4
    [08:31:38]DRAM: 4 GiB
    [08:31:38]MMC: i2c_write: error waiting for data ACK (status=0x116)
    [08:31:38]pcf8575_i2c_write_le16 i2c write failed to addr 21
    [08:31:38]OMAP SD/MMC: 0, OMAP SD/MMC: 1
    [08:31:38]
    [08:31:38]ERROR: invalid mmc device
    [08:31:38]
    [08:31:38]at arch/arm/cpu/armv7/omap-common/utils.c:193/mmc_get_part_size()
    [08:31:38]Warning: fastboot.userdata_size: unable to calc
    [08:31:38]SCSI: SATA link 0 timeout.
    [08:31:38]AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
    [08:31:38]flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst
    [08:31:38]scanning bus for devices...
    [08:31:38]Found 0 device(s).
    [08:31:38]Net: Could not get PHY for ethernet@48484000: addr 2
    [08:31:38]
    [08:31:38]Warning: ethernet@48484000 using MAC address from ROM
    [08:31:39]eth0: ethernet@48484000
    [08:31:41]Hit any key to stop autoboot: 0
    [08:31:41]## Error: "board_findfdt" not defined
    [08:31:41]i2c_write: error waiting for data ACK (status=0x116)
    [08:31:41]pcf8575_i2c_write_le16 i2c write failed to addr 21
    [08:31:41]switch to partitions #0, OK
    [08:31:41]mmc0 is current device
    [08:31:41]SD/MMC found on device 0
    [08:31:41]reading boot.scr
    [08:31:41]** Unable to read file boot.scr **
    [08:31:41]reading uEnv.txt
    [08:31:41]185 bytes read in 3 ms (59.6 KiB/s)
    [08:31:41]Loaded env from uEnv.txt
    [08:31:41]Importing environment from mmc0 ...
    [08:31:41]3577032 bytes read in 171 ms (19.9 MiB/s)
    [08:31:41]107792 bytes read in 24 ms (4.3 MiB/s)
    [08:31:41]Booting from mmc0 ...
    [08:31:41]Kernel image @ 0x82000000 [ 0x000000 - 0x3694c8 ]
    [08:31:41]## Flattened Device Tree blob at 88000000
    [08:31:41] Booting using the fdt blob at 0x88000000
    [08:31:41] Loading Device Tree to 8ffe2000, end 8ffff50f ... OK
    [08:31:41]
    [08:31:41]Starting kernel ...
    [08:31:41]
    [08:31:44][ 0.000000] Booting Linux on physical CPU 0x0
    [08:31:44][ 0.000000] Initializing cgroup subsys cpuset
    [08:31:44][ 0.000000] Initializing cgroup subsys cpuacct
    [08:31:44][ 0.000000] Linux version 4.4.84-00041-g84382ab (x0284921@bangvideoapps02) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #1 SMP PREEMPT Mon Aug 5 14:52:40 IST 2019
    [08:31:44][ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
    [08:31:44][ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    [08:31:44][ 0.000000] Machine model: TI DRA742 Cascade Radar Board
    [08:31:44][ 0.000000] Reserved memory: created DMA memory pool at 0x0000000040300000, size 3 MiB
    [08:31:44][ 0.000000] Reserved memory: initialized node cmem@40300000, compatible id shared-dma-pool
    [08:31:44][ 0.000000] Reserved memory: regions without no-map are not yet supported
    [08:31:44][ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 80 MiB
    [08:31:44][ 0.000000] Reserved memory: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
    [08:31:44][ 0.000000] Reserved memory: created CMA memory pool at 0x000000009e000000, size 32 MiB
    [08:31:44][ 0.000000] Reserved memory: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
    [08:31:44][ 0.000000] Reserved memory: created CMA memory pool at 0x00000000a1000000, size 32 MiB
    [08:31:45][ 0.000000] Reserved memory: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
    [08:31:45][ 0.000000] Reserved memory: created CMA memory pool at 0x00000000a3000000, size 32 MiB
    [08:31:45][ 0.000000] Reserved memory: initialized node dsp2_cma@9f000000, compatible id shared-dma-pool
    [08:31:45][ 0.000000] Reserved memory: regions without no-map are not yet supported
    [08:31:45][ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 64 MiB
    [08:31:45][ 0.000000] Reserved memory: initialized node cmem@A9000000, compatible id shared-dma-pool
    [08:31:45][ 0.000000] cma: Reserved 64 MiB at 0x00000000bc000000
    [08:31:45][ 0.000000] Forcing write-allocate cache policy for SMP
    [08:31:45][ 0.000000] Memory policy: Data cache writealloc
    [08:31:45][ 0.000000] OMAP4: Map 0x000000027fd00000 to fe600000 for dram barrier
    [08:31:45][ 0.000000] DRA752 ES2.0
    [08:31:45][ 0.000000] PERCPU: Embedded 11 pages/cpu @f2f1e000 s14912 r8192 d21952 u45056
    [08:31:45][ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1025330
    [08:31:45][ 0.000000] Kernel command line: console=ttyO0,115200n8 vram=16M root=PARTUUID=3cc717e1-02 rw rootwait ip=none cma=64M vmalloc=128M
    [08:31:45][ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
    [08:31:45][ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    [08:31:45][ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    [08:31:45][ 0.000000] Memory: 2439424K/4109312K available (6671K kernel code, 320K rwdata, 2396K rodata, 336K init, 290K bss, 1424128K reserved, 245760K cma-reserved, 2167808K highmem)
    [08:31:45][ 0.000000] Virtual kernel memory layout:
    [08:31:45][ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
    [08:31:45][ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
    [08:31:45][ 0.000000] vmalloc : 0xf8000000 - 0xff800000 ( 120 MB)
    [08:31:45][ 0.000000] lowmem : 0xc0000000 - 0xf7800000 ( 888 MB)
    [08:31:45][ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
    [08:31:45][ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
    [08:31:45][ 0.000000] .text : 0xc0008000 - 0xc08e302c (9069 kB)
    [08:31:45][ 0.000000] .init : 0xc08e4000 - 0xc0938000 ( 336 kB)
    [08:31:45][ 0.000000] .data : 0xc0938000 - 0xc0988220 ( 321 kB)
    [08:31:45][ 0.000000] .bss : 0xc098a000 - 0xc09d2880 ( 291 kB)
    [08:31:45][ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [08:31:45][ 0.000000] Preemptible hierarchical RCU implementation.
    [08:31:45][ 0.000000] Build-time adjustment of leaf fanout to 32.
    [08:31:45][ 0.000000] NR_IRQS:16 nr_irqs:16 16
    [08:31:45][ 0.000000] ti_dt_clocks_register: failed to lookup clock node gmac_gmii_ref_clk_div
    [08:31:45][ 0.000000] OMAP clockevent source: timer1 at 32786 Hz
    [08:31:45][ 0.000000] Architected cp15 timer(s) running at 6.14MHz (phys).
    [08:31:45][ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
    [08:31:45][ 0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
    [08:31:45][ 0.000015] Switching to timer-based delay loop, resolution 162ns
    [08:31:45][ 0.000345] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
    [08:31:45][ 0.000352] OMAP clocksource: 32k_counter at 32768 Hz
    [08:31:45][ 0.000805] Console: colour dummy device 80x30
    [08:31:45][ 0.000820] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
    [08:31:45][ 0.000827] This ensures that you still see kernel messages. Please
    [08:31:45][ 0.000832] update your kernel commandline.
    [08:31:45][ 0.000846] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
    [08:31:45][ 0.000860] pid_max: default: 32768 minimum: 301
    [08:31:45][ 0.000956] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [08:31:45][ 0.000967] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [08:31:45][ 0.001514] Initializing cgroup subsys io
    [08:31:45][ 0.001530] Initializing cgroup subsys memory
    [08:31:45][ 0.001554] Initializing cgroup subsys devices
    [08:31:45][ 0.001566] Initializing cgroup subsys freezer
    [08:31:45][ 0.001578] Initializing cgroup subsys perf_event
    [08:31:45][ 0.001589] Initializing cgroup subsys pids
    [08:31:45][ 0.001616] CPU: Testing write buffer coherency: ok
    [08:31:45][ 0.001810] /cpus/cpu@0 missing clock-frequency property
    [08:31:45][ 0.001827] /cpus/cpu@1 missing clock-frequency property
    [08:31:45][ 0.001837] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [08:31:45][ 0.001871] Setting up static identity map for 0x80008380 - 0x800083e0
    [08:31:45][ 0.080060] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [08:31:45][ 0.080129] Brought up 2 CPUs
    [08:31:45][ 0.080142] SMP: Total of 2 processors activated (24.59 BogoMIPS).
    [08:31:45][ 0.080148] CPU: All CPU(s) started in HYP mode.
    [08:31:45][ 0.080153] CPU: Virtualization extensions available.
    [08:31:45][ 0.080532] devtmpfs: initialized
    [08:31:45][ 0.109481] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
    [08:31:45][ 0.110462] omap_hwmod: l3_main_2 using broken dt data from ocp
    [08:31:45][ 0.313582] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [08:31:45][ 0.313604] futex hash table entries: 512 (order: 3, 32768 bytes)
    [08:31:45][ 0.318780] pinctrl core: initialized pinctrl subsystem
    [08:31:45][ 0.319648] NET: Registered protocol family 16
    [08:31:45][ 0.320612] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [08:31:45][ 0.350234] cpuidle: using governor ladder
    [08:31:45][ 0.380256] cpuidle: using governor menu
    [08:31:45][ 0.388776] OMAP GPIO hardware version 0.1
    [08:31:45][ 0.392707] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
    [08:31:45][ 0.408123] omap-gpmc 50000000.gpmc: GPMC revision 6.0
    [08:31:45][ 0.408136] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
    [08:31:45][ 0.417225] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [08:31:45][ 0.417235] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [08:31:45][ 0.417702] omap4_sram_init:Unable to allocate sram needed to handle errata I688
    [08:31:45][ 0.417712] omap4_sram_init:Unable to get sram pool needed to handle errata I688
    [08:31:45][ 0.418286] OMAP DMA hardware revision 0.0
    [08:31:45][ 0.461509] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
    [08:31:45][ 0.462641] edma 43300000.edma: memcpy is disabled
    [08:31:45][ 0.467330] edma 43300000.edma: TI EDMA DMA engine driver
    [08:31:45][ 0.471384] omap-iommu 40d01000.mmu: 40d01000.mmu registered
    [08:31:45][ 0.471570] omap-iommu 40d02000.mmu: 40d02000.mmu registered
    [08:31:45][ 0.471729] omap-iommu 58882000.mmu: 58882000.mmu registered
    [08:31:45][ 0.471887] omap-iommu 55082000.mmu: 55082000.mmu registered
    [08:31:45][ 0.472163] omap-iommu 41501000.mmu: 41501000.mmu registered
    [08:31:45][ 0.472367] omap-iommu 41502000.mmu: 41502000.mmu registered
    [08:31:45][ 0.475408] palmas 0-0058: IRQ missing: skipping irq request
    [08:31:45][ 0.490843] palmas 0-0058: Muxing GPIO 2e, PWM 0, LED 0
    [08:31:45][ 0.552753] pcf857x: probe of 0-0020 failed with error -121
    [08:31:45][ 0.553005] pcf857x: probe of 0-0021 failed with error -121
    [08:31:45][ 0.553866] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
    [08:31:45][ 0.554280] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
    [08:31:45][ 0.554477] media: Linux media interface: v0.10
    [08:31:45][ 0.554530] Linux video capture interface: v2.00
    [08:31:45][ 0.554572] pps_core: LinuxPPS API ver. 1 registered
    [08:31:45][ 0.554580] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [08:31:45][ 0.554609] PTP clock support registered
    [08:31:45][ 0.554659] EDAC MC: Ver: 3.0.0
    [08:31:45][ 0.555411] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
    [08:31:45][ 0.555701] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
    [08:31:45][ 0.556029] Advanced Linux Sound Architecture Driver Initialized.
    [08:31:45][ 0.556887] clocksource: Switched to clocksource arch_sys_counter
    [08:31:45][ 0.567500] NET: Registered protocol family 2
    [08:31:45][ 0.568003] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    [08:31:45][ 0.568066] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    [08:31:45][ 0.568191] TCP: Hash tables configured (established 8192 bind 8192)
    [08:31:45][ 0.568237] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [08:31:45][ 0.568269] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [08:31:45][ 0.568412] NET: Registered protocol family 1
    [08:31:45][ 0.568714] RPC: Registered named UNIX socket transport module.
    [08:31:45][ 0.568723] RPC: Registered udp transport module.
    [08:31:45][ 0.568730] RPC: Registered tcp transport module.
    [08:31:45][ 0.568736] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [08:31:45][ 0.569704] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
    [08:31:45][ 0.579690] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [08:31:45][ 0.580333] NFS: Registering the id_resolver key type
    [08:31:45][ 0.580362] Key type id_resolver registered
    [08:31:45][ 0.580370] Key type id_legacy registered
    [08:31:45][ 0.580427] ntfs: driver 2.1.32 [Flags: R/O].
    [08:31:45][ 0.581699] bounce: pool size: 64 pages
    [08:31:45][ 0.581856] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
    [08:31:45][ 0.581871] io scheduler noop registered
    [08:31:45][ 0.581884] io scheduler deadline registered
    [08:31:45][ 0.581917] io scheduler cfq registered (default)
    [08:31:45][ 0.587391] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
    [08:31:45][ 0.590901] PCI host bridge /ocp/axi@0/pcie_rc@51000000 ranges:
    [08:31:45][ 0.590914] No bus range found for /ocp/axi@0/pcie_rc@51000000, using [bus 00-ff]
    [08:31:45][ 0.590947] IO 0x20003000..0x20012fff -> 0x00000000
    [08:31:45][ 0.590968] MEM 0x20013000..0x2fffffff -> 0x20013000
    [08:31:45][ 0.591174] dra7-pcie 51000000.pcie_rc: CFG 'Bus Master Enable' change
    [08:31:45][ 0.591184] dra7-pcie 51000000.pcie_rc: CFG 'Memory Space Enable' change
    [08:31:45][ 0.618228] dra7-pcie 51000000.pcie_rc: PCI host bridge to bus 0000:00
    [08:31:45][ 0.618242] pci_bus 0000:00: root bus resource [bus 00-ff]
    [08:31:45][ 0.618252] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
    [08:31:45][ 0.618261] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
    [08:31:45][ 0.618325] dra7-pcie 51000000.pcie_rc: CFG 'Memory Space Enable' change
    [08:31:45][ 0.618342] dra7-pcie 51000000.pcie_rc: CFG 'Memory Space Enable' change
    [08:31:45][ 0.618367] dra7-pcie 51000000.pcie_rc: CFG 'Memory Space Enable' change
    [08:31:45][ 0.618381] dra7-pcie 51000000.pcie_rc: CFG 'Memory Space Enable' change
    [08:31:45][ 0.618404] dra7-pcie 51000000.pcie_rc: CFG 'Memory Space Enable' change
    [08:31:45][ 0.618418] dra7-pcie 51000000.pcie_rc: CFG 'Memory Space Enable' change
    [08:31:45][ 0.618723] PCI: bus0: Fast back to back transfers disabled
    [08:31:45][ 0.636976] PCI: bus1: Fast back to back transfers disabled
    [08:31:45][ 0.637102] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
    [08:31:45][ 0.637117] pci 0000:00:00.0: BAR 8: assigned [mem 0x20200000-0x202fffff]
    [08:31:45][ 0.637127] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
    [08:31:45][ 0.637142] pci 0000:01:00.0: BAR 0: assigned [mem 0x20200000-0x20203fff 64bit]
    [08:31:45][ 0.637189] pci 0000:00:00.0: PCI bridge to [bus 01]
    [08:31:45][ 0.637201] pci 0000:00:00.0: bridge window [mem 0x20200000-0x202fffff]
    [08:31:45][ 0.637415] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
    [08:31:45][ 0.637424] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
    [08:31:45][ 0.698950] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
    [08:31:45][ 0.702333] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 202, base_baud = 3000000) is a 8250
    [08:31:45][ 1.802326] console [ttyS0] enabled
    [08:31:45][ 1.806714] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 203, base_baud = 3000000) is a 8250
    [08:31:46][ 1.816421] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 204, base_baud = 3000000) is a 8250
    [08:31:46][ 1.826437] [drm] Initialized drm 1.1.0 20060810
    [08:31:46][ 1.831996] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [08:31:46][ 1.838683] [drm] No driver support for vblank timestamp query.
    [08:31:46][ 1.844810] [drm] Initialized vdrm 1.0.0 20110917 on minor 0
    [08:31:46][ 1.851958] OMAP DSS rev 6.1
    [08:31:46][ 1.855700] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
    [08:31:46][ 1.871326] loop: module loaded
    [08:31:46][ 1.874863] vmemexp device MAJOR num = 245
    [08:31:46][ 1.879016] vmemexp class registered
    [08:31:46][ 1.882730] /dev/vmemexp device registered
    [08:31:46][ 1.886843] ioctl DBUFIOC_EXPORT_VIRTMEM = -1072899120
    [08:31:46][ 1.892394] nvme 0000:01:00.0: enabling device (0140 -> 0142)
    [08:31:46][ 1.898814] nand: No NAND device found
    [08:31:46][ 1.902586] omap2-nand 8000000.nand: scan failed, may be bus-width mismatch
    [08:31:46][ 1.911683] m25p80 spi32766.0: found n25q00, expected s25fl256s1
    [08:31:46][ 1.917807] m25p80 spi32766.0: n25q00 (131072 Kbytes)
    [08:31:46][ 1.922941] 7 ofpart partitions found on MTD device spi32766.0
    [08:31:46][ 1.928822] Creating 7 MTD partitions on "spi32766.0":
    [08:31:46][ 1.933983] 0x000000000000-0x000000040000 : "QSPI.SPL"
    [08:31:46][ 1.950138] 0x000000040000-0x000000140000 : "QSPI.u-boot"
    [08:31:46][ 1.966454] 0x000000140000-0x0000001c0000 : "QSPI.u-boot-spl-os"
    [08:31:46][ 1.973407] 0x0000001c0000-0x0000001d0000 : "QSPI.u-boot-env"
    [08:31:46][ 1.990094] 0x0000001d0000-0x0000001e0000 : "QSPI.u-boot-env.backup1"
    [08:31:46][ 2.007501] 0x0000001e0000-0x0000009e0000 : "QSPI.kernel"
    [08:31:46][ 2.020902] nvme0n1: p1
    [08:31:46][ 2.023970] 0x0000009e0000-0x000002000000 : "QSPI.file-system"
    [08:31:46][ 2.041778] libphy: Fixed MDIO Bus: probed
    [08:31:46][ 2.096919] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
    [08:31:46][ 2.103044] libphy: 48485000.mdio: probed
    [08:31:46][ 2.120298] davinci_mdio 48485000.mdio: phy[2]: device 48485000.mdio:02, driver TI DP83867
    [08:31:46][ 2.129241] cpsw 48484000.ethernet: Detected MACID = b4:52:a9:5d:f6:dc
    [08:31:46][ 2.135895] cpsw 48484000.ethernet: cpts: overflow check period 800
    [08:31:46][ 2.142870] cpsw 48484000.ethernet: cpsw: Detected MACID = b4:52:a9:5d:f6:dd
    [08:31:46][ 2.151491] mousedev: PS/2 mouse device common for all mice
    [08:31:46][ 2.157671] i2c /dev entries driver
    [08:31:46][ 2.166350] omap_hsmmc 4809c000.mmc: Got CD GPIO
    [08:31:46][ 2.207585] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
    [08:31:46][ 2.213970] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
    [08:31:46][ 2.220813] evm_3v3_sw: supplied by sysen1
    [08:31:46][ 2.257737] ledtrig-cpu: registered to indicate activity on CPUs
    [08:31:46][ 2.266163] aic_dvdd: supplied by evm_3v3_sw
    [08:31:46][ 2.271441] davinci-mcasp 4847c000.mcasp: invalid tdm slots: 0
    [08:31:46][ 2.278949] NET: Registered protocol family 10
    [08:31:46][ 2.294249] sit: IPv6 over IPv4 tunneling driver
    [08:31:46][ 2.299471] NET: Registered protocol family 17
    [08:31:46][ 2.304164] Key type dns_resolver registered
    [08:31:46][ 2.308612] omap_voltage_late_init: Voltage driver support not added
    [08:31:46][ 2.315509] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [08:31:46][ 2.321734] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [08:31:46][ 2.328425] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [08:31:46][ 2.334633] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [08:31:46][ 2.341981] Power Management for TI OMAP4+ devices.
    [08:31:46][ 2.347118] Registering SWP/SWPB emulation handler
    [08:31:46][ 2.353267] dmm 4e000000.dmm: workaround for errata i878 in use
    [08:31:46][ 2.360838] dmm 4e000000.dmm: initialized all PAT entries
    [08:31:46][ 2.367245] [drm] Initialized omapdrm 1.0.0 20110917 on minor 1
    [08:31:46][ 2.395127] hctosys: unable to open rtc device (rtc0)
    [08:31:46][ 2.412166] evm_1v8: disabling
    [08:31:46][ 2.415244] aic_dvdd: disabling
    [08:31:46][ 2.418643] ldousb: disabling
    [08:31:46][ 2.422109] ALSA device list:
    [08:31:46][ 2.425091] No soundcards found.
    [08:31:46][ 2.429409] Waiting for root device PARTUUID=3cc717e1-02...
    [08:31:46][ 2.437014] mmc0: host does not support reading read-only switch, assuming write-enable
    [08:31:46][ 2.449658] mmc0: new high speed SDHC card at address aaaa
    [08:31:46][ 2.455580] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
    [08:31:46][ 2.463881] mmcblk0: p1 p2
    [08:31:46][ 2.539402] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
    [08:31:46][ 2.550092] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
    [08:31:46][ 2.720742] EXT4-fs (mmcblk0p2): recovery complete
    [08:31:46][ 2.726717] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [08:31:46][ 2.734895] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [08:31:46][ 2.746588] devtmpfs: mounted
    [08:31:46][ 2.749805] Freeing unused kernel memory: 336K
    [08:31:46][ 2.754343] This architecture does not have kernel memory protection.
    [08:31:47][ 2.960952] systemd[1]: System time before build time, advancing clock.
    [08:31:47][ 3.005036] random: systemd: uninitialized urandom read (16 bytes read, 18 bits of entropy available)
    [08:31:47][ 3.020124] random: systemd: uninitialized urandom read (16 bytes read, 18 bits of entropy available)
    [08:31:47][ 3.031801] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
    [08:31:47][ 3.050445] systemd[1]: Detected architecture arm.
    [08:31:47]
    [08:31:47]Welcome to Arago 2016.12!
    [08:31:47]
    [08:31:47][ 3.080102] systemd[1]: Set hostname to <dra7xx-evm>.
    [08:31:47][ 3.153120] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 19 bits of entropy available)
    [08:31:47][ 3.168263] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 19 bits of entropy available)
    [08:31:47][ 3.178614] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 19 bits of entropy available)
    [08:31:47][ 3.191279] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
    [08:31:47][ 3.207670] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
    [08:31:47][ 3.296057] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
    [08:31:47][ 3.305584] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
    [08:31:47][ 3.315516] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
    [08:31:47][ 3.599416] systemd[1]: Configuration file /etc/systemd/system/multi-user.target.wants/vsdk.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [08:31:47][ 3.618752] systemd[1]: [/etc/systemd/system/multi-user.target.wants/vsdk.service:3] Failed to add dependency on rc.pvr, ignoring: Invalid argument
    [08:31:47][ 3.722044] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
    [08:31:47][ 3.729935] systemd[1]: sysinit.target: Found dependency on alignment.service/start
    [08:31:47][ 3.737699] systemd[1]: sysinit.target: Found dependency on basic.target/start
    [08:31:47][ 3.744959] systemd[1]: sysinit.target: Found dependency on sockets.target/start
    [08:31:47][ 3.752463] systemd[1]: sysinit.target: Found dependency on dbus.socket/start
    [08:31:47][ 3.759651] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
    [08:31:47][ 3.767101] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
    [08:31:47][ 3.776543] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start
    [08:31:47][ SKIP ] Ordering cycle found, skipping alignment.service
    [08:31:47][ 3.809456] systemd[1]: Listening on Journal Socket (/dev/log).
    [08:31:47][ OK ] Listening on Journal Socket (/dev/log).
    [08:31:48][ 3.849747] systemd[1]: Listening on Syslog Socket.
    [08:31:48][ OK ] Listening on Syslog Socket.
    [08:31:48][ 3.877369] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [08:31:48][ OK ] Started Dispatch Password Requests to Console Directory Watch.
    [08:31:48][ 3.907255] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [08:31:48][ OK ] Started Forward Password Requests to Wall Directory Watch.
    [08:31:48][ 3.937090] systemd[1]: Reached target Paths.
    [08:31:48][ OK ] Reached target Paths.
    [08:31:48][ 3.958550] systemd[1]: Created slice System Slice.
    [08:31:48][ OK ] Created slice System Slice.
    [08:31:48][ 3.987339] systemd[1]: Listening on Network Service Netlink Socket.
    [08:31:48][ OK ] Listening on Network Service Netlink Socket.
    [08:31:48][ 4.017213] systemd[1]: Listening on Journal Socket.
    [08:31:48][ OK ] Listening on Journal Socket.
    [08:31:48][ 4.077316] systemd[1]: Starting Remount Root and Kernel File Systems...
    [08:31:48] Starting Remount Root and Kernel File Systems...
    [08:31:48][ 4.100161] systemd[1]: Mounting POSIX Message Queue File System...
    [08:31:48][ 4.119339] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [08:31:48] Mounting POSIX Message Queue File System...
    [08:31:48][ 4.177107] systemd[1]: Mounting Debug File System...
    [08:31:48] Mounting Debug File System...
    [08:31:48][ 4.199594] systemd[1]: Starting Journal Service...
    [08:31:48] Starting Journal Service...
    [08:31:48][ 4.218683] systemd[1]: Starting Load Kernel Modules...
    [08:31:48] Starting Load Kernel Modules...
    [08:31:48][ 4.235908] systemd[1]: Starting Setup Virtual Console...
    [08:31:48] Starting Setup Virtual Console...
    [08:31:48][ 4.259813] systemd[1]: Reached target Remote File Systems.
    [08:31:48][ OK ] Reached target Remote File Systems.
    [08:31:48][ 4.317310] systemd[1]: Starting Create list of required static device nodes for the current kernel...
    [08:31:48] Starting Create list of required st... nodes for the current kernel...
    [08:31:48][ 4.347270] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
    [08:31:48][ OK ] Listening on /dev/initctl Compatibility Named Pipe.
    [08:31:48][ 4.377893] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [08:31:48][ OK ] Created slice system-serial\x2dgetty.slice.
    [08:31:48][ 4.437099] systemd[1]: Mounting Temporary Directory...
    [08:31:48] Mounting Temporary Directory...
    [08:31:48][ 4.467374] systemd[1]: Listening on udev Control Socket.
    [08:31:48][ OK ] Listening on udev Control Socket.
    [08:31:48][ 4.497999] systemd[1]: Created slice system-getty.slice.
    [08:31:48][ OK ] Created slice system-getty.slice.
    [08:31:48][ 4.527726] systemd[1]: Created slice User and Session Slice.
    [08:31:48][ OK ] Created slice User and Session Slice.
    [08:31:48][ 4.557121] systemd[1]: Reached target Slices.
    [08:31:48][ OK ] Reached target Slices.
    [08:31:48][ 4.577100] systemd[1]: Reached target Swap.
    [08:31:48][ OK ] Reached target Swap.
    [08:31:48][ 4.597183] systemd[1]: Listening on udev Kernel Socket.
    [08:31:48][ OK ] Listening on udev Kernel Socket.
    [08:31:48][ 4.662348] systemd[1]: Mounted Debug File System.
    [08:31:48][ OK ] Mounted Debug File System.
    [08:31:48][ 4.687236] systemd[1]: Mounted POSIX Message Queue File System.
    [08:31:48][ OK ] Mounted POSIX Message Queue File System.
    [08:31:48][ 4.717154] systemd[1]: Mounted Temporary Directory.
    [08:31:48][ OK ] Mounted Temporary Directory.
    [08:31:48][ 4.747337] systemd[1]: Started Journal Service.
    [08:31:48][ OK ] Started Journal Service.
    [08:31:48][ OK ] Started Remount Root and Kernel File Systems.
    [08:31:48][FAILED] Failed to start Load Kernel Modules.
    [08:31:48]See 'systemctl status systemd-modules-load.service' for details.
    [08:31:49][ OK ] Started Setup Virtual Console.
    [08:31:49][ OK ] Started Create list of required sta...ce nodes for the current kernel.
    [08:31:49] Starting Create Static Device Nodes in /dev...
    [08:31:49] Starting Apply Kernel Variables...
    [08:31:49] Starting udev Coldplug all Devices...
    [08:31:49] Starting Flush Journal to Persistent Storage...
    [08:31:49][ OK ] Started Apply Kernel Variables.
    [08:31:49][ OK ] Started Create Static Device Nodes in /dev.
    [08:31:49][ 5.480568] systemd-journald[120]: Received request to flush runtime journal from PID 1
    [08:31:49][ OK ] Started Flush Journal to Persistent Storage.
    [08:31:49][ OK ] Reached target Local File Systems (Pre).
    [08:31:49] Mounting /media/ram...
    [08:31:49] Mounting /var/volatile...
    [08:31:49] Starting udev Kernel Device Manager...
    [08:31:49][ OK ] Mounted /var/volatile.
    [08:31:49][ OK ] Mounted /media/ram.
    [08:31:49][ OK ] Started udev Kernel Device Manager.
    [08:31:50][ OK ] Started udev Coldplug all Devices.
    [08:31:50][ 6.082447] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@95800000
    [08:31:50][ 6.099270] remoteproc0: 55020000.ipu is available
    [08:31:50][ 6.117028] remoteproc0: Note: remoteproc is still under development and considered experimental.
    [08:31:50][ 6.151804] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [08:31:50] Starting Load/Save Random Seed...
    [08:31:50][ 6.183148] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@99000000
    [08:31:50][ OK ] Reached target Local File Systems.
    [08:31:50][ 6.208939] remoteproc1: 40800000.dsp is available
    [08:31:50][ 6.216510] remoteproc1: Note: remoteproc is still under development and considered experimental.
    [08:31:50][ 6.237289] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [08:31:50][ 6.261890] remoteproc1: Direct firmware load for dra7-dsp1-fw.xe66 failed with error -2
    [08:31:50][ 6.277545] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@9f000000
    [08:31:50][ 6.291101] remoteproc1: failed to load dra7-dsp1-fw.xe66
    [08:31:50][ 6.317029] remoteproc2: 41000000.dsp is available
    [08:31:50] Starting Create Volatile Files and Directories...[ 6.328858] remoteproc2: Note: remoteproc is still under development and considered experimental.
    [08:31:50]
    [08:31:50][ 6.362118] remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [08:31:50][ OK ] Started Load/Save Random Seed.
    [08:31:50][ 6.384607] remoteproc2: Direct firmware load for dra7-dsp2-fw.xe66 failed with error -2
    [08:31:50][ 6.432097] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
    [08:31:50][ 6.433120] remoteproc2: failed to load dra7-dsp2-fw.xe66
    [08:31:50][ OK ] Started Create Volatile Files and Directories.
    [08:31:50][ 6.517791] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
    [08:31:50][ 6.565631] remoteproc0: registered virtio0 (type 7)
    [08:31:50][ OK ] Found device /dev/ttyS0.
    [08:31:50][ 6.607066] omap_rtc 48838000.rtc: rtc core: registered 48838000.rtc as rtc0
    [08:31:51] Starting Update UTMP about System Boot/Shutdown...
    [08:31:51] Starting Network Time Synchronization...
    [08:31:51][ 7.052011] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
    [08:31:51][ 7.080170] SCSI subsystem initialized
    [08:31:51][ 7.084854] CAN device driver interface
    [08:31:51][ 7.088778] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
    [08:31:51][ 7.092581] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
    [08:31:51][ OK ] Started Network Time Synchronization.
    [08:31:51][ OK ] Started Update UTMP about System Boot/Shutdown.
    [08:31:51] Starting Synchronize System and HW clocks...
    [08:31:51][ OK ] Reached target System Time Synchronized.
    [08:31:51][ 7.436311] c_can_platform 4ae3c000.can: c_can_platform device registered (regs=fce3c000, irq=254)
    [08:31:51][ OK ] Started Synchronize System and HW clocks.
    [08:31:51][ 7.497772] [drm] Initialized pvr 1.14.3699939 20110701 on minor 2
    [08:31:51][ 7.504472] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled
    [08:31:51][ 7.522582] EXT4-fs (nvme0n1p1): recovery complete
    [08:31:51][ 7.537700] ahci 4a140000.sata: Enable 32-bit DMA instead of 64-bit.
    [08:31:51][ 7.561476] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    [08:31:51][ 7.585955] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
    [08:31:51][ 7.601777] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
    [08:31:51][ 7.649917] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst
    [08:31:51][ 7.750023] scsi host0: ahci
    [08:31:51][ 7.754301] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 240
    [08:31:52][ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
    [08:31:52][ OK ] Reached target System Initialization.
    [08:31:52][ OK ] Listening on dropbear.socket.
    [08:31:52][ OK ] Listening on D-Bus System Message Bus Socket.[ 8.136958] ata1: SATA link down (SStatus 0 SControl 300)
    [08:31:52]
    [08:31:52][ OK ] Reached target Sockets.
    [08:31:52][ OK ] Reached target Basic System.
    [08:31:52][ OK ] Started D-Bus System Message Bus.
    [08:31:52][ 8.354883] remoteproc0: powering up 55020000.ipu
    [08:31:52][ 8.370148] remoteproc0: Booting fw image dra7-ipu2-fw.xem4, size 4396172
    [08:31:52][ 8.377230] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
    [08:31:52] Starting Network Service...
    [08:31:52] Starting Permit User Sessions...
    [08:31:52][ 8.445388] remoteproc0: remote processor 55020000.ipu is now up
    [08:31:52][ 8.456618] net eth0: initializing cpsw version 1.15 (0)
    [08:31:52][ 8.462179] net eth0: initialized cpsw ale version 1.4
    [08:31:52][ 8.467660] net eth0: ALE Table size 1024
    [08:31:52][ OK ] Started Kernel Logging Service.[ 8.473334] virtio_rpmsg_bus virtio0: rpmsg host is online
    [08:31:52]
    [08:31:52][ 8.483981] net eth0: phy found : id is : 0x2000a231
    [08:31:52][ 8.496859] virtio_rpmsg_bus virtio0: creating channel rpmsg-proto addr 0x50
    [08:31:52][ 8.515005] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [08:31:52][ OK ] Started Launching Vision SDK App.
    [08:31:52][ OK ] Started Daily Cleanup of Temporary Directories.[ 8.556417] NET: Registered protocol family 41
    [08:31:52]
    [08:31:52][ OK ] Reached target Timers.
    [08:31:52] Starting Login Service...
    [08:31:52][ OK ] Started System Logging Service.
    [08:31:52] Starting rc.pvr.service...
    [08:31:52][FAILED] Failed to start Network Service.
    [08:31:52]See 'systemctl status systemd-networkd.service' for details.
    [08:31:52][ 8.755173] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
    [08:31:52][ OK ] Started Permit User Sessions.
    [08:31:53][ OK ] Started rc.pvr.service.
    [08:31:53] Starting weston.service...
    [08:31:53][ OK ] Stopped Network Service.
    [08:31:53] Starting Network Service...
    [08:31:53][ OK ] Started Getty on tty1.
    [08:31:53][ OK ] Started Serial Getty on ttyS0.
    [08:31:53][ OK ] Started weston.service.
    [08:31:53][FAILED] Failed to start Network Service.
    [08:31:53]See 'systemctl status systemd-networkd.service' for details.
    [08:31:53][ OK ] Started Login Service.
    [08:31:54] Starting Network Service...
    [08:31:54] Starting tiipclad-daemon.service...
    [08:31:54] Starting telnetd.service...
    [08:31:54][FAILED] Failed to start Network Service.
    [08:31:54]See 'systemctl status systemd-networkd.service' for details.
    [08:31:54][ OK ] Started tiipclad-daemon.service.
    [08:31:54][ OK ] Started telnetd.service.
    [08:31:54][ OK ] Stopped Network Service.
    [08:31:54][FAILED] Failed to listen on Network Service Bus Name.
    [08:31:54]See 'systemctl status org.freedesktop.network1.busname' for details.
    [08:31:54][ OK ] Reached target Network.
    [08:31:54] Starting Network Name Resolution...
    [08:31:54][ OK ] Started Network Name Resolution.
    [08:31:56][ 12.484484] cpsw 48484000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
    [08:31:56][ 12.492406] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [08:31:57][ 13.697551] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
    [08:31:59]
    [08:31:59] _____ _____ _ _
    [08:31:59]| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
    [08:31:59]| | _| .'| . | . | | __| _| . | | | -_| _| _|
    [08:31:59]|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
    [08:31:59] |___| |___|
    [08:31:59]
    [08:31:59]Arago Project http://arago-project.org dra7xx-evm ttyS0
    [08:31:59]
    [08:31:59]Arago 2016.12 dra7xx-evm ttyS0
    [08:31:59]
    [08:31:59]dra7xx-evm login: [ 15.736177] DMA: Module install successful, device major num = 241
    [08:31:59][ 15.742814] DRV: Module install successful
    [08:32:00][ 15.998006] omap_l3_noc 44000000.ocp: L3 application error: target 3 mod:2 (unclearable)
    [08:32:00][ 16.006153] omap_l3_noc 44000000.ocp: L3 debug error: target 3 mod:2 (unclearable)
    [08:32:14]
    [08:32:14] _____ _____ _ _
    [08:32:14]| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
    [08:32:14]| | _| .'| . | . | | __| _| . | | | -_| _| _|
    [08:32:14]|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
    [08:32:14] |___| |___|
    [08:32:14]
    [08:32:14]Arago Project http://arago-project.org dra7xx-evm ttyS0
    [08:32:14]
    [08:32:14]Arago 2016.12 dra7xx-evm ttyS0
    [08:32:14]
  • 开发板随附的SD卡中的测试日志具有不同的SDK版本(u-boot 2016.05和Linux Kernel 4.4)
    您正在构建的版本是不同的版本(u-boot 2019和Linux Kernel 4.19)
  • HI,
    今天尝试下载u-boot2016.05和kernel4.4.84进行编译,但是编译就存在问题。
    lewis@ubuntu:~/ti/PROCESSOR_SDK_VISION_03_08_00_00/ti_components/os_tools/linux/u-boot/u-boot$ ls configs/dr
    dra7xx_evm_defconfig dra7xx_evm_nodt_defconfig dra7xx_hs_evm_defconfig draco_defconfig dragonboard410c_defconfig dreamplug_defconfig
    lewis@ubuntu:~/ti/PROCESSOR_SDK_VISION_03_08_00_00/ti_components/os_tools/linux/u-boot/u-boot$ cd -
    /home/lewis/ti/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/build
    lewis@ubuntu:~/ti/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/build$ make linux
    make -C ./hlos/makerules/linux -f build_uboot.mk uboot
    make[1]: Entering directory '/home/lewis/ti/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/build/hlos/makerules/linux'
    make -fbuild_uboot.mk uboot_build UBOOT_TARGET=dra7xx_evm_vision_config
    make[2]: Entering directory '/home/lewis/ti/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/build/hlos/makerules/linux'
    make -C /home/lewis/ti/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/../ti_components/os_tools/linux/u-boot/u-boot ARCH=arm CROSS_COMPILE=/home/lewis/ti/PROCESSOR_SDK_VISION_03_08_00_00/ti_components/os_tools/linux/arm/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/bin/arm-linux-gnueabihf- dra7xx_evm_vision_config
    make[3]: Entering directory '/home/lewis/ti/PROCESSOR_SDK_VISION_03_08_00_00/ti_components/os_tools/linux/u-boot/u-boot'
    *** Can't find default configuration "arch/../configs/dra7xx_evm_vision_defconfig"!
    make[4]: *** [scripts/kconfig/Makefile:114: dra7xx_evm_vision_defconfig] Error 1
    make[3]: *** [Makefile:477: dra7xx_evm_vision_config] Error 2
    make[3]: Leaving directory '/home/lewis/ti/PROCESSOR_SDK_VISION_03_08_00_00/ti_components/os_tools/linux/u-boot/u-boot'
    make[2]: *** [build_uboot.mk:6: uboot_build] Error 2
    make[2]: Leaving directory '/home/lewis/ti/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/build/hlos/makerules/linux'
    make[1]: *** [build_uboot.mk:13: uboot] Error 2
    make[1]: Leaving directory '/home/lewis/ti/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/build/hlos/makerules/linux'
    make: *** [Makefile:450: uboot] Error 2
    查看u-boot下面的配置文件,的确未发下如下配置文件。configs/dra7xx_evm_vision_defconfig
    u-boot下载页面为git.ti.com/.../tags
    kenerl下载页面为git.ti.com/.../tags
  • 请遵循Vision SDK用户指南,不要从“"https://git.ti.com/cgit/glsdk/psdkla-u-boot/refs/tags",  https://git.ti.com/cgit/glsdk/psdkla-kernel/refs/tags 克隆u-boot & kernel ,因为这些都不是特定于vision SDK的。
    您遵循用户指南中的说明。通过以下步骤,我可以运行一种HLOS use-cases。
    1) Download & install the vision SDK 3.8
    2) Install package required for the build (chapter 2.2.3 Other mandatory software packages for build)
    3) Do the below changes in the vision_sdk/build/Rules.make
    MAKECONFIG?=tda2xx_evm_linux_all
    4) Follow the instruction provided in the user-guide for GIT configuration set-up (chapter 2.4.1 One time PC set up)
    5) cd vision_sdk/build/
    6) Run the below script from the build directory, this will clone kernel, u-boot, etc.
    ./hlos/scripts/linux/setup_linux.sh
    7)Follow the instruction provided in the user-guide for target file system set-up(chapter 2.4.2.1.4 Download and untar file system)
    8)Follow the instruction provided in the user-guide for A15 compiler set-up (chapter 2.2.1 A15 Compiler, Linker)
    9) make linux
    10) make linux_install
    11) make -s -j depend
    12) make -s -j
    13) Copy the target file system & boot image, MLO, etc to the SD card & insert the SD into the target SD card slot.
    14) Run the below command in the UART console.
    cd /opt/vision_sdk/
    source ./vision_sdk_load.sh
    ./apps.out
    15) You can choose the use-case you want to run from the menu.
  • HI Annie Liu:
    很感谢你的回答。 目前我个人感觉从git.ti.com克隆仓库,体验的确很糟糕(下载速度10多KB),个人感觉到是不是因为TI限速的原因,才导致速度这么慢?你这边获得仓库时也是这样的速度吗?你可以提供一个正常下载的版本或者链接地址吗? 谢谢
    lewis@ubuntu:~/ti_software_git$ git clone git://git.ti.com/glsdk/psdkla-kernel.git omap
    Cloning into 'omap'...
    remote: Counting objects: 7956674, done.
    remote: Compressing objects: 100% (1215458/1215458), done.
    rceiving objects: 0% (2935/7956674), 1.63 MiB | 18.00 KiB/s .
  • 这不是TI的限制,因为我们能够下载Mbps。
    Receiving objects: 5% (399321/7956674), 197.18 MiB | 11.76 MiB/s
    建议您尝试重新下载,或者换一台电脑
  • HI
    重新制作,仍然是失败。 (我想确认下, 13步骤是直接将file system & boot image, MLO, etc 拷贝到SD卡的吗? SD卡的文件系统是什么格式的? 我这边是使用./hlos/scripts/linux/mksdboot.sh制作到SD卡中,启动的LOG如下:)
    U-Boot 2019.01-00014-gf454ae0-dirty (Dec 09 2020 - 18:04:13 -0800)
    Model: TI DRA742
    DRAM: 4 GiB
    NAND: 0 MiB
    MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
    Loading Environment from MMC... Card did not respond to voltage select!
    *** Warning - No block device, using default environment
    invalid mmc device
    173 bytes read in 1 ms (168.9 KiB/s)
    4407808 bytes read in 193 ms (21.8 MiB/s)
    96488 bytes read in 5 ms (18.4 MiB/s)
    Loading Device Tree to 8ffe5000, end 8ffff8e7 ... OK
    Starting kernel ...
    [ 0.000000] Linux version 4.19.73-00040-g3d03684-dirty (lewis@ubuntu) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #1 SMP PREEMPT Wed Dec 9 18:05:19 PST 2020
    [ 0.000000] CPU: div instructions available: patching division code
    [ 0.000000] OF: fdt: Machine model: TI DRA742
    [ 0.000000] efi: Getting EFI parameters from FDT:
    [ 0.000000] efi: UEFI not found.
    [ 0.000000] OF: reserved mem: initialized node cmem@40300000, compatible id shared-dma-pool
    [ 0.000000] OF: reserved mem: initialized node ipu2-memory@95800000, compatible id shared-dma-pool
    [ 0.000000] OF: reserved mem: initialized node ipu1-memory@9d000000, compatible id shared-dma-pool
    [ 0.000000] OF: reserved mem: initialized node dsp1-memory@99000000, compatible id shared-dma-pool
    [ 0.000000] OF: reserved mem: initialized node dsp2-memory@9f000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 32 MiB
    [ 0.000000] OF: reserved mem: initialized node cmem@A9000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created CMA memory pool at 0x00000000b0000000, size 64 MiB
    [ 0.000000] OF: reserved mem: initialized node gpu-memory@c0000000, compatible id shared-dma-pool
    [ 0.000000] cma: Reserved 64 MiB at 0x00000000bbc00000
    [ 0.000000] OMAP4: Map 0x00000000bfd00000 to (ptrval) for dram barrier
    [ 0.000000] random: get_random_bytes called from start_kernel+0xb4/0x470 with crng_init=0
    [ 0.000000] percpu: Embedded 16 pages/cpu s36492 r8192 d20852 u65536
    [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 251456
    [ 0.000000] Kernel command line: console=ttyO0,115200n8 vram=16M root=PARTUUID=651f4d1c-02 rw rootwait ip=none mem=1024M cma=64M
    [ 0.000000] Memory: 280708K/1012736K available (10240K kernel code, 341K rwdata, 2804K rodata, 2048K init, 269K bss, 420732K reserved, 311296K cma-reserved, 128000K highmem)
    [ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
    [ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
    [ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (12256 kB)
    [ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (2048 kB)
    [ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 342 kB)
    [ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 270 kB)
    [ 0.000000] rcu: Preemptible hierarchical RCU implementation.
    [ 0.000000] Tasks RCU enabled.
    [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [ 0.000000] GIC: Using split EOI/Deactivate mode
    [ 0.000000] arch_timer: cp15 timer(s) running at 6.14MHz (phys).
    [ 0.000018] Switching to timer-based delay loop, resolution 162ns
    [ 0.000296] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
    [ 0.000305] OMAP clocksource: 32k_counter at 32768 Hz
    [ 0.000761] Console: colour dummy device 80x30
    [ 0.000781] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
    [ 0.000789] This ensures that you still see kernel messages. Please
    [ 0.000797] update your kernel commandline.
    [ 0.000830] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
    [ 0.000847] pid_max: default: 32768 minimum: 301
    [ 0.000971] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [ 0.000987] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [ 0.001530] CPU: Testing write buffer coherency: ok
    [ 0.001568] CPU0: Spectre v2: using ICIALLU workaround
    [ 0.001780] /cpus/cpu@0 missing clock-frequency property
    [ 0.001799] /cpus/cpu@1 missing clock-frequency property
    [ 0.001812] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [ 0.059917] Setting up static identity map for 0x80200000 - 0x80200060
    [ 0.079930] rcu: Hierarchical SRCU implementation.
    [ 0.100124] EFI services will not be available.
    [ 0.119991] smp: Bringing up secondary CPUs ...
    [ 0.200350] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [ 0.200356] CPU1: Spectre v2: using ICIALLU workaround
    [ 0.200479] smp: Brought up 1 node, 2 CPUs
    [ 0.200492] SMP: Total of 2 processors activated (24.59 BogoMIPS).
    [ 0.200501] CPU: All CPU(s) started in HYP mode.
    [ 0.200508] CPU: Virtualization extensions available.
    [ 0.200994] devtmpfs: initialized
    [ 0.219259] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
    [ 0.219520] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [ 0.219539] futex hash table entries: 512 (order: 3, 32768 bytes)
    [ 0.224374] pinctrl core: initialized pinctrl subsystem
    [ 0.224902] DMI not present or invalid.
    [ 0.225182] NET: Registered protocol family 16
    [ 0.226374] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [ 0.227290] omap_hwmod: l3_main_2 using broken dt data from ocp
    [ 0.421923] cpuidle: using governor ladder
    [ 0.421958] cpuidle: using governor menu
    [ 0.432077] OMAP GPIO hardware version 0.1
    [ 0.457786] No ATAGs?
    [ 0.457863] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [ 0.457878] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [ 0.458399] omap4_sram_init:Unable to allocate sram needed to handle errata I688
    [ 0.458411] omap4_sram_init:Unable to get sram pool needed to handle errata I688
    [ 0.459054] OMAP DMA hardware revision 0.0
    [ 0.470741] edma 43300000.edma: memcpy is disabled
    [ 0.474139] edma 43300000.edma: TI EDMA DMA engine driver
    [ 0.481286] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
    [ 0.482863] evm_3v3: supplied by evm_12v0
    [ 0.483157] evm_5v0: supplied by evm_12v0
    [ 0.483457] evm_3v6: supplied by evm_5v0
    [ 0.486656] omap-iommu 40d01000.mmu: 40d01000.mmu registered
    [ 0.486827] omap-iommu 40d02000.mmu: 40d02000.mmu registered
    [ 0.487079] omap-iommu 58882000.mmu: 58882000.mmu registered
    [ 0.487312] omap-iommu 55082000.mmu: 55082000.mmu registered
    [ 0.487688] omap-iommu 41501000.mmu: 41501000.mmu registered
    [ 0.487867] omap-iommu 41502000.mmu: 41502000.mmu registered
    [ 0.488143] iommu: Adding device 58820000.ipu to group 1
    [ 0.488223] iommu: Adding device 55020000.ipu to group 2
    [ 0.488349] iommu: Adding device 40800000.dsp to group 0
    [ 0.488586] iommu: Adding device 41000000.dsp to group 3
    [ 0.489698] SCSI subsystem initialized
    [ 0.490994] palmas 0-0058: IRQ missing: skipping irq request
    [ 0.520947] palmas 0-0058: Muxing GPIO 2e, PWM 0, LED 0
    [ 0.522610] SMPS123: supplied by regulator-dummy
    [ 0.524488] SMPS45: supplied by regulator-dummy
    [ 0.526333] SMPS6: supplied by regulator-dummy
    [ 0.528051] SMPS7: supplied by regulator-dummy
    [ 0.529892] SMPS8: supplied by regulator-dummy
    [ 0.531606] SMPS9: supplied by regulator-dummy
    [ 0.532595] LDO1: supplied by regulator-dummy
    [ 0.541428] LDO2: supplied by regulator-dummy
    [ 0.551301] LDO3: supplied by regulator-dummy
    [ 0.561309] LDO4: supplied by regulator-dummy
    [ 0.561575] random: fast init done
    [ 0.562045] LDO5: supplied by regulator-dummy
    [ 0.562751] LDO6: supplied by regulator-dummy
    [ 0.563464] LDO7: supplied by regulator-dummy
    [ 0.564194] LDO8: supplied by regulator-dummy
    [ 0.564921] LDO9: supplied by regulator-dummy
    [ 0.571348] LDOLN: supplied by regulator-dummy
    [ 0.581370] LDOUSB: supplied by regulator-dummy
    [ 0.593601] pcf857x: probe of 0-0020 failed with error -121
    [ 0.593851] pcf857x: probe of 0-0021 failed with error -121
    [ 0.594018] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
    [ 0.594486] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
    [ 0.594707] media: Linux media interface: v0.10
    [ 0.594746] videodev: Linux video capture interface: v2.00
    [ 0.594818] pps_core: LinuxPPS API ver. 1 registered
    [ 0.594828] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [ 0.594848] PTP clock support registered
    [ 0.594881] EDAC MC: Ver: 3.0.0
    [ 0.595679] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
    [ 0.595923] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
    [ 0.596439] Advanced Linux Sound Architecture Driver Initialized.
    [ 0.597250] clocksource: Switched to clocksource arch_sys_counter
    [ 0.605320] NET: Registered protocol family 2
    [ 0.605892] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
    [ 0.605921] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    [ 0.605984] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    [ 0.606110] TCP: Hash tables configured (established 8192 bind 8192)
    [ 0.606180] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [ 0.606214] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [ 0.606353] NET: Registered protocol family 1
    [ 0.626793] RPC: Registered named UNIX socket transport module.
    [ 0.626804] RPC: Registered udp transport module.
    [ 0.626813] RPC: Registered tcp transport module.
    [ 0.626821] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [ 0.627904] hw perfevents: no interrupt-affinity property for /pmu, guessing.
    [ 0.628110] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
    [ 0.629091] Initialise system trusted keyrings
    [ 0.629222] workingset: timestamp_bits=14 max_order=18 bucket_order=4
    [ 0.634138] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [ 0.644634] NFS: Registering the id_resolver key type
    [ 0.644660] Key type id_resolver registered
    [ 0.644669] Key type id_legacy registered
    [ 0.644708] ntfs: driver 2.1.32 [Flags: R/O].
    [ 0.646283] Key type asymmetric registered
    [ 0.646294] Asymmetric key parser 'x509' registered
    [ 0.646347] bounce: pool size: 64 pages
    [ 0.646380] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [ 0.646390] io scheduler noop registered
    [ 0.646399] io scheduler deadline registered
    [ 0.646497] io scheduler cfq registered (default)
    [ 0.646507] io scheduler mq-deadline registered
    [ 0.646516] io scheduler kyber registered
    [ 0.652336] pinctrl-single 4a003400.pinmux: 282 pins, size 1128
    [ 0.656328] dra7-pcie 51000000.pcie: Linked as a consumer to phy-4a094000.pciephy.1
    [ 0.656573] dra7-pcie 51000000.pcie: WA for Errata i870 not applied
    [ 0.656664] dra7-pcie 51000000.pcie: host bridge /ocp/axi@0/pcie@51000000 ranges:
    [ 0.656706] dra7-pcie 51000000.pcie: IO 0x20003000..0x20012fff -> 0x00000000
    [ 0.656734] dra7-pcie 51000000.pcie: MEM 0x20013000..0x2fffffff -> 0x20013000
    [ 1.657017] dra7-pcie 51000000.pcie: Phy link never came up
    [ 1.657151] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
    [ 1.657165] pci_bus 0000:00: root bus resource [bus 00-ff]
    [ 1.657177] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
    [ 1.657188] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
    [ 1.663312] PCI: bus0: Fast back to back transfers disabled
    [ 1.668921] PCI: bus1: Fast back to back transfers enabled
    [ 1.668965] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff 64bit]
    [ 1.668984] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
    [ 1.669303] pcieport 0000:00:00.0: Signaling PME with IRQ 176
    [ 1.669437] pcieport 0000:00:00.0: AER enabled with IRQ 176
    [ 1.673580] evm_1v8: supplied by smps9
    [ 1.673838] evm_3v3_sw: supplied by sysen1
    [ 1.674071] aic_dvdd: supplied by evm_3v3_sw
    [ 1.674158] vtt_fixed: supplied by sysen2
    [ 1.718873] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [ 1.722434] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 45, base_baud = 3000000) is a 8250
    [ 2.925250] console [ttyS0] enabled
    [ 2.929675] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 46, base_baud = 3000000) is a 8250
    [ 2.939306] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 47, base_baud = 3000000) is a 8250
    [ 2.950412] omap_rng 48090000.rng: Random Number Generator ver. 20
    [ 2.950741] random: crng init done
    [ 2.970535] brd: module loaded
    [ 2.979831] loop: module loaded
    [ 2.983647] vmemexp device MAJOR num = 244
    [ 2.987811] vmemexp class registered
    [ 2.991500] /dev/vmemexp device registered
    [ 2.995614] ioctl DBUFIOC_EXPORT_VIRTMEM = -1072899120
    [ 3.026544] m25p80 spi0.0: found n25q00, expected s25fl256s1
    [ 3.032517] m25p80 spi0.0: n25q00 (131072 Kbytes)
    [ 3.037356] 10 fixed-partitions partitions found on MTD device spi0.0
    [ 3.043827] Creating 10 MTD partitions on "spi0.0":
    [ 3.048746] 0x000000000000-0x000000010000 : "QSPI.SPL"
    [ 3.054623] 0x000000010000-0x000000020000 : "QSPI.SPL.backup1"
    [ 3.061178] 0x000000020000-0x000000030000 : "QSPI.SPL.backup2"
    [ 3.067728] 0x000000030000-0x000000040000 : "QSPI.SPL.backup3"
    [ 3.074254] 0x000000040000-0x000000140000 : "QSPI.u-boot"
    [ 3.080363] 0x000000140000-0x0000001c0000 : "QSPI.u-boot-spl-os"
    [ 3.087056] 0x0000001c0000-0x0000001d0000 : "QSPI.u-boot-env"
    [ 3.093524] 0x0000001d0000-0x0000001e0000 : "QSPI.u-boot-env.backup1"
    [ 3.100679] 0x0000001e0000-0x0000009e0000 : "QSPI.kernel"
    [ 3.106754] 0x0000009e0000-0x000002000000 : "QSPI.file-system"
    [ 3.113871] libphy: Fixed MDIO Bus: probed
    [ 3.177288] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000
    [ 3.184981] davinci_mdio 48485000.mdio: no live phy, scanning all
    [ 3.224435] libphy: 48485000.mdio: probed
    [ 3.229195] cpsw 48484000.ethernet: Detected MACID = b4:52:a9:5d:f6:dc
    [ 3.235798] cpsw 48484000.ethernet: initialized cpsw ale version 1.4
    [ 3.242208] cpsw 48484000.ethernet: ALE Table size 1024
    [ 3.247516] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies)
    [ 3.255510] cpsw 48484000.ethernet: cpsw: Detected MACID = b4:52:a9:5d:f6:dd
    [ 3.264151] i2c /dev entries driver
    [ 3.272769] cpu cpu0: Linked as a consumer to regulator.10
    [ 3.278385] cpu cpu0: Linked as a consumer to regulator.32
    [ 3.285260] sdhci: Secure Digital Host Controller Interface driver
    [ 3.291522] sdhci: Copyright(c) Pierre Ossman
    [ 3.296826] sdhci-pltfm: SDHCI platform and OF driver helper
    [ 3.303765] omap_gpio 4805d000.gpio: Could not set line 27 debounce to 200000 microseconds (-22)
    [ 3.312647] sdhci-omap 4809c000.mmc: Got CD GPIO
    [ 3.317484] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.31
    [ 3.324550] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.16
    [ 3.331582] sdhci-omap 4809c000.mmc: Dropping the link to regulator.16
    [ 3.338464] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.16
    [ 3.345354] sdhci-omap 4809c000.mmc: Dropping the link to regulator.16
    [ 3.351988] sdhci-omap 4809c000.mmc: Dropping the link to regulator.31
    [ 3.359347] sdhci-omap 480b4000.mmc: Linked as a consumer to regulator.2
    [ 3.366133] sdhci-omap 480b4000.mmc: Dropping the link to regulator.2
    [ 3.372691] sdhci-omap 480b4000.mmc: Linked as a consumer to regulator.2
    [ 3.405267] mmc0: SDHCI controller on 480b4000.mmc [480b4000.mmc] using ADMA
    [ 3.413169] ti-iodelay 4844a000.padconf: Set reg 0x840 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
    [ 3.422135] ti-iodelay 4844a000.padconf: Set reg 0x848 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
    [ 3.431142] ti-iodelay 4844a000.padconf: Set reg 0x84c Delay(a: 307 g: 0), Elements(C=0 F=8)0x29008
    [ 3.440325] ti-iodelay 4844a000.padconf: Set reg 0x850 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
    [ 3.449286] ti-iodelay 4844a000.padconf: Set reg 0x854 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
    [ 3.458341] ti-iodelay 4844a000.padconf: Set reg 0x870 Delay(a: 785 g: 0), Elements(C=1 F=8)0x29028
    [ 3.467540] ti-iodelay 4844a000.padconf: Set reg 0x874 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
    [ 3.476551] ti-iodelay 4844a000.padconf: Set reg 0x878 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
    [ 3.485600] ti-iodelay 4844a000.padconf: Set reg 0x87c Delay(a: 613 g: 0), Elements(C=1 F=3)0x29023
    [ 3.494804] ti-iodelay 4844a000.padconf: Set reg 0x880 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
    [ 3.503828] ti-iodelay 4844a000.padconf: Set reg 0x884 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
    [ 3.512879] ti-iodelay 4844a000.padconf: Set reg 0x888 Delay(a: 683 g: 0), Elements(C=1 F=5)0x29025
    [ 3.522082] ti-iodelay 4844a000.padconf: Set reg 0x88c Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
    [ 3.531126] ti-iodelay 4844a000.padconf: Set reg 0x890 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
    [ 3.540185] ti-iodelay 4844a000.padconf: Set reg 0x894 Delay(a: 835 g: 0), Elements(C=1 F=9)0x29029
    [ 3.549323] ti-iodelay 4844a000.padconf: Set reg 0x898 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
    [ 3.558256] ti-iodelay 4844a000.padconf: Set reg 0x89c Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
    [ 3.567585] sdhci-omap 480d1000.mmc: Linked as a consumer to regulator.8
    [ 3.574372] sdhci-omap 480d1000.mmc: Dropping the link to regulator.8
    [ 3.580953] sdhci-omap 480d1000.mmc: Linked as a consumer to regulator.7
    [ 3.587757] sdhci-omap 480d1000.mmc: Linked as a consumer to regulator.8
    [ 3.677302] sdhci-omap 480d1000.mmc: no pinctrl state for sdr104 mode
    [ 3.683775] sdhci-omap 480d1000.mmc: no pinctrl state for ddr50 mode
    [ 3.690180] sdhci-omap 480d1000.mmc: no pinctrl state for sdr50 mode
    [ 3.696567] sdhci-omap 480d1000.mmc: no pinctrl state for hs200_1_8v mode
    [ 3.729078] mmc1: SDHCI controller on 480d1000.mmc [480d1000.mmc] using PIO
    [ 3.736982] ledtrig-cpu: registered to indicate activity on CPUs
    [ 3.747559] tlv320aic3x-codec 0-0019: Linked as a consumer to regulator.3
    [ 3.754480] tlv320aic3x-codec 0-0019: Linked as a consumer to regulator.4
    [ 3.763192] davinci-mcasp 4847c000.mcasp: invalid tdm slots: 0
    [ 3.770605] NET: Registered protocol family 10
    [ 3.776008] Segment Routing with IPv6
    [ 3.779999] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [ 3.786445] NET: Registered protocol family 17
    [ 3.791166] Key type dns_resolver registered
    [ 3.795637] Registering SWP/SWPB emulation handler
    [ 3.800506] omap_voltage_late_init: Voltage driver support not added
    [ 3.806914] Power Management for TI OMAP4+ devices.
    [ 3.812553] Loading compiled-in X.509 certificates
    [ 3.842718] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [ 3.849434] [drm] No driver support for vblank timestamp query.
    [ 3.855747] [drm] Initialized vdrm 1.0.0 20191105 for 44000000.ocp:vdrm@0 on minor 0
    [ 3.940363] Console: switching to colour frame buffer device 240x67
    [ 3.963333] vdrm 44000000.ocp:vdrm@0: fb0: DRM emulated frame buffer device
    [ 3.970855] dmm 4e000000.dmm: workaround for errata i878 in use
    [ 3.978460] dmm 4e000000.dmm: initialized all PAT entries
    [ 3.984743] [drm] Initialized omapdrm 1.0.0 20110917 for omapdrm.0 on minor 1
    [ 3.993170] omap_gpio 4805d000.gpio: Could not set line 27 debounce to 200000 microseconds (-22)
    [ 4.002038] sdhci-omap 4809c000.mmc: Got CD GPIO
    [ 4.006891] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.31
    [ 4.014028] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.16
    [ 4.020944] sdhci-omap 4809c000.mmc: Dropping the link to regulator.16
    [ 4.027808] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.16
    [ 4.034704] sdhci-omap 4809c000.mmc: Dropping the link to regulator.16
    [ 4.041342] sdhci-omap 4809c000.mmc: Dropping the link to regulator.31
    [ 4.050022] asoc-simple-card sound0: tlv320aic3x-hifi <-> 48468000.mcasp mapping ok
    [ 4.057781] asoc-simple-card sound0: ASoC: no DMI vendor name!
    [ 4.066347] omap_gpio 4805d000.gpio: Could not set line 27 debounce to 200000 microseconds (-22)
    [ 4.075207] sdhci-omap 4809c000.mmc: Got CD GPIO
    [ 4.080066] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.31
    [ 4.087146] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.16
    [ 4.094065] sdhci-omap 4809c000.mmc: Dropping the link to regulator.16
    [ 4.100915] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.16
    [ 4.107837] sdhci-omap 4809c000.mmc: Dropping the link to regulator.16
    [ 4.114454] sdhci-omap 4809c000.mmc: Dropping the link to regulator.31
    [ 4.122454] omap_gpio 4805d000.gpio: Could not set line 27 debounce to 200000 microseconds (-22)
    [ 4.131316] sdhci-omap 4809c000.mmc: Got CD GPIO
    [ 4.136109] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.31
    [ 4.143220] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.16
    [ 4.150139] sdhci-omap 4809c000.mmc: Dropping the link to regulator.16
    [ 4.156949] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.16
    [ 4.163878] sdhci-omap 4809c000.mmc: Dropping the link to regulator.16
    [ 4.170509] sdhci-omap 4809c000.mmc: Dropping the link to regulator.31
    [ 4.178051] hctosys: unable to open rtc device (rtc0)
    [ 4.183879] aic_dvdd: disabling
    [ 4.187224] ldousb: disabling
    [ 4.190509] pbias_mmc_omap5: disabling
    [ 4.194313] ALSA device list:
    [ 4.197344] #0: DRA7xx-EVM
    [ 4.201057] Waiting for root device PARTUUID=651f4d1c-02...
    检查资源如下:(我觉得是没有问题的)
    lewis@ubuntu:~/ti/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/build$ ./hlos/scripts/linux/setup_linux.sh
    Linux Build Setup
    Cloning Kernel
    fatal: destination path 'omap' already exists and is not an empty directory.
    fatal: A branch named 'kernel_dev' already exists.
    Cloning Cmem
    fatal: destination path 'ludev' already exists and is not an empty directory.
    fatal: A branch named 'cmem_dev' already exists.
    Cloning UBoot
    fatal: destination path 'u-boot' already exists and is not an empty directory.
    fatal: A branch named 'uboot_dev' already exists.
    Cloning SGX ddk
    fatal: destination path 'omap5-sgx-ddk-linux' already exists and is not an empty directory.
    fatal: A branch named 'sgx_dev' already exists.
    Basic Linux Setup for 4.19 done
    Download the filesystem and untar
    其它文件如下:(文件系统和资源)
    lewis@ubuntu:~/ti_software_linux$ ls
    gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf.tar.xz PROCESSOR_SDK_VISION_03_08_00_00_setuplinux.bin tisdk-rootfs-image-dra7xx-evm_vsdk_3_8.tar.xz
  • 请您提供以下信息,以便于分析问题:
    • Go to the directory "ti_components/os_tools/linux/kernel/omap"  & run the command "git log"  then share the O/P of this command.
    • Share the O/P of "make -s showconfig", run this command from the vision SDK build directoty.
    是的,要从SD卡 boot,  需要使用脚本./hlos/scripts/linux/mksdboot.sh.
  • HI, 很高兴收到你的回复 。
    lewis@ubuntu:~/ti_software_git/omap$ git log
    commit 3d036849ccdc09ec79610811620f9805fbccb322
    Author: Subhajit Paul <subhajit_paul@ti.com>
    Date: Tue May 15 14:14:06 2018 +0530
    vdrm:Full rewrite for kernel 4.19
    Heavily based on omapdrm
    Signed-off-by: Subhajit Paul <subhajit_paul@ti.com>
    Signed-off-by: Ramprasad N <x0038811@ti.com>
    commit ec514ec3605908139cc62b4067b4d0e043805b1c
    Date: Mon Apr 30 12:26:20 2018 +0530
    vdrm: added DT node for visionSDK example usecase
    commit 8bbd382ee34df3d60c5915b757dfc229cf7dcdf4
    Author: Ramprasad N <x0038811@ti.com>
    Date: Tue Oct 1 13:14:17 2019 +0530
    :...skipping...
    ti_config_fragments: Turn off TIDSS configuration
    TIDSS is for J7 and if it is enabled in visionSDK,
    it has symbol conflicts with vDRM exposed functions.
    commit 7dfa5c9d72024520ed0cb388597760bc91673978
    Date: Thu Oct 31 12:14:33 2019 +0530
    ti_config_fragments: Add CONFIG_BLK_DEV_NVME to default config
    Cascade radar board has a NVME SSD card mounted on the board.
    Add NVME driver support by default in the kernel config
    Signed-off-by: Shravan Karthik <shravan.karthik@ti.com>
    commit 65852b621070dd781a76e5111579f6a550cded6f
    Date: Thu Aug 29 15:24:12 2019 +0530
    omapdrm: Remove DSS dependencies in omapdrm probe
    lewis@ubuntu:~/ti/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/build$ gmake -s showconfig
    # Build Config is [ tda2xx_evm_linux_all ]
    # Build Config file is @ /home/lewis/ti/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/configs/tda2xx_evm_linux_all/cfg.mk
    # Build Config .h file is @ /home/lewis/ti/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/links_fw/include/config/apps/tda2xx_evm_linux_all/system_cfg.h
    # Build CPUs is @ ipu2 a15_0 dsp1 dsp2 eve1 eve2 eve3 eve4
    # CPUs included in application,
    # PROC_IPU1_0_INCLUDE=no
    # PROC_IPU1_1_INCLUDE=no
    # PROC_IPU2_INCLUDE=yes
    # PROC_DSP1_INCLUDE=yes
    # PROC_DSP2_INCLUDE=yes
    # PROC_EVE1_INCLUDE=yes
    # PROC_EVE2_INCLUDE=yes
    # PROC_EVE3_INCLUDE=yes
    # PROC_EVE4_INCLUDE=yes
    # PROC_A15_0_INCLUDE=yes
    # Platform config,
    # VSDK_BOARD_TYPE=TDA2XX_EVM [options: TDA2XX_EVM TDA2EX_EVM TDA3XX_EVM TDA3XX_RVP TDA2XX_RVP]
    # PLATFORM=tda2xx-evm
    # DUAL_A15_SMP_BIOS=no
    # IPU1_SMP_BIOS=no
    # DDR_MEM=DDR_MEM_1024M [options: DDR_MEM_128M DDR_MEM_512M DDR_MEM_1024M]
    # EMIFMODE=SINGLE_EMIF_512MB [options: SINGLE_EMIF_512MB SINGLE_EMIF_1GB ref build_pdk.mk]
    # NDK_PROC_TO_USE=none [options: a15_0 ipu1_0 ipu1_1 ipu2 none]
    # NSP_TFDTP_INCLUDE=no [options: yes no]
    # TDA2EX_ETHSRV_BOARD=no [options: yes no]
    # FATFS_PROC_TO_USE=none [options: ipu1_0 none]
    # RADAR_BOARD=none [options: TDA3XX_AR12_ALPS TDA3XX_AR12_VIB_DAB_BOOSTER TDA3XX_RADAR_RVP none]
    # Build config,
    # BUILD_OS=Linux [options: Windows_NT Linux]
    # BUILD_DEPENDENCY_ALWAYS=no
    # BUILD_ALGORITHMS=no
    # BUILD_INFOADAS=no
    # PROFILE=release [options: debug release]
    # KW_BUILD=no
    # CPLUSPLUS_BUILD=no
    # IPU_PRIMARY_CORE=ipu2 [options: ipu1_0 ipu2]
    # IPU_SECONDARY_CORE=ipu1_0 [options: ipu1_0 ipu2]
    # A15_TARGET_OS=Linux [options: Bios Linux Qnx]
    # BSP_STW_PACKAGE_SELECT=all [options: all vps-iss-dss-only vps-vip-vpe]
    # Safety Module config,
    # RTI_INCLUDE=no
    # ECC_FFI_INCLUDE=no
    # DCC_ESM_INCLUDE=no
    # Video Module config,
    # IVAHD_INCLUDE=yes
    # VPE_INCLUDE=yes
    # CAL_INCLUDE=no
    # ISS_INCLUDE=no
    # ISS_ENABLE_DEBUG_TAPS=no
    # WDR_LDC_INCLUDE=no
    # DSS_INCLUDE=yes
    # Open Compute config,
    # OPENCL_INCLUDE=no
    # TARGET_ROOTDIR=/home/lewis/ti/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/../ti_components/os_tools/linux/targetfs
    # ENABLE_OPENCV=no
    # ENABLE_OPENCV_TESTS=no
    # OPENVX_INCLUDE=no
    # Log config,
    # ENABLE_UART_LOG=yes
    # ENABLE_NETWORK_LOG=no
    # ENABLE_CCS_LOG=no
    # CIO_REDIRECT=yes
    # IPC config,
    # WORKQ_INCLUDE=no
    # IPC_LIB_INCLUDE=no
    # AUTOSAR_APP=no
    # Surround View config,
    # SRV_FAST_BOOT_INCLUDE=no
    # Other Module config,
    # AVB_INCLUDE=no
    # DCAN_INCLUDE=no
    # RADAR_ONLY=no
    # RADAR_STUDIO=no
    # CPU_IDLE_ENABLED=yes
    # FAST_BOOT_INCLUDE=no
    # DATA_VIS_INCLUDE=no
    # HS_DEVICE=no
    # ULTRASONIC_INCLUDE=no
    # PGA450=
    # PGA460=
    # ENABLE_ALL_DEPTH=
    # Linux config,
    # DEFAULT_UBOOT_CONFIG=dra7xx_evm_vision_config
    # DEFAULT_KERNEL_CONFIG=ti_sdk_dra7x_release_defconfig
    # DEFAULT_DTB=dra7-evm-infoadas.dtb dra7-evm-infoadas-lcd-lg.dtb
    # CMEM_INCLUDE=yes
    # IPUMM_INCLUDE=no
    # IPU1_EVELOADER_INCLUDE=yes
    # ROBUST_RVC_INCLUDE=no
    # BUILD_ADAM_CAR=no
    # Alg plugins included in build,
    # ALG_autocalibration ALG_dmaSwMs ALG_framecopy ALG_sparseopticalflow ALG_structurefrommotion ALG_surroundview
    # Use-cases included in build,
    # UC_srv_calibration UC_lvds_vip_multi_cam_3d_perception UC_lvds_vip_multi_cam_3d_srv UC_lvds_vip_multi_cam_2mp_3d_srv UC_lvds_vip_multi_cam_3d_adaptive_srv UC_lvds_vip_multi_cam_view_sgx_display UC_lvds_vip_multi_cam_vpe_enc_null UC_null_src_decode_display UC_disp_dist_src_display UC_ov490_vip_multi_cam_3d_srv UC_vip_single_cam_connectorLinksA15_sgx_display UC_vip_single_cam_enc_dec_sgx_display UC_vip_single_cam_framecopy_sgx_display UC_vip_single_cam_framecopyEve_sgx_display UC_vip_single_cam_sgx_display
    # CPUs that are NOT required but included in config [ tda2xx_evm_linux_all ],
    # CPUs that are required but not included in config [ tda2xx_evm_linux_all ],
    # ERROR: IPU1_0 MUST be included in application
    # Edit /home/lewis/ti/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/apps/configs/tda2xx_evm_linux_all/cfg.mk to include or exclude CPUs in an application
  • 为什么在此目录中使用kernel code(〜/ ti_software_git / omap)? 这应该在“ ti_components / os_tools / linux / kernel / omap”目录中。
    您要从“〜/ ti_software_git / omap”目录构建Linux kernel吗?
  • HI,
    最终我会将〜/ ti_software_git / omap复制到ti_components / os_tools / linux / kernel / omap
    lewis@ubuntu:~/PROCESSOR_SDK_VISION_03_08_00_00/ti_components/os_tools/linux/kernel/omap$ git log
  • 请提供所有boot image,产品工程师将在安装程序中进行测试。
  • Hi
    很高兴收到你的回复。
    我查看了下文件大小 文件有811M, 通过什么方式可以传给们的产品工程师 ? 你们有FTP服务器么?
    lewis@ubuntu:~/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/hlos/linux/boot$ ll -h
    total 811M
    drwxr-xr-x 2 lewis lewis 4.0K Dec 15 18:08 ./
    drwxr-xr-x 3 lewis lewis 4.0K Dec 15 17:32 ../
    -rwxr-xr-x 1 lewis lewis 181K Dec 15 17:32 MLO*
    -rw-rw-r-- 1 lewis lewis 810M Dec 15 18:08 tisdk-rootfs-image-dra7xx-evm.tar.xz
    -rwxr-xr-x 1 lewis lewis 1.2M Dec 15 17:32 u-boot.img*
    -rwxrwxr-x 1 lewis lewis 173 Dec 15 17:32 uenv.txt*
  • 您可以点击:使用高级编译器编辑文本-在菜单栏中选择插入文件或者插入word.
  • HI,你好!
    网络上传的最大文件为20M, 即我压缩后文件将超过200M, 使用这种方式上传文件行不通。
  • 已给您发送私信,请查收。
  • 仅共享boot images即可(MLO,u-boot,uenv.txt和内核映像(/ bin / Image)),无需发送rootfs。
  • 请查收下~
  • Please share the Kernel Image(This will be in the /boot directory of rootfs).
  • 在TDA2xx EVM设置中测试了您的图像,可以成功运行的。
    从上一个开机自检日志中,知道您正在使用CASCADE TDA2XX EVM板,因此请使用以下配置而不是tda2xx_evm_linux_all重复所有步骤。
    MAKECONFIG?=tda2xx_cascade_linux_radar (File: vision_sdk/build/Rules.make)
    Please do the clean build after the above changes.
  • HI, 您好!
    根据你的配置可以正常启动和运行了。 谢谢了!
    [HOST] [IPU2 ] 13.111267 s: SYSTEM: System Init in progress !!!
    [HOST] [IPU2 ] 13.111328 s: SYSTEM: BSP Common Init in progress !!!
    [HOST] [IPU2 ] 13.111389 s: SYSTEM: BSP Common Init Done !!!
    [HOST] [IPU2 ] 13.111450 s: SYSTEM: BSP Platform Init in progress !!!
    [HOST] [IPU2 ] 13.113524 s: SYSTEM: BSP Platform Init Done !!!
    [HOST] [IPU2 ] 13.113585 s: SYSTEM: FVID2 Init in progress !!!
    [HOST] [IPU2 ] 13.113737 s: SYSTEM: FVID2 Init Done !!!
    [HOST] [IPU2 ] 13.113798 s: SYSTEM: VPS Init in progress !!!
    [HOST] [IPU2 ] 13.113859 s: SYSTEM: VPDMA Descriptor Memory Address translation ENABLED [0x80000000 -> 0x80000000]
    [HOST] [IPU2 ] 13.116879 s: *** VPDMA Firmware Loading... ***
    [HOST] [IPU2 ] 13.117062 s: VPDMA Firmware Address = 0xa03dc4c0
    [HOST] [IPU2 ] 13.117153 s: VPDMA Load Address = 0x4897d004
    [HOST] [IPU2 ] 13.117245 s: VPDMA Firmware Version = 0x4d0001b8
    [HOST] [IPU2 ] 13.117336 s: VPDMA List Busy Status = 0x00000000
    [HOST] [IPU2 ] 13.117397 s: *** VPDMA Firmware Load Success ***
    [HOST] [IPU2 ] 13.117733 s: *** VPDMA Firmware Loading... ***
    [HOST] [IPU2 ] 13.117824 s: VPDMA Firmware Address = 0xa03dc4c0
    [HOST] [IPU2 ] 13.117916 s: VPDMA Load Address = 0x4899d004
    [HOST] [IPU2 ] 13.118038 s: VPDMA Firmware Version = 0x4d0001b8
    [HOST] [IPU2 ] 13.118099 s: VPDMA List Busy Status = 0x00000000
    [HOST] [IPU2 ] 13.118190 s: *** VPDMA Firmware Load Success ***
    [HOST] [IPU2 ] 13.118526 s: *** VPDMA Firmware Loading... ***
    [HOST] [IPU2 ] 13.118587 s: VPDMA Firmware Address = 0xa03dc4c0
    [HOST] [IPU2 ] 13.118678 s: VPDMA Load Address = 0x489bd004
    [HOST] [IPU2 ] 13.118770 s: VPDMA Firmware Version = 0x4d0001b8
    [HOST] [IPU2 ] 13.118861 s: VPDMA List Busy Status = 0x00000000
    [HOST] [IPU2 ] 13.118983 s: *** VPDMA Firmware Load Success ***
    [HOST] [IPU2 ] 13.119288 s: *** VPDMA Firmware Loading... ***
    [HOST] [IPU2 ] 13.119380 s: VPDMA Firmware Address = 0xa03dc4c0
    [HOST] [IPU2 ] 13.119471 s: VPDMA Load Address = 0x489dd004
    [HOST] [IPU2 ] 13.119563 s: VPDMA Firmware Version = 0x4d0001b8
    [HOST] [IPU2 ] 13.119654 s: VPDMA List Busy Status = 0x00000000
    [HOST] [IPU2 ] 13.119746 s: *** VPDMA Firmware Load Success ***
    [HOST] [IPU2 ] 13.176508 s: SYSTEM: VPS Init Done !!!
    [HOST] [IPU2 ] 13.177392 s: UTILS: DMA: HWI Create for INT25 !!!
    [HOST] [IPU2 ] 13.177667 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
    [HOST] [IPU2 ] 13.177758 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 260928 B (254 KB)
    [HOST] [IPU2 ] 13.177972 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
    [HOST] [IPU2 ] 13.178124 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x84203000, Total size = 314572800 B (300 MB), Free size = 314572800 B (300 MB)
    [HOST] [IPU2 ] 13.178338 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xa0100000, Total size = 1047168 B (0 MB), Free size = 1047168 B (0 MB)
    [HOST] [IPU2 ] 13.178490 s: SYSTEM: Initializing Links !!!
    [HOST] [IPU2 ] 13.315988 s: Connection established with HLOS, calling rpmsgInit
    [HOST] [IPU2 ] 13.352437 s: SYSTEM: Initializing Links ... DONE !!!
    [HOST] [IPU2 ] 13.352955 s: CHAINS: Application Started !!!
    [HOST] [IPU2 ] 13.363051 s: BOARD: Board Init in progress !!!
    [HOST] [IPU2 ] 13.363600 s: BOARD: Board Init Done !!!
    [HOST] [IPU2 ] 13.368175 s:
    [HOST] [HOST ] 125.573964 s:
    [HOST] [HOST ]
    [HOST] [HOST ] ====================
    [HOST] [HOST ] Vision SDK Usecases
    [HOST] [HOST ] 1: Single Camera Usecases
    [HOST] [HOST ] 2: Multi-Camera LVDS Usecases
    [HOST] [HOST ] 3: Open-Compute Usecases
    [HOST] [HOST ] 6: Radar Usecases
    [HOST] [HOST ]
    [HOST] [HOST ] 7: PCIe SSD card Write Test
    [HOST] [HOST ] p: CPU Status
    [HOST] [HOST ] i: Show IP Addr (IPU + NDK + AVB)
    [HOST] [HOST ]
    [HOST] [HOST ] s: System Settings
    [HOST] [HOST ]
    [HOST] [HOST ] x: Exit
    [HOST] [HOST ] z: Exit - AND SHUTDOWN Remote CPUs
    [HOST] [HOST ]
    [HOST] [HOST ] Enter Choice:
    [HOST] [HOST ]
  • 很高兴您的问题得到解决。
  • Hi Annie Liu:
    If I operated the step 6 above (which refers to 2.4.2.1 in the Linux User Guide document) , do I need to go through the 2.4.2.1.1 ~ 2.4.2.1.3 suboperation in the guide document?
  • 遵循文档 VisionSDK_Linux_UserGuide.pdf 中所有构建操作步骤,能够正常构建。
