mmWave SDK
请问mmWave SDK使用手册中的下边的这种程序是怎么运行的?
Building component in windows
cd %MMWAVE_SDK_INSTALL_PATH%/ti/<component_path_under_ti>
gmake clean
gmake all
REM The command will create the following file
REM     lib<component>_<device_type>.aer4f library under ti/<component_path_under_ti>/lib folder
REM If the module has unit test, it will also create
REM     <device_type>_<component>_mss.xer4f unit test binary under ti/<component_path_under_ti>/test/<device_type>
folder
REM If the device has a DSP and the driver supports DSP then the command will also create
REM     lib<component>_<device_type>.ae674 library for DSS under ti/<component_path_under_ti>/lib folder
REM     <device_type>_<component>_dss.xe674 unit test binary for DSS under ti/<component_path_under_ti>/test
/<device_type> folder
REM Above paths are relative to %MMWAVE_SDK_INSTALL_PATH%/
REM For example to build the adcbuf lib and unit test
cd %MMWAVE_SDK_INSTALL_PATH%/ti/drivers/adcbuf
gmake clean
gmake all
REM For example to build the mmwavelink lib and unit test
cd %MMWAVE_SDK_INSTALL_PATH%/ti/control/mmwavelink
gmake clean
gmake all
REM For example to build the aoaproc dpu lib
cd %MMWAVE_SDK_INSTALL_PATH%/ti/datapath/dpc/dpu/aoaproc
gmake clean
gmake all
REM Additional build options for each component can be found by invoking make help
gmake help
