AWR2243级联雷达,使用mmWave studio 配置时,报错 Create Application Response from Capture Card timed out!!
GM: Constructor
GM: Mon Dec 14 19:36:51 2020
RSTD.Transmit("/Settings")
[19:36:51]
[19:36:51] ### Running Startup script: "C:\ti\mmwave_studio_03_00_00_14\mmWaveStudio\Scripts\Startup.lua" ###
[19:36:51] RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
[19:36:51] RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
[19:36:51] Scripter ignored: Attempt to UnBuild() again or before Build.
[19:36:51] RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "C:\\ti\\mmwave_studio_03_00_00_14\\mmWaveStudio\\Clients\\\\LabClient.dll")
[19:36:51] RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
[19:36:51] RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
[19:36:51] RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
[19:36:51] RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
[19:36:51] RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
[19:36:51] RSTD.SetVar ("/Settings/AL Client/AL Dll" , "C:\\ti\\mmwave_studio_03_00_00_14\\mmWaveStudio\\RunTime\\SAL.dll")
[19:36:51] RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
[19:36:51] RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
[19:36:51] RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
[19:36:51] RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
[19:36:51] RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
[19:36:51] RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
[19:36:51] RSTD.Transmit("/")
[19:36:51] RSTD.SaveSettings(): Settings saved to "C:\Users\my\AppData\Roaming\RSTD\config.xml"
[19:36:51] RSTD.Build()
[19:36:51] RSTD.AL_Build()
[19:36:51] RSTD.AL_LoadXml()
[19:36:51] RSTD.AL_Init()
[19:36:51] RSTD.Clients_Build()
[19:36:51] GM: Init
[19:36:51] GM: Loaded 'C:\ti\mmwave_studio_03_00_00_14\mmWaveStudio\Clients\\LabClient.dll'
[19:36:51] GM: 1 Guest (s) init
[19:36:51] GM: 1 Module(s) init
[19:36:51] GM: 2 Tab (s) init
[19:36:51] RSTD.Client_LoadXml()
[19:36:51] [RadarAPI]: ar1.selectRadarMode(0)
[19:36:51] [RadarAPI]: Status: Passed
[19:36:51] Matlab Runtime Engine is installed
[19:36:51] [RadarAPI]: Starting Matlab Engine..
[19:36:55] [RadarAPI]: Matlab Engine Started!
[19:36:57] [RadarAPI]: ar1.selectCascadeMode(0)
[19:36:57] [RadarAPI]: Status: Passed
[19:36:57] [RadarAPI]: ar1.LoadSettings('C:\Users\my\AppData\Roaming\RSTD\ar1gui.ini')
[19:36:57] TESTING = false
[19:36:57] RstdNet: Port 2777: Listening..
[19:36:57]
[19:36:57] ***Script completed successfully.***
[19:38:49] [RadarAPI]: ar1.selectRadarMode(1)
[19:38:49] [RadarAPI]: ar1.selectCascadeMode(1)
[19:38:49] [RadarAPI]: Status: Passed
[19:38:54] [RadarAPI]: ar1.SelectCaptureDevice("TDA2XX")
[19:38:54] [RadarAPI]: Status: Passed
[19:38:56] [RadarAPI]: TDAStatusCallback Event Registered
[19:38:56] [RadarAPI]: registerTDAStatusCallback Status: Passed
[19:38:56] [RadarAPI]: ar1.ConnectTDA("192.168.33.180", 5001, 15)
[19:38:56] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[19:38:56] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_VERSION_INFO Async event recieved() with status 0. TDA Version : REL_VISION_SDK_03_07_01_00 Aug 5 2019 15:04:45[19:38:56] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[19:38:58] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[19:38:58] [RadarAPI]: ConnectTDACaptureCard Status: Passed
[19:38:58] TDA Capture Card Status : CONNECTED!
[19:39:03] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[19:39:04] [RadarAPI]: ar1.FullReset(1)
[19:39:04] [RadarAPI]: Status: Passed
[19:39:04] [RadarAPI]: ar1.SOPControl_mult(1,4)
[19:39:05] [RadarAPI]: ar1.PowerOn_mult(1, 0, 1000, 0,0)
[19:39:05] [RadarAPI]: Status: Passed
[19:39:05] [DeviceId-0] MSS power up done async event received!
[19:39:06] [RadarAPI]: ar1.DownloadBSSFw_mult(1,"C:\\ti\\mmwave_dfp_02_02_02_01\\firmware\\xwr22xx_metaImage.bin")
[19:39:06] [RadarAPI]: ar1.DownloadBssFwOvSPI_mult(1, C:\\ti\\mmwave_dfp_02_02_02_01\\firmware\\xwr22xx_metaImage.bin)
[19:39:08] [RadarAPI]: ar1.SelectChipVersion("AR1243")
[19:39:08] [RadarAPI]: Status: Passed
[19:39:08] [RadarAPI]: ar1.deviceVariantSelection("XWR2243")
[19:39:08] [RadarAPI]: ar1.frequencyBandSelection("77G")
[19:39:08] [RadarAPI]: ar1.SelectChipVersion("XWR2243")
[19:39:08] Device Status : XWR2243/ASIL-B/SOP:4/ES:1.1
[19:39:08] [RadarAPI]: ar1.RfEnable_mult(1)
[19:39:08] [DeviceId-0] BSS power up done async event received!
[19:39:27] [RadarAPI]: ar1.ChanNAdcConfig_mult(1, 1, 1, 0, 1, 1, 1, 1, 2, 1, 0, 1)
[19:39:27] [RadarAPI]: Status: Passed
[19:39:44] [RadarAPI]: ar1.LPModConfig_mult(1, 0,0)
[19:39:44] [RadarAPI]: Status: Passed
[19:39:50] [RadarAPI]: ar1.RfInit_mult(1)
[19:39:51] [DeviceId-0] RF Init async event received!
[19:39:51] [RadarAPI]: Status: Passed
[19:39:51] [RadarAPI]: Time stamp, Temperture: 42777,34; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 1, 1; RxIQMM Status, Update: 1, 1;
[19:40:09] [RadarAPI]: Device 2 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[19:40:09] [RadarAPI]: ar1.FullReset(14)
[19:40:09] [RadarAPI]: Status: Passed
[19:40:09] [RadarAPI]: ar1.SOPControl_mult(14,4)
[19:40:22] [DeviceId-1] MSS power up done async event received!
[19:40:22] [RadarAPI]: ar1.AddDevice(2)
[19:40:22] [RadarAPI]: Status: Passed
[19:40:29] [RadarAPI]: ar1.DownloadBSSFw_mult(2,"C:\\ti\\mmwave_dfp_02_02_02_01\\firmware\\xwr22xx_metaImage.bin")
[19:40:29] [RadarAPI]: ar1.DownloadBssFwOvSPI_mult(2, C:\\ti\\mmwave_dfp_02_02_02_01\\firmware\\xwr22xx_metaImage.bin)
[19:40:31] [RadarAPI]: ar1.SelectChipVersion("AR1243")
[19:40:31] [RadarAPI]: Status: Passed
[19:40:31] [RadarAPI]: ar1.SelectChipVersion("XWR2243")
[19:40:31] Slave1 Device Status : XWR2243/ASIL-B/SOP:4/ES:1.1
[19:40:31] [RadarAPI]: ar1.RfEnable_mult(2)
[19:40:31] [DeviceId-1] BSS power up done async event received!
[19:40:41] [RadarAPI]: ar1.AddDevice(4)
[19:40:41] Status: Failed, Error Type: RESP TIMEOUT
[19:40:45] MSS Power Up async event was not received!
[19:40:55] [RadarAPI]: ar1.AddDevice(4)
[19:40:55] Status: Failed, Error Type: RESP TIMEOUT
[19:40:59] MSS Power Up async event was not received!
[19:41:04] [RadarAPI]: Device 4 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[19:41:05] [RadarAPI]: ar1.FullReset(4)
[19:41:05] [RadarAPI]: Status: Passed
[19:41:05] [RadarAPI]: ar1.SOPControl_mult(4,4)
[19:41:11] [DeviceId-2] MSS power up done async event received!
[19:41:11] [RadarAPI]: ar1.AddDevice(4)
[19:41:11] [RadarAPI]: Status: Passed
[19:41:18] [RadarAPI]: ar1.DownloadBSSFw_mult(4,"C:\\ti\\mmwave_dfp_02_02_02_01\\firmware\\xwr22xx_metaImage.bin")
[19:41:18] [RadarAPI]: ar1.DownloadBssFwOvSPI_mult(4, C:\\ti\\mmwave_dfp_02_02_02_01\\firmware\\xwr22xx_metaImage.bin)
[19:41:20] [RadarAPI]: ar1.SelectChipVersion("AR1243")
[19:41:20] [RadarAPI]: Status: Passed
[19:41:20] [RadarAPI]: ar1.SelectChipVersion("XWR2243")
[19:41:20] Slave2 Device Status : XWR2243/ASIL-B/SOP:4/ES:1.1
[19:41:20] [RadarAPI]: ar1.RfEnable_mult(4)
[19:41:20] [DeviceId-2] BSS power up done async event received!
[19:41:28] [RadarAPI]: Device 8 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[19:41:29] [RadarAPI]: ar1.FullReset(8)
[19:41:29] [RadarAPI]: Status: Passed
[19:41:29] [RadarAPI]: ar1.SOPControl_mult(8,4)
[19:41:32] [DeviceId-3] MSS power up done async event received!
[19:41:32] [RadarAPI]: ar1.AddDevice(8)
[19:41:32] [RadarAPI]: Status: Passed
[19:41:34] [RadarAPI]: ar1.DownloadBSSFw_mult(8,"C:\\ti\\mmwave_dfp_02_02_02_01\\firmware\\xwr22xx_metaImage.bin")
[19:41:34] [RadarAPI]: ar1.DownloadBssFwOvSPI_mult(8, C:\\ti\\mmwave_dfp_02_02_02_01\\firmware\\xwr22xx_metaImage.bin)
[19:41:36] [RadarAPI]: ar1.SelectChipVersion("AR1243")
[19:41:36] [RadarAPI]: Status: Passed
[19:41:36] [RadarAPI]: ar1.SelectChipVersion("XWR2243")
[19:41:36] Slave3 Device Status : XWR2243/ASIL-B/SOP:4/ES:1.1
[19:41:36] [RadarAPI]: ar1.RfEnable_mult(8)
[19:41:36] [DeviceId-3] BSS power up done async event received!
[19:44:39] [RadarAPI]: ar1.ChanNAdcConfig_mult(2, 1, 1, 0, 1, 1, 1, 1, 2, 1, 0, 2)
[19:44:39] [RadarAPI]: Status: Passed
[19:44:46] [RadarAPI]: ar1.LPModConfig_mult(2, 0,0)
[19:44:46] [RadarAPI]: Status: Passed
[19:44:50] [RadarAPI]: ar1.RfInit_mult(2)
[19:44:50] [DeviceId-1] RF Init async event received!
[19:44:50] [RadarAPI]: Status: Passed
[19:44:50] [RadarAPI]: Time stamp, Temperture: 259470,38; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 1, 1; RxIQMM Status, Update: 1, 1;
[19:45:14] [RadarAPI]: ar1.ChanNAdcConfig_mult(4, 1, 1, 0, 1, 1, 1, 1, 2, 1, 0, 2)
[19:45:14] [RadarAPI]: Status: Passed
[19:45:21] [RadarAPI]: ar1.LPModConfig_mult(4, 0,0)
[19:45:21] [RadarAPI]: Status: Passed
[19:45:26] [RadarAPI]: ar1.RfInit_mult(4)
[19:45:26] [DeviceId-2] RF Init async event received!
[19:45:26] [RadarAPI]: Status: Passed
[19:45:26] [RadarAPI]: Time stamp, Temperture: 246429,40; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 1, 1; RxIQMM Status, Update: 1, 1;
[19:45:55] [RadarAPI]: ar1.ChanNAdcConfig_mult(8, 1, 1, 0, 1, 1, 1, 1, 2, 1, 0, 2)
[19:45:55] [RadarAPI]: Status: Passed
[19:46:03] [RadarAPI]: ar1.LPModConfig_mult(8, 0,0)
[19:46:03] [RadarAPI]: Status: Passed
[19:46:13] [RadarAPI]: ar1.RfInit_mult(8)
[19:46:13] [DeviceId-3] RF Init async event received!
[19:46:13] [RadarAPI]: Status: Passed
[19:46:13] [RadarAPI]: Time stamp, Temperture: 276376,38; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 1, 1; RxIQMM Status, Update: 1, 1;
[19:47:29] [RadarAPI]: ar1.DisableTestSource_mult(1,0)
[19:47:29] [RadarAPI]: Status: Passed
[19:47:29] [RadarAPI]: ar1.AdvanceFrameConfig_mult(1, 1, 1536, 0, 0, 1, 128, 8000000, 0, 1, 1, 8000000, 0, 0, 1, 128, 8000000,0, 1, 1, 8000000, 0, 0, 1, 128, 8000000, 0, 1, 1, 8000000, 0, 0, 1,128, 8000000, 0, 1, 1, 8000000, 0, 1, 0, 1, 128, 0, 1, 128, 1, 1,128, 1, 1, 128, 1, 1)
[19:47:29] Status: Failed, Error Type: CHIRP USED IN THE FRAME IS NOT CONFIGURED BY AWR_CHIRP_CONF_SET_SB
[19:48:45] [RadarAPI]: ar1.ProfileConfig_mult(1, 0, 77, 100, 6, 60, 0, 0, 0, 0, 0, 0, 29.982, 0, 256, 10000, 0, 0, 94)
[19:48:45] [RadarAPI]: Status: Passed
[19:48:48] [RadarAPI]: ar1.ChirpConfig_mult(1, 0, 0, 0, 0, 0, 0, 0, 1, 0,0)
[19:48:48] [RadarAPI]: Status: Passed
[19:49:22] [RadarAPI]: ar1.DisableTestSource_mult(1,0)
[19:49:22] [RadarAPI]: Status: Passed
[19:49:22] [RadarAPI]: ar1.AdvanceFrameConfig_mult(1, 1, 1536, 0, 0, 1, 128, 8000000, 0, 1, 1, 8000000, 0, 0, 1, 128, 8000000,0, 1, 1, 8000000, 0, 0, 1, 128, 8000000, 0, 1, 1, 8000000, 0, 0, 1,128, 8000000, 0, 1, 1, 8000000, 0, 1, 0, 1, 128, 512, 1, 128, 1, 1,128, 1, 1, 128, 1, 1)
[19:49:22] Status: Failed, Error Type: DATA PATH CONFIGURATION NOT DONE
[19:49:49] [RadarAPI]: ar1.DataPathConfig_mult(1, 512, 1216644097, 0)
[19:49:49] [RadarAPI]: Status: Passed
[19:49:52] [RadarAPI]: ar1.LvdsClkConfig_mult(1, 1,1)
[19:49:52] [RadarAPI]: Status: Passed
[19:49:56] [RadarAPI]: ar1.CSI2LaneConfig_mult(1, 1, 0, 2, 0, 4, 0, 5,0,3,0, 0)
[19:49:56] [RadarAPI]: Status: Passed
[19:50:13] [RadarAPI]: ar1.DisableTestSource_mult(1,0)
[19:50:13] [RadarAPI]: Status: Passed
[19:50:13] [RadarAPI]: ar1.AdvanceFrameConfig_mult(1, 1, 1536, 0, 0, 1, 128, 8000000, 0, 1, 1, 8000000, 0, 0, 1, 128, 8000000,0, 1, 1, 8000000, 0, 0, 1, 128, 8000000, 0, 1, 1, 8000000, 0, 0, 1,128, 8000000, 0, 1, 1, 8000000, 0, 1, 0, 1, 128, 512, 1, 128, 1, 1,128, 1, 1, 128, 1, 1)
[19:51:09] [RadarAPI]: ar1.TDACaptureCard_StartRecord_mult(1, 0, 0, adc_data, 0)
[19:51:09] Device 0 - Configuring TDA with Width : 2048 and Height : 128
[19:51:09] [RadarAPI]: Device 0 - setWidthAndHeight Status: Passed
[19:51:09] Device 1 - Configuring TDA with Width : 0 and Height : 0
[19:51:09] [RadarAPI]: Device 1 - setWidthAndHeight Status: Passed
[19:51:09] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[19:51:09] Device 2 - Configuring TDA with Width : 0 and Height : 0
[19:51:09] [RadarAPI]: Device 2 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[19:51:09] [RadarAPI]: Device 2 - setWidthAndHeight Status: Passed
[19:51:09] [RadarAPI]: Device 4 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[19:51:09] Device 3 - Configuring TDA with Width : 0 and Height : 0
[19:51:09] [RadarAPI]: Device 3 - setWidthAndHeight Status: Passed
[19:51:09] [RadarAPI]: Device 8 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[19:51:09] Sending Frame Periodicity of 40 to TDA..
[19:51:09] [RadarAPI]: Status: Passed. Frame Periodicity sent to TDA
[19:51:09] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[19:51:10] Sending Capture Directory with name /mnt/ssd/adc_data to TDA..
[19:51:10] [RadarAPI]: Status: Passed. Capture Directory sent to TDA
[19:51:10] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[19:51:10] Sending File Allocation of 0 files to TDA..
[19:51:10] [RadarAPI]: Status: Passed. File Allocation sent to TDA
[19:51:10] Sending Enable Data Packaging (0 - 16-bit; 1 - 12-bit) with value of 0 to TDA..
[19:51:10] [RadarAPI]: Status: Passed. Enable Data Packaging sent to TDA
[19:51:10] Sending Number of frames to capture with value of 0 to TDA..
[19:51:10] [RadarAPI]: Status: Passed. Number of frames to capture sent to TDA
[19:51:10] [RadarAPI]: Status: Passed for notifying TDA about Creating Application
[19:51:19] Create Application Response from Capture Card timed out!!
