mmWave Studio 启动时不能加载Radar API,提示无法加载DLL,但该动态链接库已经存在于安装目录下
GM: Constructor
GM: Fri Dec 18 14:20:44 2020
RSTD.Transmit("/Settings")
[14:20:44]
[14:20:44] ### Running Startup script: "C:\ti\mmwave_studio_03_00_00_14\mmWaveStudio\Scripts\Startup.lua" ###
[14:20:44] RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
[14:20:44] RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
[14:20:44] Scripter ignored: Attempt to UnBuild() again or before Build.
[14:20:44] RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "C:\\ti\\mmwave_studio_03_00_00_14\\mmWaveStudio\\Clients\\\\LabClient.dll")
[14:20:44] RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
[14:20:44] RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
[14:20:44] RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
[14:20:44] RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
[14:20:44] RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
[14:20:44] RSTD.SetVar ("/Settings/AL Client/AL Dll" , "C:\\ti\\mmwave_studio_03_00_00_14\\mmWaveStudio\\RunTime\\SAL.dll")
[14:20:44] RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
[14:20:44] RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
[14:20:44] RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
[14:20:44] RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
[14:20:44] RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
[14:20:45] RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
[14:20:45] RSTD.Transmit("/")
[14:20:45] RSTD.SaveSettings(): Settings saved to "\\10.57.48.231\t3user\T3_user\koulian\AppData\Roaming\RSTD\config.xml"
[14:20:45] RSTD.Build()
[14:20:45] RSTD.AL_Build()
[14:20:45] RSTD.AL_LoadXml()
[14:20:45] RSTD.AL_Init()
[14:20:45] RSTD.Clients_Build()
[14:20:45] GM: Init
[14:20:45] GM: Loaded 'C:\ti\mmwave_studio_03_00_00_14\mmWaveStudio\Clients\\LabClient.dll'
[14:20:45] GM: 1 Guest (s) init
[14:20:45] GM: 1 Module(s) init
[14:20:45] GM: 2 Tab (s) init
[14:20:45] RSTD.Client_LoadXml()
[14:20:45] [RadarAPI]: ar1.selectRadarMode(0)
[14:20:45]
[14:20:45] &&&&&&&&&&&&&&&&&&&&
[14:20:45] ***Script FAILED!***
[14:20:45] Exception message is:
[14:20:45] 无法加载 DLL“RadarLinkDLL.dll”: 找不到指定的模块。 (异常来自 HRESULT:0x8007007E)。
