在MIMO模式例程的基础上,对chirps进行了修改,最终nsample取1024,chirp_loops取32,载入配置正常,采集脚本运行时报错,运行日志如下。我该做怎样的修改,才能正常采集?
GM: Constructor
GM: Tue Apr 13 22:06:47 2021
RSTD.Transmit("/Settings")
[22:06:48]
[22:06:48] ### Running Startup script: "D:\ti\mmwave_studio_03_00_00_14\mmWaveStudio\Scripts\Startup.lua" ###
[22:06:48] RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
[22:06:48] RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
[22:06:48] Scripter ignored: Attempt to UnBuild() again or before Build.
[22:06:48] RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "D:\\ti\\mmwave_studio_03_00_00_14\\mmWaveStudio\\Clients\\\\LabClient.dll")
[22:06:48] RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
[22:06:48] RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
[22:06:48] RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
[22:06:48] RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
[22:06:48] RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
[22:06:48] RSTD.SetVar ("/Settings/AL Client/AL Dll" , "D:\\ti\\mmwave_studio_03_00_00_14\\mmWaveStudio\\RunTime\\SAL.dll")
[22:06:48] RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
[22:06:48] RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
[22:06:48] RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
[22:06:48] RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
[22:06:48] RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
[22:06:48] RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
[22:06:48] RSTD.Transmit("/")
[22:06:48] RSTD.SaveSettings(): Settings saved to "C:\Users\Allen\AppData\Roaming\RSTD\config.xml"
[22:06:48] RSTD.Build()
[22:06:48] RSTD.AL_Build()
[22:06:48] RSTD.AL_LoadXml()
[22:06:48] RSTD.AL_Init()
[22:06:48] RSTD.Clients_Build()
[22:06:48] GM: Init
[22:06:48] GM: Loaded 'D:\ti\mmwave_studio_03_00_00_14\mmWaveStudio\Clients\\LabClient.dll'
[22:06:48] GM: 1 Guest (s) init
[22:06:48] GM: 1 Module(s) init
[22:06:48] GM: 2 Tab (s) init
[22:06:48] RSTD.Client_LoadXml()
[22:06:49] [RadarAPI]: ar1.selectRadarMode(0)
[22:06:49] [RadarAPI]: Status: Passed
[22:06:49] Matlab Runtime Engine is installed
[22:06:49] [RadarAPI]: Starting Matlab Engine..
[22:06:57] [RadarAPI]: Matlab Engine Started!
[22:07:00] [RadarAPI]: ar1.selectCascadeMode(0)
[22:07:00] [RadarAPI]: Status: Passed
[22:07:00] [RadarAPI]: ar1.LoadSettings('C:\Users\Allen\AppData\Roaming\RSTD\ar1gui.ini')
[22:07:00] TESTING = false
[22:07:00] RstdNet: Port 2777: Listening..
[22:07:00]
[22:07:00] ***Script completed successfully.***
[22:07:23] Setting up Studio for Cascade started..
[22:07:23] [RadarAPI]: ar1.SelectCaptureDevice("TDA2XX")
[22:07:23] [RadarAPI]: Status: Passed
[22:07:23] [RadarAPI]: TDAStatusCallback Event Registered
[22:07:23] [RadarAPI]: registerTDAStatusCallback Status: Passed
[22:07:23] [RadarAPI]: ar1.ConnectTDA("192.168.33.180", 5001, 15)
[22:07:23] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[22:07:23] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_VERSION_INFO Async event recieved() with status 0. TDA Version : REL_VISION_SDK_03_07_01_00 Aug 5 2019 15:04:45[22:07:23] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[22:07:24] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[22:07:24] [RadarAPI]: ConnectTDACaptureCard Status: Passed
[22:07:24] TDA Capture Card Status : CONNECTED!
[22:07:24] ConnectTDA Successful
[22:07:24] [RadarAPI]: ar1.selectCascadeMode(1)
[22:07:25] [RadarAPI]: Status: Passed
[22:07:25] selectCascadeMode Successful
[22:07:25] Setting up Studio for Cascade ended..
[22:07:25] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[22:07:25] [RadarAPI]: ar1.FullReset(1)
[22:07:25] [RadarAPI]: ar1.SOPControl_mult(1,4)
[22:07:25] Master : SOP Reset Successful
[22:07:26] [RadarAPI]: ar1.PowerOn_mult(1, 0, 1000, 0,0)
[22:07:26] [RadarAPI]: Status: Passed
[22:07:26] [DeviceId-0] MSS power up done async event received!
[22:07:26] Master : SPI Connection Successful
[22:07:26] [RadarAPI]: ar1.DownloadBssFwOvSPI_mult(1, D:\\ti\\mmwave_dfp_02_02_02_01\\firmware\\xwr22xx_metaImage.bin)
[22:07:28] Master : FW Download Successful
[22:07:29] [RadarAPI]: ar1.SelectChipVersion("AR1243")
[22:07:29] [RadarAPI]: Status: Passed
[22:07:29] [RadarAPI]: ar1.deviceVariantSelection("XWR2243")
[22:07:29] [RadarAPI]: ar1.frequencyBandSelection("77G")
[22:07:29] [RadarAPI]: ar1.SelectChipVersion("XWR2243")
[22:07:30] Device Status : XWR2243/ASIL-B/SOP:4/ES:1.1
[22:07:30] [RadarAPI]: ar1.RfEnable_mult(1)
[22:07:30] [DeviceId-0] BSS power up done async event received!
[22:07:30] [RadarAPI]: Status: Passed
[22:07:31] Master : RF Power Up Successful
[22:07:31] [RadarAPI]: ar1.ChanNAdcConfig_mult(1, 1, 1, 1, 1, 1, 1, 1, 2, 1, 0, 1)
[22:07:32] [RadarAPI]: Status: Passed
[22:07:32] Master : Channel & ADC Configuration Successful
[22:07:32] [RadarAPI]: Device 2 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[22:07:32] [RadarAPI]: ar1.FullReset(2)
[22:07:32] [RadarAPI]: ar1.SOPControl_mult(2,4)
[22:07:32] Device 2 : SOP Reset Successful
[22:07:33] [DeviceId-1] MSS power up done async event received!
[22:07:33] [RadarAPI]: ar1.AddDevice(2)
[22:07:33] [RadarAPI]: Status: Passed
[22:07:33] Device 2 : SPI Connection Successful
[22:07:33] [RadarAPI]: Device 4 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[22:07:33] [RadarAPI]: ar1.FullReset(4)
[22:07:33] [RadarAPI]: ar1.SOPControl_mult(4,4)
[22:07:33] Device 3 : SOP Reset Successful
[22:07:34] [DeviceId-2] MSS power up done async event received!
[22:07:34] [RadarAPI]: ar1.AddDevice(4)
[22:07:34] [RadarAPI]: Status: Passed
[22:07:34] Device 3 : SPI Connection Successful
[22:07:34] [RadarAPI]: Device 8 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[22:07:34] [RadarAPI]: ar1.FullReset(8)
[22:07:34] [RadarAPI]: ar1.SOPControl_mult(8,4)
[22:07:34] Device 4 : SOP Reset Successful
[22:07:35] [DeviceId-3] MSS power up done async event received!
[22:07:35] [RadarAPI]: ar1.AddDevice(8)
[22:07:35] [RadarAPI]: Status: Passed
[22:07:35] Device 4 : SPI Connection Successful
[22:07:35] [RadarAPI]: ar1.DownloadBssFwOvSPI_mult(14, D:\\ti\\mmwave_dfp_02_02_02_01\\firmware\\xwr22xx_metaImage.bin)
[22:07:37] Slaves : FW Download Successful
[22:07:38] [RadarAPI]: ar1.SelectChipVersion("AR1243")
[22:07:38] [RadarAPI]: Status: Passed
[22:07:38] [RadarAPI]: ar1.SelectChipVersion("XWR2243")
[22:07:38] Slave1 Device Status : XWR2243/ASIL-B/SOP:4/ES:1.1
[22:07:39] [RadarAPI]: ar1.SelectChipVersion("AR1243")
[22:07:39] [RadarAPI]: Status: Passed
[22:07:39] [RadarAPI]: ar1.SelectChipVersion("XWR2243")
[22:07:39] Slave2 Device Status : XWR2243/ASIL-B/SOP:4/ES:1.1
[22:07:40] [RadarAPI]: ar1.SelectChipVersion("AR1243")
[22:07:40] [RadarAPI]: Status: Passed
[22:07:40] [RadarAPI]: ar1.SelectChipVersion("XWR2243")
[22:07:40] Slave3 Device Status : XWR2243/ASIL-B/SOP:4/ES:1.1
[22:07:40] [RadarAPI]: ar1.RfEnable_mult(14)
[22:07:41] [DeviceId-3] BSS power up done async event received!
[22:07:41] [DeviceId-2] BSS power up done async event received!
[22:07:41] [DeviceId-1] BSS power up done async event received!
[22:07:41] [RadarAPI]: Status: Passed
[22:07:45] Slaves : RF Power Up Successful
[22:07:45] [RadarAPI]: ar1.ChanNAdcConfig_mult(14, 1, 1, 1, 1, 1, 1, 1, 2, 1, 0, 2)
[22:07:45] [RadarAPI]: Status: Passed
[22:07:45] Slaves : Channel & ADC Configuration Successful
[22:07:45] [RadarAPI]: ar1.RfLdoBypassConfig_mult(15, 0xF)
[22:07:45] LDO Bypass Successful
[22:07:46] [RadarAPI]: ar1.LPModConfig_mult(15, 0,0)
[22:07:46] [RadarAPI]: Status: Passed
[22:07:46] Low Power Mode Configuration Successful
[22:07:46] [RadarAPI]: ar1.SetMiscConfig_mult(15, 1, 0, 0, 0)
[22:07:46] Misc Control Configuration Successful
[22:07:46] [RadarAPI]: ar1.RfInitCalibConfig_mult(15, 1, 1, 1, 1, 1, 1, 1, 65537)
[22:07:46] RF Init Calibration Successful
[22:07:46] [RadarAPI]: ar1.RfInit_mult(15)
[22:07:46] [DeviceId-3] RF Init async event received!
[22:07:46] [DeviceId-1] RF Init async event received!
[22:07:46] [DeviceId-0] RF Init async event received!
[22:07:46] [DeviceId-2] RF Init async event received!
[22:07:46] [RadarAPI]: Time stamp, Temperture: 5552,49; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 1, 1; RxIQMM Status, Update: 1, 1;
[22:07:46] RF Init Successful
[22:07:46] [RadarAPI]: ar1.DataPathConfig_mult(15, 0, 1, 0)
[22:07:46] Data Path Configuration Successful
[22:07:46] [RadarAPI]: ar1.LvdsClkConfig_mult(15, 1,1)
[22:07:47] [RadarAPI]: Status: Passed
[22:07:47] Clock Configuration Successful
[22:07:47] [RadarAPI]: ar1.CSI2LaneConfig_mult(15, 1, 0, 2, 0, 4, 0, 5,0,3,0, 0)
[22:07:47] CSI2 Configuration Successful
[22:07:47] [RadarAPI]: ar1.ProfileConfig_mult(15, 0, 77, 7, 4.21, 55.66, 0, 0, 0, 0, 0, 0, 60.012, 0, 1024, 20000, 0, 0, 48)
[22:07:47] Profile Configuration successful
[22:07:47] [RadarAPI]: ar1.ChirpConfig_mult(1, 0, 0, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:47] Device 1 : Chirp 0 Configuration successful
[22:07:47] [RadarAPI]: ar1.ChirpConfig_mult(1, 1, 1, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:47] Device 1 : Chirp 1 Configuration successful
[22:07:47] [RadarAPI]: ar1.ChirpConfig_mult(1, 2, 2, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:47] Device 1 : Chirp 2 Configuration successful
[22:07:47] [RadarAPI]: ar1.ChirpConfig_mult(1, 3, 3, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:48] [RadarAPI]: Status: Passed
[22:07:48] Device 1 : Chirp 3 Configuration successful
[22:07:48] [RadarAPI]: ar1.ChirpConfig_mult(1, 4, 4, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:48] Device 1 : Chirp 4 Configuration successful
[22:07:48] [RadarAPI]: ar1.ChirpConfig_mult(1, 5, 5, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:48] Device 1 : Chirp 5 Configuration successful
[22:07:48] [RadarAPI]: ar1.ChirpConfig_mult(1, 6, 6, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:48] Device 1 : Chirp 6 Configuration successful
[22:07:48] [RadarAPI]: ar1.ChirpConfig_mult(1, 7, 7, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:48] Device 1 : Chirp 7 Configuration successful
[22:07:48] [RadarAPI]: ar1.ChirpConfig_mult(1, 8, 8, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:48] Device 1 : Chirp 8 Configuration successful
[22:07:48] [RadarAPI]: ar1.ChirpConfig_mult(1, 9, 9, 0, 0, 0, 0, 0, 0, 0,1)
[22:07:48] Device 1 : Chirp 9 Configuration successful
[22:07:49] [RadarAPI]: ar1.ChirpConfig_mult(1, 10, 10, 0, 0, 0, 0, 0, 0, 1,0)
[22:07:49] [RadarAPI]: Status: Passed
[22:07:49] Device 1 : Chirp 10 Configuration successful
[22:07:49] [RadarAPI]: ar1.ChirpConfig_mult(1, 11, 11, 0, 0, 0, 0, 0, 1, 0,0)
[22:07:49] Device 1 : Chirp 11 Configuration successful
[22:07:49] [RadarAPI]: ar1.ChirpConfig_mult(2, 0, 0, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:49] Device 2 : Chirp 0 Configuration successful
[22:07:49] [RadarAPI]: ar1.ChirpConfig_mult(2, 1, 1, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:49] Device 2 : Chirp 1 Configuration successful
[22:07:49] [RadarAPI]: ar1.ChirpConfig_mult(2, 2, 2, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:49] Device 2 : Chirp 2 Configuration successful
[22:07:49] [RadarAPI]: ar1.ChirpConfig_mult(2, 3, 3, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:49] Device 2 : Chirp 3 Configuration successful
[22:07:49] [RadarAPI]: ar1.ChirpConfig_mult(2, 4, 4, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:49] Device 2 : Chirp 4 Configuration successful
[22:07:50] [RadarAPI]: ar1.ChirpConfig_mult(2, 5, 5, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:50] [RadarAPI]: Status: Passed
[22:07:50] Device 2 : Chirp 5 Configuration successful
[22:07:50] [RadarAPI]: ar1.ChirpConfig_mult(2, 6, 6, 0, 0, 0, 0, 0, 0, 0,1)
[22:07:50] Device 2 : Chirp 6 Configuration successful
[22:07:50] [RadarAPI]: ar1.ChirpConfig_mult(2, 7, 7, 0, 0, 0, 0, 0, 0, 1,0)
[22:07:50] Device 2 : Chirp 7 Configuration successful
[22:07:50] [RadarAPI]: ar1.ChirpConfig_mult(2, 8, 8, 0, 0, 0, 0, 0, 1, 0,0)
[22:07:50] Device 2 : Chirp 8 Configuration successful
[22:07:50] [RadarAPI]: ar1.ChirpConfig_mult(2, 9, 9, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:50] Device 2 : Chirp 9 Configuration successful
[22:07:50] [RadarAPI]: ar1.ChirpConfig_mult(2, 10, 10, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:50] Device 2 : Chirp 10 Configuration successful
[22:07:50] [RadarAPI]: ar1.ChirpConfig_mult(2, 11, 11, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:50] Device 2 : Chirp 11 Configuration successful
[22:07:51] [RadarAPI]: ar1.ChirpConfig_mult(4, 0, 0, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:51] [RadarAPI]: Status: Passed
[22:07:51] Device 3 : Chirp 0 Configuration successful
[22:07:51] [RadarAPI]: ar1.ChirpConfig_mult(4, 1, 1, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:51] Device 3 : Chirp 1 Configuration successful
[22:07:51] [RadarAPI]: ar1.ChirpConfig_mult(4, 2, 2, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:51] Device 3 : Chirp 2 Configuration successful
[22:07:51] [RadarAPI]: ar1.ChirpConfig_mult(4, 3, 3, 0, 0, 0, 0, 0, 0, 0,1)
[22:07:51] Device 3 : Chirp 3 Configuration successful
[22:07:51] [RadarAPI]: ar1.ChirpConfig_mult(4, 4, 4, 0, 0, 0, 0, 0, 0, 1,0)
[22:07:51] Device 3 : Chirp 4 Configuration successful
[22:07:51] [RadarAPI]: ar1.ChirpConfig_mult(4, 5, 5, 0, 0, 0, 0, 0, 1, 0,0)
[22:07:51] Device 3 : Chirp 5 Configuration successful
[22:07:51] [RadarAPI]: ar1.ChirpConfig_mult(4, 6, 6, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:52] Device 3 : Chirp 6 Configuration successful
[22:07:52] [RadarAPI]: ar1.ChirpConfig_mult(4, 7, 7, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:52] [RadarAPI]: Status: Passed
[22:07:52] Device 3 : Chirp 7 Configuration successful
[22:07:52] [RadarAPI]: ar1.ChirpConfig_mult(4, 8, 8, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:52] Device 3 : Chirp 8 Configuration successful
[22:07:52] [RadarAPI]: ar1.ChirpConfig_mult(4, 9, 9, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:52] Device 3 : Chirp 9 Configuration successful
[22:07:52] [RadarAPI]: ar1.ChirpConfig_mult(4, 10, 10, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:52] Device 3 : Chirp 10 Configuration successful
[22:07:52] [RadarAPI]: ar1.ChirpConfig_mult(4, 11, 11, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:52] Device 3 : Chirp 11 Configuration successful
[22:07:52] [RadarAPI]: ar1.ChirpConfig_mult(8, 0, 0, 0, 0, 0, 0, 0, 0, 0,1)
[22:07:52] Device 4 : Chirp 0 Configuration successful
[22:07:52] [RadarAPI]: ar1.ChirpConfig_mult(8, 1, 1, 0, 0, 0, 0, 0, 0, 1,0)
[22:07:53] [RadarAPI]: Status: Passed
[22:07:53] Device 4 : Chirp 1 Configuration successful
[22:07:53] [RadarAPI]: ar1.ChirpConfig_mult(8, 2, 2, 0, 0, 0, 0, 0, 1, 0,0)
[22:07:53] Device 4 : Chirp 2 Configuration successful
[22:07:53] [RadarAPI]: ar1.ChirpConfig_mult(8, 3, 3, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:53] Device 4 : Chirp 3 Configuration successful
[22:07:53] [RadarAPI]: ar1.ChirpConfig_mult(8, 4, 4, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:53] Device 4 : Chirp 4 Configuration successful
[22:07:53] [RadarAPI]: ar1.ChirpConfig_mult(8, 5, 5, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:53] Device 4 : Chirp 5 Configuration successful
[22:07:53] [RadarAPI]: ar1.ChirpConfig_mult(8, 6, 6, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:53] Device 4 : Chirp 6 Configuration successful
[22:07:53] [RadarAPI]: ar1.ChirpConfig_mult(8, 7, 7, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:53] Device 4 : Chirp 7 Configuration successful
[22:07:53] [RadarAPI]: ar1.ChirpConfig_mult(8, 8, 8, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:54] [RadarAPI]: Status: Passed
[22:07:54] Device 4 : Chirp 8 Configuration successful
[22:07:54] [RadarAPI]: ar1.ChirpConfig_mult(8, 9, 9, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:54] Device 4 : Chirp 9 Configuration successful
[22:07:54] [RadarAPI]: ar1.ChirpConfig_mult(8, 10, 10, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:54] Device 4 : Chirp 10 Configuration successful
[22:07:54] [RadarAPI]: ar1.ChirpConfig_mult(8, 11, 11, 0, 0, 0, 0, 0, 0, 0,0)
[22:07:54] Device 4 : Chirp 11 Configuration successful
[22:07:54] Test Source Already Disabled...!!!
[22:07:54] [RadarAPI]: ar1.DisableTestSource_mult(1,0)
[22:07:54] [RadarAPI]: ar1.FrameConfig_mult(1, 0, 11, 5, 32, 100, 0, 1)
[22:07:55] [RadarAPI]: Status: Passed
[22:07:55] Master : Frame Configuration successful
[22:07:55] Test Source Already Disabled...!!!
[22:07:55] [RadarAPI]: ar1.DisableTestSource_mult(14,0)
[22:07:55] [RadarAPI]: ar1.FrameConfig_mult(14, 0, 11, 5, 32, 100, 0, 2)
[22:07:55] Slaves : Frame Configuration successful
[22:07:55]
[22:07:55] ***Script completed successfully.***
[22:31:13] Loops Remaining : 1
[22:31:13] Starting TDA ARM...
[22:31:13] [RadarAPI]: ar1.TDACaptureCard_StartRecord_mult(1, 0, 0, czhTest1, 0)
[22:31:13] Device 0 - Configuring TDA with Width : 8192 and Height : 384
[22:31:13] [RadarAPI]: Device 0 - setWidthAndHeight Status: Passed
[22:31:13] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[22:31:13] Device 1 - Configuring TDA with Width : 8192 and Height : 384
[22:31:13] [RadarAPI]: Device 1 - setWidthAndHeight Status: Passed
[22:31:13] [RadarAPI]: Device 2 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[22:31:13] Device 2 - Configuring TDA with Width : 8192 and Height : 384
[22:31:13] [RadarAPI]: Device 2 - setWidthAndHeight Status: Passed
[22:31:13] [RadarAPI]: Device 4 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[22:31:13] Device 3 - Configuring TDA with Width : 8192 and Height : 384
[22:31:13] [RadarAPI]: Device 3 - setWidthAndHeight Status: Passed
[22:31:13] [RadarAPI]: Device 8 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[22:31:13] Sending Frame Periodicity of 100 to TDA..
[22:31:13] [RadarAPI]: Status: Passed. Frame Periodicity sent to TDA
[22:31:13] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[22:31:14] Sending Capture Directory with name /mnt/ssd/czhTest1 to TDA..
[22:31:14] [RadarAPI]: Status: Passed. Capture Directory sent to TDA
[22:31:14] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[22:31:14] Sending File Allocation of 0 files to TDA..
[22:31:14] [RadarAPI]: Status: Passed. File Allocation sent to TDA
[22:31:14] Sending Enable Data Packaging (0 - 16-bit; 1 - 12-bit) with value of 0 to TDA..
[22:31:14] [RadarAPI]: Status: Passed. Enable Data Packaging sent to TDA
[22:31:14] Sending Number of frames to capture with value of 0 to TDA..
[22:31:14] [RadarAPI]: Status: Passed. Number of frames to capture sent to TDA
[22:31:14] [RadarAPI]: Status: Passed for notifying TDA about Creating Application
[22:31:24] Create Application Response from Capture Card timed out!!
[22:31:24] TDA ARM Failed
[22:31:24]
[22:31:24] ***Script completed successfully.***
