两块LM3S9B96通信不成功。
我在一块板子上用SSI0做主发送数据,SSI1做从接收数据可以。但是我把程序拆分开,分别把主从程序下载到两块LM3S9B96板子中,链接都建立不上,用示波器根本看不到波形。下面是两个程序
Master程序:
#include "inc/hw_memmap.h"
#include "inc/hw_ssi.h"
#include "inc/hw_types.h"
#include "driverlib/ssi.h"
#include "driverlib/gpio.h"
#include "driverlib/sysctl.h"
#include "utils/uartstdio.h"
#define NUM_SSI_DATA 8
#define USER_BITRATE 1000
// 设定 SSI0 为SPI主模式,
int
main(void)
   unsigned long ulDataTx[NUM_SSI_DATA];
   unsigned long ulindex;
   SysCtlClockSet(SYSCTL_SYSDIV_1 | SYSCTL_USE_OSC | SYSCTL_OSC_MAIN |
                  SYSCTL_XTAL_16MHZ);
   SysCtlPeripheralEnable(SYSCTL_PERIPH_SSI0);
   SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
   //设定PA2&PA3&PA4&PA5为SSI0引脚,
   GPIOPinConfigure(GPIO_PA2_SSI0CLK);
   GPIOPinConfigure(GPIO_PA3_SSI0FSS);
   GPIOPinConfigure(GPIO_PA4_SSI0RX);
   GPIOPinConfigure(GPIO_PA5_SSI0TX);
   GPIOPinTypeSSI(GPIO_PORTA_BASE, GPIO_PIN_5 | GPIO_PIN_4 | GPIO_PIN_3 |
                  GPIO_PIN_2);
   SSIConfigSetExpClk(SSI0_BASE, SysCtlClockGet(),
                      SSI_FRF_MOTO_MODE_0,
                      SSI_MODE_MASTER, USER_BITRATE, 8);
   SSIEnable(SSI0_BASE);
   while(1)
   ulDataTx[0] = 'M';
   ulDataTx[1] = '3';
   ulDataTx[2] = 'S';
   ulDataTx[3] = 'P';
   ulDataTx[4] = 'I';
   ulDataTx[5] = 'S';
   ulDataTx[6] = 'S';
   ulDataTx[7] = 'I';
   for(ulindex = 0; ulindex < NUM_SSI_DATA; ulindex++)
       SSIDataPut(SSI0_BASE, ulDataTx[ulindex]);
   //确认SSI发送是否为忙,确认的发送是否已完成
   while(SSIBusy(SSI0_BASE))
从机程序为:
void
InitConsole(void)
   GPIOPinConfigure(GPIO_PA0_U0RX);
   GPIOPinConfigure(GPIO_PA1_U0TX);
   GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1);
   UARTStdioInit(0);
// SSI1 为SPI从模式,接收
int
main(void)
   unsigned long ulDataRx[NUM_SSI_DATA];
                  SYSCTL_XTAL_16MHZ);
   InitConsole();
   UARTprintf("SSI ->\n");
   UARTprintf("  Mode: SPI\n");
   UARTprintf("  Data: 8-bit\n\n");
   SysCtlPeripheralEnable(SYSCTL_PERIPH_SSI1);
   SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE);
   //设定PA2&PA3&PA4&PA5为SSI1引脚,
   GPIOPinConfigure(GPIO_PE0_SSI1CLK);
   GPIOPinConfigure(GPIO_PE1_SSI1FSS);
   GPIOPinConfigure(GPIO_PE2_SSI1RX);
   GPIOPinConfigure(GPIO_PE3_SSI1TX);
   GPIOPinTypeSSI(GPIO_PORTE_BASE, GPIO_PIN_3 | GPIO_PIN_2 | GPIO_PIN_1 |
                  GPIO_PIN_0);
   SSIConfigSetExpClk(SSI1_BASE, SysCtlClockGet(),
                      SSI_MODE_SLAVE, USER_BITRATE, 8);
   SSIEnable(SSI1_BASE);
   while(SSIDataGetNonBlocking(SSI1_BASE, &ulDataRx[0]))
   UARTprintf("\nReceived:\n  ");
while(1)
       //接收数据,把一个数据读出SSI1 的RX FIFO(如无数据直接返回)
       SSIDataGetNonBlocking(SSI1_BASE, &ulDataRx[ulindex]);
       ulDataRx[ulindex] &= 0x00FF;
       UARTprintf("'%c' ", ulDataRx[ulindex]);
请专家帮忙看下,先谢谢了。
