RDK-BLDC-9107源代码问题。
买了这块BLDC开发板用来学习无刷电机,下了开发包里的代码,看了蛮久了,发现有几处错误:
第一:
// Mapping from Hall States to Phase Drive states (60 degree spacing).
// This array maps the hall state value to the set of PWM
// signals that should be driving at that time.
// \verbatim
//     Phase A  | + | Z | - | - | Z | + |
//     Phase B  | - | - | Z | + | + | Z |
//     Phase C  | Z | + | + | Z | - | - |
//     Hall A   | 0 | 1 | 1 | 1 | 0 | 0 |
//     Hall B   | 0 | 0 | 1 | 1 | 1 | 0 |
//     Hall C   | 0 | 0 | 0 | 1 | 1 | 1 |
// \endverbatim
static const unsigned long g_ulHallToPhase60[8] =
   PWM_PHASEA_HIGH | PWM_PHASEB_LOW,
   PWM_PHASEC_HIGH | PWM_PHASEB_LOW,
   0,
   PWM_PHASEC_HIGH | PWM_PHASEA_LOW,
   PWM_PHASEA_HIGH | PWM_PHASEC_LOW,
   0,
   PWM_PHASEB_HIGH | PWM_PHASEC_LOW,
   PWM_PHASEB_HIGH | PWM_PHASEA_LOW,
换相顺序根本没对应上
其实:
// If trapezoid (not sine), and slow decay, set the odd PWM at near
   // 100% duty cycle.
   if((UI_PARAM_MODULATION != MODULATION_SINE) &&
           (g_ucDecayMode == DECAY_SLOW))
       PWMPulseWidthSet(PWM0_BASE, PWM_OUT_1,
                        (g_ulPWMClock - UI_PARAM_PWM_DEAD_TIME));
       PWMPulseWidthSet(PWM0_BASE, PWM_OUT_3,
       PWMPulseWidthSet(PWM0_BASE, PWM_OUT_5,
怎么会产生近100%占空比的pwm??
前面定义的:
     // Get the number of PWM clocks in a 20 KHz period.
           g_ulPWMClock = PWM_CLOCK / 20000;
// Configure the PWM period, duty cycle, and dead band.  The initial period
   // is 1 KHz (for triggering the ADC), which will be increased when the
   // motor starts running.
   // 配置PWM周期,占空比,死区。最初的周期是1KHZ(触发ADC),当点击开始启动时将会增加。
   PWMClearDeadBand();
   PWMSetFrequency();
   PWMGenPeriodSet(PWM0_BASE, PWM_GEN_0, PWM_CLOCK / 1000);
   PWMGenPeriodSet(PWM0_BASE, PWM_GEN_1, PWM_CLOCK / 1000);
   PWMGenPeriodSet(PWM0_BASE, PWM_GEN_2, PWM_CLOCK / 1000);
   PWMUpdateDutyCycle();
怎么也不会有近100%的PWM产生。这个代码我不知道官方测试过没。。。。都不知道该不该继续看下去
