如何在RAM中调试程序
// LM3S.icf - Linker configuration file for timers.
// Copyright (c) 2005-2008 Luminary Micro, Inc.  All rights reserved.
// Software License Agreement
// Luminary Micro, Inc. (LMI) is supplying this software for use solely and
// exclusively on LMI's microcontroller products.
// The software is owned by LMI and/or its suppliers, and is protected under
// applicable copyright laws.  All rights are reserved.  You may not combine
// this software with "viral" open-source software in order to form a larger
// program.  Any use in violation of the foregoing restrictions may subject
// the user to criminal sanctions under applicable laws, as well as to civil
// liability for the breach of the terms and conditions of this license.
// THIS SOFTWARE IS PROVIDED "AS IS".  NO WARRANTIES, WHETHER EXPRESS, IMPLIED
// OR STATUTORY, INCLUDING, BUT NOT LIMITED TO, IMPLIED WARRANTIES OF
// MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE.
// LMI SHALL NOT, IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR
// CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.
// This is part of revision 2752 of the Stellaris Peripheral Driver Library.
// Define a memory region that covers the entire 4 GB addressible space of the
// processor.
define memory mem with size = 4G;
// Define a region for the on-chip flash.
//这里是片上flash的大小,256k
define region FLASH = mem:[from 0x00000000 to 0x0003FFFF];
//这里是片上ram的大小,96k
// Define a region for the on-chip SRAM.
define region SRAM = mem:[from 0x20000000 to 0x20017fff];
// Define a block for the heap.  The size should be set to something other
// than zero if things in the C library that require the heap are used.
define block HEAP with alignment = 8, size = 0x00000000 { };
// Indicate that the read/write values should be initialized by copying from
// flash.
initialize by copy { readwrite };
// Indicate that the noinit values should be left alone.  This includes the
// stack, which if initialized will destroy the return address from the
// initialization code, causing the processor to branch to zero and fault.
do not initialize { section .noinit };
// Place the interrupt vectors at the start of flash.
//place at start of FLASH { readonly section .intvec };
//  将中断向量表放在SRAM的起始地址处
place at address mem:0x20000000 { readonly section .intvec};
// Place the remainder of the read-only items into flash.
//place in FLASH { readonly };
place in mem:[from 0x20000000 to 0x2000ee00] {readonly};
// Place all read/write items into SRAM.
//place in SRAM { readwrite, block HEAP };
place in mem:[from 0x2000ee01 to 0x20017FFF]  { readwrite, block HEAP };
