开发环境:IAR5.5
MCU : 3S9B90 G3版本
硬件平台:EK-LM3S9B90-B
使用此评估板一段时间后,下载代码时出现flash校验告警:
Sun Oct 09 15:56:35 2011: Warning:
Verify error at address 0x20000001, target byte: 0x00, byte in file: 0x80
Verify error at address 0x20000003, target byte: 0x00, byte in file: 0x20
Verify error at address 0x20000004, target byte: 0x00, byte in file: 0x79
Verify error at address 0x20000005, target byte: 0x00, byte in file: 0x01
Verify error at address 0x20000007, target byte: 0x00, byte in file: 0x20
Verify error at address 0x20000081, target byte: 0x00, byte in file: 0x20
Verify error at address 0x20000082, target byte: 0x00, byte in file: 0x70
Verify error at address 0x20000083, target byte: 0x00, byte in file: 0x47
Verify error at address 0x20000084, target byte: 0x00, byte in file: 0x10
Verify error at address 0x20000085, target byte: 0x00, byte in file: 0xB5
Verify error at address 0x20000086, target byte: 0x00, byte in file: 0x08
Verify error at address 0x20000087, target byte: 0x00, byte in file: 0x18
Verify error at address 0x20000088, target byte: 0x00, byte in file: 0x10
Verify error at address 0x20000089, target byte: 0x00, byte in file: 0xF0
Verify error at address 0x2000008A, target byte: 0x00, byte in file: 0x03
Verify error at address 0x2000008B, target byte: 0x00, byte in file: 0x0F
Verify error at address 0x2000008C, target byte: 0x00, byte in file: 0x18
Verify error at address 0x2000008D, target byte: 0x00, byte in file: 0xD1
Verify error at address 0x2000008E, target byte: 0x00, byte in file: 0x12
Verify error at address 0x2000008F, target byte: 0x00, byte in file: 0xF0
Verify error at address 0x20000090, target byte: 0x00, byte in file: 0x03
Verify error at address 0x20000091, target byte: 0x00, byte in file: 0x0F
Verify error at address 0x20000092, target byte: 0x00, byte in file: 0x15
Verify error at address 0x20000093, target byte: 0x00, byte in file: 0xD1
Verify error at address 0x20000094, target byte: 0x00, byte in file: 0x17
Verify error at address 0x20000095, target byte: 0x00, byte in file: 0x49
Verify error at address 0x20000096, target byte: 0x00, byte in file: 0x01
Verify error at address 0x20000097, target byte: 0x00, byte in file: 0x24
Verify error at address 0x20000098, target byte: 0x00, byte in file: 0x4C
Verify error at address 0x20000099, target byte: 0x00, byte in file: 0x61
Verify error at address 0x2000009B, target byte: 0x00, byte in file: 0x2A
Verify error at address 0x2000009C, target byte: 0x00, byte in file: 0x0B
Verify error at address 0x2000009D, target byte: 0x00, byte in file: 0xE0
Verify error at address 0x2000009E, target byte: 0x00, byte in file: 0x08
Verify error at address 0x2000009F, target byte: 0x00, byte in file: 0x60
Verify error at address 0x200000A0, target byte: 0x00, byte in file: 0x1C
Verify error at address 0x200000A1, target byte: 0x00, byte in file: 0x68
Verify error at address 0x200000A2, target byte: 0x00, byte in file: 0x4C
Verify error at address 0x200000A3, target byte: 0x00, byte in file: 0x60
Verify error at address 0x200000A4, target byte: 0x00, byte in file: 0x07
Verify error at address 0x200000A5, target byte: 0x00, byte in file: 0x4C
Verify error at address 0x200000A6, target byte: 0x00, byte in file: 0x8C
Verify error at address 0x200000A7, target byte: 0x00, byte in file: 0x60
Verify error at address 0x200000A8, target byte: 0x00, byte in file: 0x8C
Verify error at address 0x200000A9, target byte: 0x00, byte in file: 0x68
Verify error at address 0x200000AA, target byte: 0x00, byte in file: 0x14
Verify error at address 0x200000AB, target byte: 0x00, byte in file: 0xF0
Verify error at address 0x200000AC, target byte: 0x00, byte in file: 0x01
Verify error at address 0x200000AD, target byte: 0x00, byte in file: 0x0F
Verify error at address 0x200000AE, target byte: 0x00, byte in file: 0xFB
Verify error at address 0x200000AF, target byte: 0x00, byte in file: 0xD1
Verify error at address 0x200000B0, target byte: 0x00, byte in file: 0x1B
Verify error at address 0x200000B1, target byte: 0x00, byte in file: 0x1D
Verify error at address 0x200000B3, target byte: 0x00, byte in file: 0x1D
Verify error at address 0x200000B4, target byte: 0x00, byte in file: 0x12
Verify error at address 0x200000B5, target byte: 0x00, byte in file: 0x1F
Verify error at address 0x200000B6, target byte: 0x00, byte in file: 0xF2
Verify error at address 0x200000B7, target byte: 0x00, byte in file: 0xD1
Verify error at address 0x200000B8, target byte: 0x00, byte in file: 0xC8
Verify error at address 0x200000B9, target byte: 0x00, byte in file: 0x68
Verify error at address 0x200000BA, target byte: 0x00, byte in file: 0x10
Verify error at address 0x200000BB, target byte: 0x00, byte in file: 0xF0
Verify error at address 0x200000BC, target byte: 0x00, byte in file: 0x01
Verify error at address 0x200000BF, target byte: 0x00, byte in file: 0xD0
Verify error at address 0x200000C0, target byte: 0x00, byte in file: 0x01
Verify error at address 0x200000C1, target byte: 0x00, byte in file: 0x20
Verify error at address 0x200000C2, target byte: 0x00, byte in file: 0x10
Verify error at address 0x200000C3, target byte: 0x00, byte in file: 0xBD
Verify error at address 0x200000C4, target byte: 0x00, byte in file: 0x01
Verify error at address 0x200000C6, target byte: 0x00, byte in file: 0x42
Verify error at address 0x200000C7, target byte: 0x00, byte in file: 0xA4
Verify error at address 0x200000C8, target byte: 0x00, byte in file: 0x81
Verify error at address 0x200000C9, target byte: 0x00, byte in file: 0x05
Verify error at address 0x200000CA, target byte: 0x00, byte in file: 0x01
Verify error at address 0x200000CB, target byte: 0x00, byte in file: 0xD0
Verify error at address 0x200000CC, target byte: 0x00, byte in file: 0x01
Verify error at address 0x200000CD, target byte: 0x00, byte in file: 0x20
Verify error at address 0x200000CE, target byte: 0x00, byte in file: 0x70
Verify error at address 0x200000CF, target byte: 0x00, byte in file: 0x47
Verify error at address 0x200000D0, target byte: 0x00, byte in file: 0x08
Verify error at address 0x200000D1, target byte: 0x00, byte in file: 0x49
Verify error at address 0x200000D2, target byte: 0x00, byte in file: 0x01
Verify error at address 0x200000D3, target byte: 0x00, byte in file: 0x22
Verify error at address 0x200000D4, target byte: 0x00, byte in file: 0x4A
Verify error at address 0x200000D5, target byte: 0x00, byte in file: 0x61
Verify error at address 0x200000D6, target byte: 0x00, byte in file: 0x08
Verify error at address 0x200000D7, target byte: 0x00, byte in file: 0x60
Verify error at address 0x200000D8, target byte: 0x00, byte in file: 0x05
Verify error at address 0x200000D9, target byte: 0x00, byte in file: 0x48
Verify error at address 0x200000DA, target byte: 0x00, byte in file: 0x88
Verify error at address 0x200000DB, target byte: 0x00, byte in file: 0x60
Verify error at address 0x200000DC, target byte: 0x00, byte in file: 0x88
Verify error at address 0x200000DD, target byte: 0x00, byte in file: 0x68
Verify error at address 0x200000DE, target byte: 0x00, byte in file: 0x10
Verify error at address 0x200000DF, target byte: 0x00, byte in file: 0xF0
Verify error at address 0x200000E0, target byte: 0x00, byte in file: 0x02
Verify error at address 0x200000E1, target byte: 0x00, byte in file: 0x0F
Verify error at address 0x200000E2, target byte: 0x00, byte in file: 0xFB
Verify error at address 0x200000E3, target byte: 0x00, byte in file: 0xD1
Verify error at address 0x200000E4, target byte: 0x00, byte in file: 0xC8
Verify error at address 0x200000E5, target byte: 0x00, byte in file: 0x68
Verify error at address 0x200000E6, target byte: 0x00, byte in file: 0x10
Verify error at address 0x200000E7, target byte: 0x00, byte in file: 0xF0
Verify error at address 0x200000E8, target byte: 0x00, byte in file: 0x01
Verify error at address 0x200000EB, target byte: 0x00, byte in file: 0xD0
Verify error at address 0x200000EC, target byte: 0x00, byte in file: 0x01
Verify error at address 0x200000ED, target byte: 0x00, byte in file: 0x20
Verify error at address 0x200000EE, target byte: 0x00, byte in file: 0x70
Verify error at address 0x200000EF, target byte: 0x00, byte in file: 0x47
Verify error at address 0x200000F0, target byte: 0x00, byte in file: 0x02
Verify error at address 0x200000F2, target byte: 0x00, byte in file: 0x42
Verify error at address 0x200000F3, target byte: 0x00, byte in file: 0xA4
Verify error at address 0x200000F5, target byte: 0x00, byte in file: 0xD0
Verify error at address 0x200000F6, target byte: 0x00, byte in file: 0x0F
Verify error at address 0x200000F7, target byte: 0x00, byte in file: 0x40
Verify error at address 0x200000F8, target byte: 0x00, byte in file: 0x10
Verify error at address 0x200000F9, target byte: 0x00, byte in file: 0xB5
Verify error at address 0x200000FA, target byte: 0x00, byte in file: 0x1D
Verify error at address 0x200000FB, target byte: 0x00, byte in file: 0x4C
Verify error at address 0x200000FC, target byte: 0x00, byte in file: 0x06
Verify error at address 0x200000FD, target byte: 0x00, byte in file: 0x49
Verify error at address 0x200000FE, target byte: 0x00, byte in file: 0x07
Verify error at address 0x200000FF, target byte: 0x00, byte in file: 0x48
Verify error at address 0x20000101, target byte: 0x00, byte in file: 0x68
Verify error at address 0x20000102, target byte: 0x00, byte in file: 0x03
Verify error at address 0x20000103, target byte: 0x00, byte in file: 0xB4
Verify error at address 0x20000104, target byte: 0x00, byte in file: 0x63
Verify error at address 0x20000105, target byte: 0x00, byte in file: 0x68
Verify error at address 0x20000106, target byte: 0x00, byte in file: 0xA2
Verify error at address 0x20000107, target byte: 0x00, byte in file: 0x68
Verify error at address 0x20000108, target byte: 0x00, byte in file: 0x21
Verify error at address 0x20000109, target byte: 0x00, byte in file: 0x69
Verify error at address 0x2000010A, target byte: 0x00, byte in file: 0x20
Verify error at address 0x2000010B, target byte: 0x00, byte in file: 0x68
Verify error at address 0x2000010C, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x2000010D, target byte: 0x00, byte in file: 0xF7
Verify error at address 0x2000010E, target byte: 0x00, byte in file: 0xB8
Verify error at address 0x2000010F, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x20000110, target byte: 0x00, byte in file: 0x02
Verify error at address 0x20000111, target byte: 0x00, byte in file: 0xB0
Verify error at address 0x20000112, target byte: 0x00, byte in file: 0x60
Verify error at address 0x20000113, target byte: 0x00, byte in file: 0x60
Verify error at address 0x20000114, target byte: 0x00, byte in file: 0x10
Verify error at address 0x20000115, target byte: 0x00, byte in file: 0xBD
Verify error at address 0x20000117, target byte: 0x00, byte in file: 0xBF
Verify error at address 0x20000118, target byte: 0x00, byte in file: 0xEC
Verify error at address 0x20000119, target byte: 0x00, byte in file: 0x7E
Verify error at address 0x2000011B, target byte: 0x00, byte in file: 0x20
Verify error at address 0x2000011C, target byte: 0x00, byte in file: 0xA8
Verify error at address 0x2000011D, target byte: 0x00, byte in file: 0x7E
Verify error at address 0x2000011F, target byte: 0x00, byte in file: 0x20
Verify error at address 0x20000120, target byte: 0x00, byte in file: 0x10
Verify error at address 0x20000121, target byte: 0x00, byte in file: 0xB5
Verify error at address 0x20000122, target byte: 0x00, byte in file: 0x13
Verify error at address 0x20000123, target byte: 0x00, byte in file: 0x4C
Verify error at address 0x20000125, target byte: 0x00, byte in file: 0xF0
Verify error at address 0x20000126, target byte: 0x00, byte in file: 0x1E
Verify error at address 0x20000127, target byte: 0x00, byte in file: 0xF8
Verify error at address 0x20000128, target byte: 0x00, byte in file: 0x60
Verify error at address 0x20000129, target byte: 0x00, byte in file: 0x60
Verify error at address 0x2000012A, target byte: 0x00, byte in file: 0x10
Verify error at address 0x2000012B, target byte: 0x00, byte in file: 0xBD
Verify error at address 0x2000012C, target byte: 0x00, byte in file: 0x70
Verify error at address 0x2000012D, target byte: 0x00, byte in file: 0xB5
Verify error at address 0x2000012E, target byte: 0x00, byte in file: 0x10
Verify error at address 0x2000012F, target byte: 0x00, byte in file: 0x4C
Verify error at address 0x20000130, target byte: 0x00, byte in file: 0x21
Verify error at address 0x20000131, target byte: 0x00, byte in file: 0x69
Verify error at address 0x20000132, target byte: 0x00, byte in file: 0x69
Verify error at address 0x20000133, target byte: 0x00, byte in file: 0xB9
Verify error at address 0x20000134, target byte: 0x00, byte in file: 0xE5
Verify error at address 0x20000135, target byte: 0x00, byte in file: 0x68
Verify error at address 0x20000137, target byte: 0x00, byte in file: 0x26
Verify error at address 0x20000138, target byte: 0x00, byte in file: 0x60
Verify error at address 0x20000139, target byte: 0x00, byte in file: 0x68
Verify error at address 0x2000013A, target byte: 0x00, byte in file: 0x86
Verify error at address 0x2000013B, target byte: 0x00, byte in file: 0x42
Verify error at address 0x2000013C, target byte: 0x00, byte in file: 0x10
Verify error at address 0x2000013D, target byte: 0x00, byte in file: 0xD2
Verify error at address 0x2000013E, target byte: 0x00, byte in file: 0x69
Verify error at address 0x2000013F, target byte: 0x00, byte in file: 0x68
Verify error at address 0x20000140, target byte: 0x00, byte in file: 0x28
Verify error at address 0x20000141, target byte: 0x00, byte in file: 0x68
Verify error at address 0x20000142, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x20000143, target byte: 0x00, byte in file: 0xF7
Verify error at address 0x20000144, target byte: 0x00, byte in file: 0xC1
Verify error at address 0x20000145, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x20000146, target byte: 0x00, byte in file: 0x01
Verify error at address 0x20000148, target byte: 0x00, byte in file: 0x0A
Verify error at address 0x20000149, target byte: 0x00, byte in file: 0xD1
Verify error at address 0x2000014A, target byte: 0x00, byte in file: 0x08
Verify error at address 0x2000014B, target byte: 0x00, byte in file: 0x35
Verify error at address 0x2000014C, target byte: 0x00, byte in file: 0x76
Verify error at address 0x2000014D, target byte: 0x00, byte in file: 0x1C
Verify error at address 0x2000014E, target byte: 0x00, byte in file: 0xF3
Verify error at address 0x2000014F, target byte: 0x00, byte in file: 0xE7
Verify error at address 0x20000150, target byte: 0x00, byte in file: 0x20
Verify error at address 0x20000151, target byte: 0x00, byte in file: 0x68
Verify error at address 0x20000152, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x20000153, target byte: 0x00, byte in file: 0xF7
Verify error at address 0x20000154, target byte: 0x00, byte in file: 0xB9
Sun Oct 09 15:56:35 2011: Warning: Too many verify errors, only the first 200 are displayed
尝试过解锁,没有起作用。请问是什么原因造成的?有什么解决办法吗?
