关于cortex-m4 UART的技术问题请教
UART有8个串口,UART0调试正常(有范例)但配置在UART1/2/3/4/5/6/7都不能正常通讯,不知道是怎么回事。
  • 怎么调试的?
    把你相关代码发上来帮你看看。
  • 不能通讯,你是采用中断还是轮询?
    出现的什么错误?
    板子是否支持?
    GPIO口有否复用?
    #include "inc/hw_ints.h"
    #include "inc/hw_memmap.h"
    #include "inc/hw_types.h"
    #include "driverlib/debug.h"
    #include "driverlib/fpu.h"
    #include "driverlib/gpio.h"
    #include "driverlib/interrupt.h"
    #include "driverlib/sysctl.h"
    #include "driverlib/uart.h"
    #include "driverlib/rom.h"
    #include "grlib/grlib.h"
    #include "drivers/cfal96x64x16.h"
    //! \addtogroup example_list
    //! <h1>UART Echo (uart_echo)</h1>
    //! This example application utilizes the UART to echo text.  The first UART
    //! (connected to the USB debug virtual serial port on the evaluation board)
    //! will be configured in 115,200 baud, 8-n-1 mode.  All characters received on
    //! the UART are transmitted back to the UART.
    // The error routine that is called if the driver library encounters an error.
    #ifdef DEBUG
    void
    __error__(char *pcFilename, unsigned long ulLine)
    #endif
    // The UART interrupt handler.
    void
    UARTIntHandler(void)
       unsigned long ulStatus;
       // Get the interrrupt status.
       ulStatus = ROM_UARTIntStatus(UART3_BASE, true);
       // Clear the asserted interrupts.
       ROM_UARTIntClear(UART3_BASE, ulStatus);
       // Loop while there are characters in the receive FIFO.
       while(ROM_UARTCharsAvail(UART3_BASE))
           // Read the next character from the UART and write it back to the UART.
           ROM_UARTCharPutNonBlocking(UART3_BASE,
                                      ROM_UARTCharGetNonBlocking(UART3_BASE));
    // Send a string to the UART.
    void
    UARTSend(const unsigned char *pucBuffer, unsigned long ulCount)
       // Loop while there are more characters to send.
       while(ulCount--)
           // Write the next character to the UART.
           ROM_UARTCharPutNonBlocking(UART3_BASE, *pucBuffer++);
    // This example demonstrates how to send a string of data to the UART.
    int
    main(void)
       tRectangle sRect;
       tContext sContext;
       // The FPU should be enabled because some compilers will use floating-
       // point registers, even for non-floating-point code.  If the FPU is not
       // enabled this will cause a fault.  This also ensures that floating-
       // point operations could be added to this application and would work
       // correctly and use the hardware floating-point unit.  Finally, lazy
       // stacking is enabled for interrupt handlers.  This allows floating-
       // point instructions to be used within interrupt handlers, but at the
       // expense of extra stack usage.
       FPUEnable();
       FPULazyStackingEnable();
       // Set the clocking to run directly from the crystal.
       ROM_SysCtlClockSet(SYSCTL_SYSDIV_1 | SYSCTL_USE_OSC | SYSCTL_OSC_MAIN |
                          SYSCTL_XTAL_16MHZ);
       // Initialize the display driver.
       CFAL96x64x16Init();
       // Initialize the graphics context.
       GrContextInit(&sContext, &g_sCFAL96x64x16);
       // Fill the top part of the screen with blue to create the banner.
       sRect.sXMin = 0;
       sRect.sYMin = 0;
       sRect.sXMax = GrContextDpyWidthGet(&sContext) - 1;
       sRect.sYMax = 9;
       GrContextForegroundSet(&sContext, ClrDarkBlue);
       GrRectFill(&sContext, &sRect);
       // Change foreground for white text.
       GrContextForegroundSet(&sContext, ClrWhite);
       // Put the application name in the middle of the banner.
       GrContextFontSet(&sContext, g_pFontFixed6x8);
       GrStringDrawCentered(&sContext, "OURS-uart3-echo", -1,
                            GrContextDpyWidthGet(&sContext) / 2, 4, 0);
       // Initialize the display and write some instructions.
       GrStringDrawCentered(&sContext, "Connect a", -1,
                            GrContextDpyWidthGet(&sContext) / 2, 20, false);
       GrStringDrawCentered(&sContext, "terminal", -1,
                            GrContextDpyWidthGet(&sContext) / 2, 30, false);
       GrStringDrawCentered(&sContext, "to UART3.", -1,
                            GrContextDpyWidthGet(&sContext) / 2, 40, false);
       GrStringDrawCentered(&sContext, "115200,N,8,1", -1,
                            GrContextDpyWidthGet(&sContext) / 2, 50, false);
       // Enable the peripherals used by this example.
       ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOC);
       ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_UART3);
       // Enable processor interrupts.
       ROM_IntMasterEnable();
       // Set GPIO G4 and G5 as UART pins.
       ROM_GPIOPinTypeUART(GPIO_PORTC_BASE, GPIO_PIN_6 | GPIO_PIN_7);
       // Configure the UART for 115,200, 8-N-1 operation.
       ROM_UARTConfigSetExpClk(UART3_BASE, ROM_SysCtlClockGet(), 115200,
                               (UART_CONFIG_WLEN_8 | UART_CONFIG_STOP_ONE |
                                UART_CONFIG_PAR_NONE));
       // Enable the UART interrupt.
       ROM_IntEnable(INT_UART3);
       ROM_UARTIntEnable(UART3_BASE, UART_INT_RX | UART_INT_RT);
       // Prompt for text to be entered.
       UARTSend((unsigned char *)"Please Enter: ", 16);
       // Loop forever echoing data through the UART.
       while(1)
  • 能进得了中断吗? 建议你看看寄存器对比下器件手册,看看UART3是否在正常工作
  •     因为UART0的引脚是默认 UART0模式,但是其他的UART单元所使用的引脚需要通过硬件配置下才能使用。可以添加以下两行代码试下:
       GPIOPinConfigure(GPIO_PC4_U1RX);
    GPIOPinConfigure(GPIO_PC5_U1TX);
  • PC6和PC7管脚是复用的,所以你需要配置GPIO pin脚的功能
    GPIOPinConfigure(GPIO_PC6_U3RX);
    GPIOPinConfigure(GPIO_PC7_U3TX);
  • 好的,我试试去,谢谢!
  •    ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOC);
    按照您的方法配置了,现在是目标板能发送信号,但接收不了(即:在目标板上复位时,在PC机的串口调试工具里能显示:"please enter:",但PC机端的串口调试工具里点击发送却没有任何反应)
  • 检查一下Startup.c文件中
    串口3的中断函数有没有正确注册!怀疑是这个问题!!
    或者你在中断函数中设置断点,看看PC上发送文字能否进中断处理函数。
  • OK,太好了,非常感谢您的支持!
  • 我配置了pin脚还是无法通信,板子reset调试工具什么都无法显示,相同代码配置uart0可以显示。我的代码如下:
    int main(void)
    char cThisChar;
    //SysCtlClockSet(SYSCTL_SYSDIV_4|SYSCTL_USE_PLL|SYSCTL_XTAL_16MHZ|SYSCTL_OSC_MAIN);
    SysCtlClockSet(SYSCTL_SYSDIV_1|SYSCTL_USE_OSC|SYSCTL_OSC_MAIN|SYSCTL_XTAL_16MHZ);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_UART1);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOB);
    GPIOPinConfigure(GPIO_PB0_U1RX);
    GPIOPinConfigure(GPIO_PB1_U1TX);
    GPIOPinTypeUART(GPIO_PORTB_BASE,GPIO_PIN_0|GPIO_PIN_1);
    UARTConfigSetExpClk(UART1_BASE,SysCtlClockGet(),115200,(UART_CONFIG_WLEN_8|UART_CONFIG_STOP_ONE|UART_CONFIG_PAR_NONE));
    UARTCharPut(UART1_BASE,'!');
    do
    cThisChar=UARTCharGet(UART1_BASE);
    UARTCharPut(UART1_BASE,cThisChar);
    }while ((cThisChar!='\n')&&(cThisChar!='\r'));
    return(0);
