如何利用NI LabVIEW图形化编程工具开发DK-LM3S9B96系统
Other Parts Discussed in Thread: LM3S8962
在TI Stellaris系列微处理器手册(版本:ZHCB012A)第125页关于Stellaris LM3S9B96微处理器开发套件介绍中写道:“...对于采用National Instruments公司嵌入式LabVIEW等工具编程编程的系统而言,LM3S9B96开发板不失为一套非常实用的开发工具...”
以我的使用经验,NI 的LabVIEW for ARM模块能支持LM3S8962开发板的图形化编程,但好像不支持这块9B96开发板,请TI的工程师解释一下,如何让LabVIEW开发环境能配合这块9B96开发板使用,谢谢!
  • 以下是关于labview 和Stellaris配合的相关内容请参考。
    1> 目前labview支持的Stellaris只有LM3S8962
    2> 要使EK-LM3S8962在labview下工作,要满足一下条件
         2.1> A LabView for ARM license
         2.2> Keil license
         2.3> uLink2
    3> 若要labview支持LM3S9B96,请参考以下NI给的移植说明
      To port LabVIEW Embedded Module for ARM Microcontrollers to a Texas Instruments Stellaris Microcontroller use the following instructions first to create your port:
         3.1> Create a new ARM Project in LabVIEW.
         3.2>When asked to select a target type choose Other.
         3.3>  Select Luminary Micro LM3S8962 Stellaris for the processor.  This will load a generic template.
         3.4> In the project right-click on the LM3Sxxxx target and select the target processor to be Luminary Micro LM3S8962 Stellaris.  Now you have a generic target for Luminary Micro parts.
        3.5> If you are using Elemental I/O right-click on the LM3Sxxxx target and choose select elemental I/O...  Select the LM3S8962 device.
        3.6> Create an application build specification if there is not one already.
        3.7> Right-click on the Application under Build Specifications and select Properties.
        3.8> Go to the Advanced Compiler section.
        3.9> Add a Preprocesser symbol of:  LM3S_PART_DEFINED PART_LM3Sxxxx
                   Where xxxx is the model number that you want to use.
    Note: The uVision project created for this target will assume a flash memory size of 256K and 64K of RAM (as configured for the LM3S8962 target). If the memory configuration for your microcontroller is different, edit your uVision project. If the Texas Instruments Stellaris Microcontroller that you are using is newer than the LM3S8962, you might need to upddate software support installed with LabVIEW. To update the software follow the instructions in KnowledgeBase 4YBA2IBN: Error: #20: Identifier is Undefined when Compiling for Texas Instruments (Formerly Luminary Micro) Stellaris
  • 谢谢Winston的回复,请问你的这个资料的来源是哪里?这个资料给了我一个提示,但还不够详细。
