求助 关于ARM M3 中断问题
#include "hw_memmap.h"
#include "hw_ints.h"
#include "hw_nvic.h"
#include "hw_types.h"
#include "interrupt.h"
#include "sysctl.h"
#include "gpio.h"
#define LED3 GPIO_PIN_6
#define KEY3 GPIO_PIN_4
#define PINS    GPIO_PIN_5
void delay(int d)//延时函数
   for( ; d; --d);
int main()
 SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOB);
  GPIOPadConfigSet(GPIO_PORTB_BASE, PINS,
                    GPIO_STRENGTH_4MA,
                    GPIO_PIN_TYPE_STD);//配置管脚驱动,驱动电流2MA其实已足够
   GPIODirModeSet(GPIO_PORTB_BASE, PINS, GPIO_DIR_MODE_OUT);//设置管脚输出
GPIOPadConfigSet(GPIO_PORTB_BASE,KEY3,GPIO_STRENGTH_2MA,GPIO_PIN_TYPE_STD_WPU);
 GPIODirModeSet(GPIO_PORTB_BASE,KEY3,GPIO_DIR_MODE_IN);
 IntMasterEnable();
// IntEnable(INT_GPIOB);  //使能B端口中断
GPIOIntTypeSet(GPIO_PORTB_BASE,KEY3,GPIO_FALLING_EDGE); //下降沿中断
// GPIOPinIntEnable(GPIO_PORTB_BASE,KEY3);    //使能中断
   while(1) {
             GPIOPinWrite(GPIO_PORTB_BASE, PINS, PINS);//输出高电平
             delay(20000);//延时
             GPIOPinWrite(GPIO_PORTB_BASE, PINS, ~PINS);//输出低电平
             delay(20000);//延时
void GPIO_Port_B_ISR(void)
long IntStatus;
IntStatus=GPIOPinIntStatus(GPIO_PORTB_BASE,true);
GPIOPinIntClear(GPIO_PORTB_BASE,IntStatus);
if(IntStatus&KEY3)  {
  GPIOPinWrite(GPIO_PORTB_BASE,LED3,LED3^GPIOPinRead(GPIO_PORTB_BASE,LED3));
为什么要屏蔽这两个才能进入死循环 while(1)
如果不屏蔽的话死循环的点灯就不会执行  且中断也没反应。
不知道 是不是哪设置的不对啊!
是在PROTEUS仿真下试验的
  •  startup_ewarm.c 的配置如下
    // startup_ewarm.c - Startup code for use with IAR's Embedded Workbench,
    //                   version 5.
    // Copyright (c) 2006-2012 Texas Instruments Incorporated.  All rights reserved.
    // Software License Agreement
    // Texas Instruments (TI) is supplying this software for use solely and
    // exclusively on TI's microcontroller products. The software is owned by
    // TI and/or its suppliers, and is protected under applicable copyright
    // laws. You may not combine this software with "viral" open-source
    // software in order to form a larger program.
    // THIS SOFTWARE IS PROVIDED "AS IS" AND WITH ALL FAULTS.
    // NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT
    // NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
    // A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. TI SHALL NOT, UNDER ANY
    // CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR CONSEQUENTIAL
    // DAMAGES, FOR ANY REASON WHATSOEVER.
    // This is part of revision 8555 of the EK-LM3S811 Firmware Package.
    // Enable the IAR extensions for this source file.
    #pragma language=extended
    // Forward declaration of the default fault handlers.
    void ResetISR(void);
    static void NmiSR(void);
    static void FaultISR(void);
    static void IntDefaultHandler(void);
    void GPIO_Port_B_ISR(void);   //没加 extern 关键字
    // The entry point for the application startup code.
    extern void __iar_program_start(void);
    // Reserve space for the system stack.
    static unsigned long pulStack[64] @ ".noinit";
    // A union that describes the entries of the vector table.  The union is needed
    // since the first entry is the stack pointer and the remainder are function
    // pointers.
    typedef union
       void (*pfnHandler)(void);
       unsigned long ulPtr;
    uVectorEntry;
    // The vector table.  Note that the proper constructs must be placed on this to
    // ensure that it ends up at physical address 0x0000.0000.
    __root const uVectorEntry __vector_table[] @ ".intvec" =
       { .ulPtr = (unsigned long)pulStack + sizeof(pulStack) },
    //   __iar_program_start,                                        // The initial stack pointer
       ResetISR,                               // The reset handler
       NmiSR,                                  // The NMI handler
       FaultISR,                               // The hard fault handler
       IntDefaultHandler,                      // The MPU fault handler
       IntDefaultHandler,                      // The bus fault handler
       IntDefaultHandler,                      // The usage fault handler
       0,                                      // Reserved
       0,                                      // Reserved
       0,                                      // Reserved
       0,                                      // Reserved
       IntDefaultHandler,                      // SVCall handler
       IntDefaultHandler,                      // Debug monitor handler
       0,                                      // Reserved
       IntDefaultHandler,                      // The PendSV handler
       IntDefaultHandler,                      // The SysTick handler
       IntDefaultHandler,                      // GPIO Port A
       GPIO_Port_B_ISR,                      // GPIO Port B
       IntDefaultHandler,                      // GPIO Port C
       IntDefaultHandler,                      // GPIO Port D
       IntDefaultHandler,                      // GPIO Port E
       IntDefaultHandler,                      // UART0 Rx and Tx
       IntDefaultHandler,                      // UART1 Rx and Tx
       IntDefaultHandler,                      // SSI0 Rx and Tx
       IntDefaultHandler,                      // I2C0 Master and Slave
       IntDefaultHandler,                      // PWM Fault
       IntDefaultHandler,                      // PWM Generator 0
       IntDefaultHandler,                      // PWM Generator 1
       IntDefaultHandler,                      // PWM Generator 2
       IntDefaultHandler,                      // Quadrature Encoder 0
       IntDefaultHandler,                      // ADC Sequence 0
       IntDefaultHandler,                      // ADC Sequence 1
       IntDefaultHandler,                      // ADC Sequence 2
       IntDefaultHandler,                      // ADC Sequence 3
       IntDefaultHandler,                      // Watchdog timer
       IntDefaultHandler,                      // Timer 0 subtimer A
       IntDefaultHandler,                      // Timer 0 subtimer B
       IntDefaultHandler,                      // Timer 1 subtimer A
       IntDefaultHandler,                      // Timer 1 subtimer B
       IntDefaultHandler,                      // Timer 2 subtimer A
       IntDefaultHandler,                      // Timer 2 subtimer B
       IntDefaultHandler,                      // Analog Comparator 0
       IntDefaultHandler,                      // Analog Comparator 1
       IntDefaultHandler,                      // Analog Comparator 2
       IntDefaultHandler,                      // System Control (PLL, OSC, BO)
       IntDefaultHandler                       // FLASH Control
    // This is the code that gets called when the processor first starts execution
    // following a reset event.  Only the absolutely necessary set is performed,
    // after which the application supplied entry() routine is called.  Any fancy
    // actions (such as making decisions based on the reset cause register, and
    // resetting the bits in that register) are left solely in the hands of the
    // application.
    void
    ResetISR(void)
       // Call the application's entry point.
       __iar_program_start();
    // This is the code that gets called when the processor receives a NMI.  This
    // simply enters an infinite loop, preserving the system state for examination
    // by a debugger.
    static void
    NmiSR(void)
       // Enter an infinite loop.
       while(1)
    // This is the code that gets called when the processor receives a fault
    // interrupt.  This simply enters an infinite loop, preserving the system state
    // for examination by a debugger.
    static void
    FaultISR(void)
       while(1)
    // This is the code that gets called when the processor receives an unexpected
    static void
       // Go into an infinite loop.
       while(1)
  • fanhuaming fanhuaming :
    这是全部的代码?怎么连时钟设置都没有呀
  • 楼主检查下你中断向量表中中断的位置,看看是否正确,有可能跑到别的中断里去了
    可以不用startup代码,参考driverlib的例程写一个试试:
    int iVal;
    // Register the port-level interrupt handler. This handler is the
    // first level interrupt handler for all the pin interrupts.
    GPIOPortIntRegister(GPIO_PORTA_BASE, PortAIntHandler);
    // Initialize the GPIO pin configuration.
    // Set pins 2, 4, and 5 as input, SW controlled.
    GPIOPinTypeGPIOInput(GPIO_PORTA_BASE,
    GPIO_PIN_2 | GPIO_PIN_4 | GPIO_PIN_5);
    // Set pins 0 and 3 as output, SW controlled.
    GPIOPinTypeGPIOOutput(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_3);
    // Make pins 2 and 4 rising edge triggered interrupts.
    GPIOIntTypeSet(GPIO_PORTA_BASE, GPIO_PIN_2 | GPIO_PIN_4, GPIO_RISING_EDGE);
    // Make pin 5 high level triggered interrupts.
    GPIOIntTypeSet(GPIO_PORTA_BASE, GPIO_PIN_5, GPIO_HIGH_LEVEL);
    // Read some pins.
    iVal = GPIOPinRead(GPIO_PORTA_BASE,
    (GPIO_PIN_0 | GPIO_PIN_2 | GPIO_PIN_3 |
    GPIO_PIN_4 | GPIO_PIN_5));
    // Write some pins. Even though pins 2, 4, and 5 are specified, those
    // pins are unaffected by this write because they are configured as inputs.
    // At the end of this write, pin 0 will be a 0, and pin 3 will be a 1.
    GPIOPinWrite(GPIO_PORTA_BASE,
    GPIO_PIN_4 | GPIO_PIN_5),
    0xF8);
    // Enable the pin interrupts.
    GPIOPinIntEnable(GPIO_PORTA_BASE, GPIO_PIN_2 | GPIO_PIN_4 | GPIO_PIN_5);
  • 问题解决了,中断跟Backup of driverlib.a 也是有关系的。
    我用TI函数库中的D:\StellarisWare\driverlib\ewarm-cm3\Exe\driverlib-cm3.a这个文件一直进不了中断。。后来按照周立功的做法用IAR得新生成的Backup of driverlib.a 进中断可以。。
  • fanhuaming :
      这种软件仿真的很多东西不可信。。。
