Other Parts Discussed in Thread: CCSTUDIO
!SESSION 2014-07-31 08:53:13.202 -----------------------------------------------
eclipse.buildId=I20110613-1736
java.version=1.6.0_13
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_CN
Framework arguments: -product com.ti.ccstudio.branding.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product com.ti.ccstudio.branding.product
This is a continuation of log file C:\Users\TX\workspace_v5_1\.metadata\.bak_0.log
Created Time: 2014-07-31 08:53:16.875
!ENTRY org.eclipse.ui 4 4 2014-07-31 08:53:16.876
!MESSAGE The proxied handler for 'com.ti.ccstudio.debug.ui.commands.FindSymbol' could not be loaded
!ENTRY org.eclipse.ui 4 0 2014-07-31 08:53:16.877
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "com.ti.ccstudio.debug.ui" was unable to instantiate class "com.ti.ccstudio.debug.ui.commands.FindSymbol".
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:188)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.handlers.HandlerProxy.loadHandler(HandlerProxy.java:350)
at org.eclipse.ui.internal.handlers.HandlerProxy.isEnabled(HandlerProxy.java:319)
at org.eclipse.core.commands.Command.isEnabled(Command.java:833)
at org.eclipse.core.commands.Command.setHandler(Command.java:996)
at org.eclipse.ui.internal.handlers.HandlerAuthority.updateCommand(HandlerAuthority.java:459)
at org.eclipse.ui.internal.handlers.HandlerAuthority.activateHandler(HandlerAuthority.java:249)
at org.eclipse.ui.internal.handlers.HandlerService.activateHandler(HandlerService.java:120)
at org.eclipse.ui.internal.handlers.HandlerService.activateHandler(HandlerService.java:112)
at org.eclipse.ui.internal.handlers.HandlerPersistence.readHandlersFromRegistry(HandlerPersistence.java:313)
at org.eclipse.ui.internal.handlers.HandlerPersistence.reRead(HandlerPersistence.java:219)
at org.eclipse.ui.internal.handlers.HandlerPersistence.read(HandlerPersistence.java:167)
at org.eclipse.ui.internal.handlers.HandlerService.readRegistry(HandlerService.java:186)
at org.eclipse.ui.internal.handlers.HandlerServiceFactory.create(HandlerServiceFactory.java:61)
at org.eclipse.ui.internal.services.WorkbenchServiceRegistry.getService(WorkbenchServiceRegistry.java:103)
at org.eclipse.ui.internal.services.ServiceLocator.getService(ServiceLocator.java:174)
at org.eclipse.ui.internal.Workbench$49.runWithException(Workbench.java:1887)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Caused by: java.lang.NoClassDefFoundError: org/mozilla/xpcom/XPCOMException
at com.ti.ccstudio.debug.ui.commands.AbstractDebugHandler.<init>(AbstractDebugHandler.java:42)
at com.ti.ccstudio.debug.ui.commands.FindSymbol.<init>(FindSymbol.java:26)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184)
... 43 more
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle com.ti.ccstudio.debug.server (342).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:122)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:462)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:476)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(Unknown Source)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:345)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1207)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
at com.ti.ccstudio.core.CCStudioPlugin.getXPCOMRuntimeAdapter(CCStudioPlugin.java:85)
at com.ti.ccstudio.core.BaseCCSPlugin.initializeXPCOMRuntime(BaseCCSPlugin.java:29)
at com.ti.ccstudio.core.BaseCCSPlugin.internalStart(BaseCCSPlugin.java:20)
at com.ti.common.core.BaseTIPlugin.start(BaseTIPlugin.java:41)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:268)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:35)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:473)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at com.ti.ccstudio.ui.BaseCCSUIPlugin.internalStart(BaseCCSUIPlugin.java:21)
at com.ti.common.ui.BaseTIUIPlugin.start(BaseTIUIPlugin.java:41)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:191)
... 11 more
Caused by: org.osgi.framework.BundleException: Exception in com.ti.ccstudio.debug.server.DebugServerPlugin.start() of bundle com.ti.ccstudio.debug.server.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
... 76 more
Caused by: java.lang.UnsatisfiedLinkError: C:\TI\ccsv5\ccs_base\DebugServer\bin\win32\LibraryLoader.dll: 应用程序无法启动,因为应用程序的并行配置不正确。有关详细信息,请参阅应用程序事件日志,或使用命令行 sxstrace.exe 工具。
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(Unknown Source)
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.load0(Unknown Source)
at java.lang.System.load(Unknown Source)
at com.ti.debug.engine.xpcom.DLLPreLoader.load(DLLPreLoader.java:40)
at com.ti.debug.engine.xpcom.Runtime.preXPCOMInit(Runtime.java:244)
at com.ti.debug.engine.xpcom.Runtime.startBare(Runtime.java:191)
at com.ti.debug.engine.xpcom.Runtime.startBare(Runtime.java:148)
at com.ti.debug.engine.xpcom.Runtime.setRuntimeLocation(Runtime.java:67)
at com.ti.ccstudio.debug.server.internal.XPCOMRuntimeManager$1.run(XPCOMRuntimeManager.java:48)
at com.ti.ccstudio.debug.server.internal.XPCOMRuntimeManager.initializeXPCOMRuntime(XPCOMRuntimeManager.java:67)
at com.ti.ccstudio.debug.server.internal.XPCOMRuntimeAdapter.initializeRuntime(XPCOMRuntimeAdapter.java:21)
... 82 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2014-07-31 08:53:16.880
!MESSAGE Plug-in "com.ti.ccstudio.debug.ui" was unable to instantiate class "com.ti.ccstudio.debug.ui.commands.FindSymbol".
!STACK 0
... 11 more
... 76 more
... 82 more
!ENTRY org.eclipse.osgi 4 0 2014-07-31 08:53:17.599
!MESSAGE Application error
!STACK 1
at com.ti.ccstudio.debug.ui.profileClockStatus.ProfileClockStatusBar.createControl(ProfileClockStatusBar.java:36)
at org.eclipse.jface.action.ControlContribution.fill(ControlContribution.java:97)
at org.eclipse.ui.internal.menus.DynamicMenuContributionItem.fill(DynamicMenuContributionItem.java:210)
at org.eclipse.jface.action.ToolBarManager.update(ToolBarManager.java:353)
at org.eclipse.jface.action.ToolBarManager.createControl(ToolBarManager.java:111)
at org.eclipse.ui.internal.menus.TrimContributionManager$ToolBarTrimProxy.dock(TrimContributionManager.java:88)
at org.eclipse.ui.internal.menus.TrimContributionManager.update(TrimContributionManager.java:265)
at org.eclipse.ui.internal.WorkbenchWindow.updateLayoutDataForContents(WorkbenchWindow.java:3867)
at org.eclipse.ui.internal.WorkbenchWindow.setLayoutDataForContents(WorkbenchWindow.java:3878)
at org.eclipse.ui.internal.WorkbenchWindow.createDefaultContents(WorkbenchWindow.java:1150)
at org.eclipse.ui.internal.WorkbenchWindowConfigurer.createDefaultContents(WorkbenchWindowConfigurer.java:623)
at org.eclipse.ui.application.WorkbenchWindowAdvisor.createWindowContents(WorkbenchWindowAdvisor.java:300)
at org.eclipse.ui.internal.WorkbenchWindow.createContents(WorkbenchWindow.java:1036)
at org.eclipse.jface.window.Window.create(Window.java:431)
at org.eclipse.ui.internal.Workbench$22.runWithException(Workbench.java:1211)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$33.runWithException(Workbench.java:1595)
... 11 more
... 76 more
... 82 more
!ENTRY org.eclipse.core.jobs 2 2 2014-07-31 08:53:17.989
!MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.AbstractWorkingSetManager$10
!ENTRY org.eclipse.core.jobs 2 2 2014-07-31 08:53:17.990
!MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.ide.IDEWorkbenchActivityHelper$4
由于先前将某些关于Java的软件删除,但是不太想重装,请问有什么可以解决的方法么?
