CC3200 MQTT Client Broker斷線重線的問題
您好
原本的MQTT Client Example Code機制為,Broker斷線後,直接LOOP_FOREVER();結束,如下:
if(BROKER_DISCONNECTION == RecvQue.event){
lRetVal = sl_ExtLib_MqttClientCtxDelete(((connect_config*)(RecvQue.hndl))->clt_ctx);
                if(iConnBroker < 1)
                    // device not connected to any broker
                    goto end;
end:
    sl_ExtLib_MqttClientExit();
    UART_PRINT("\n\r Exiting the Application\n\r");     <------ I want to go back and try connection again from here
    LOOP_FOREVER();
如果想要做成無須重新開機,直接Reconnect的機制又會遇到卡在底層的問題,(底下紅色字體的部分)
在net_ops->open前面打印參數,和原先第一次使用的帶入參數是一樣的,看起來沒問題。
static i32 net_connect(struct client_ctx *cl_ctx)
        struct client_desc *client = CLIENT(cl_ctx);
        if(NEED_NET_CLOSE(cl_ctx))
                return MQP_ERR_NOT_DEF;
        if(NULL == net_ops)
                return MQP_ERR_NET_OPS;
        DBG_INFO("net_connect flag=%d ,%s,%d,%d\r\n",client->nwconn_opts | DEV_NETCONN_OPT_TCP,client->server_addr,client->port_number,client->nw_security);   //打印參數
        cl_ctx->net = net_ops->open(client->nwconn_opts | DEV_NETCONN_OPT_TCP,
                                    &client->nw_security);
        return (-1 == cl_ctx->net)? MQP_ERR_REMLSTN : 0;
請教一下,要如何達到Broker斷線,無須重開機的重連機制呢?
 謝謝
