Part Number: TAS2781
Other Parts Discussed in Thread: TAS2563
Hi support team
Regarding the TAS2781, due to the large volume of initialization data, using I2C is relatively slow. Therefore, I intend to use SPI for communication. However, the datasheet does not provide detailed information on the SPI communication protocol. Could you please clarify how read and write operations should be performed using SPI? For instance, when reading a register, is it necessary to send 0x01 before the register address to initiating the read operation?
Best Regards
keith
