After using I2S to acquire data from DAC and output data to ADC, I need to adjust the I2S clock to support the output and acquisition of signals with different sampling rates. However, simply configuring the 0x32 register doesn’t take effect. Could you please advise how to make this configuration effective?For example, change the I2S sampling rate from 48 kHz to 96 kHz.
