TLV320AIC3104 采集Mic音频周期性噪声问题
Other Parts Discussed in Thread: TLV320AIC3104, DM385
我们项目CPU为DM385,音频芯片为TLV320AIC3104
现在采集的音频信号除了背景的底噪以外还有周期性的 嗒嗒噪声,如下图
采样率:32000    16bit   2声道,附件是PCM数据
寄存器配置如下:其他寄存器为默认值。
           reg     val
                 1A     8F         Left AGC enable, Target gain = -5.5db, Attack time = 20ms, decay time = 500ms
                 1B     9A         Left AGC Maximum gain applicable = 32db
                 1C     38         Left AGC Hysteresis =1db, noise threshold = -84db
                 22     7F         Left AGC Noise detect debounce = 512ms, signal debounce = 32ms
                 1D     8F         Right AGC enable, Target gain = -5.5db, Attack = 20ms, decay = 500ms
                 1E     9A         Right AGC Maximum gain applicable = 32db
                 1F     38         Right AGC Hysteresis =1db, noise threshold = -84db
                 23     7F         Right AGC Noise detect debounce = 512ms, signal debounce = 32ms
