I2C debugging of PCM1795
Other Parts Discussed in Thread: PCM1795
Hi
       we encountered a problem when debugging PCM1795, do you have any reference code for PCM1795,PCM1795 I2C register address? Not seen in the specification.
  • I am so sorry that we don't have the reference code of PCM1795.
    About the I2C address, the datasheet P15 has described that the I2C slave address is 10011 ADR1 ADR0, and ADR0 , ADR1 could be configured by the hardware pin.
x 出现错误。请重试或与管理员联系。
