请问PCM9211支持HDMI 2.1 eARC 标准的帧的专用输入,是否同时支持HDMI音频输入。
  • 应该是支持的,请看这篇应用手册对ARC和eARC的介绍:www.ti.com/.../sbaa300a.pdf
    One of the most important functions the ARC enables is sending audio signal both “upstream” and “downstream” over a single connection. As a result, with eARC the full-resolution sound signals can be passed back and forth between your TV and audio systems with ease and without compromising sound quality.
