有的芯片我们希望选用有通过AEC-Q100认证的。目前有的芯片,名称上带后缀“-Q1”,但Datasheet中没有“AEC-Q100”字样,TI 是否有这样一份“声明文件”能提供,说明车规级芯片名称上有后缀名“-Q1”即达到AEC-Q100。
最好是PDF格式的文件。
Though we are informed that the IC named with subfix“-Q1” equals to "AEC-Q100 qulified", even no “AEC-Q100” literaly in datasheet. Could your side provied an statement document to declare that " a subfix '-Q1' symbolizes a IC(or a component) is AEC-Q100 complianced. The file in *.pdf format is preferred.
Right now my targer IC is TAS5760MQ1, the description I find is below:
Thanks
