Part Number: TLV320AIC3104
我们用该codec做通话的时候,发现免提那一路的底噪特别大,并且随着通话时间增加,底噪还会越来越大;
目前主要现象如下:
1. 通话的时候就会有比较大的底噪,之后随着通话时间增加,底噪越来越大声;中途一端mute后,底噪就会暂时变小,重新打开后过一段时间,又会变大了。
2. 断开mic(悬空)后也有底噪; 但将mic的正负用电阻接起来,对端就听不到底噪声。
3. 在HAL层打开mic和spk通路,录制音频,再用tinyplay播放,这时候的底噪却很小,几乎听不到。
4. 对mic静音后再打开,对端偶尔会听到电流音(滋滋)。
5. 切换到其他通路时底噪也很小,几乎听不到。
测试时是在语音房测试的,没有其他环境噪音。
麻烦帮忙看一下为什么会产生这么大的底噪呢?
附件中分别是原理图、寄存器、通路path、通话过程dump出来的音频:
原理图:
寄存器:
rk3326_m2g:/ # cat /sys/kernel/debug/regmap/1-0018/registers 00: 00 01: 00 02: 11 03: 10 04: 04 05: 00 06: 00 07: 0a 08: 00 09: 00 0a: 00 0b: 01 0c: 00 0d: 00 0e: 00 0f: 3c 10: 3c 11: ff 12: ff 13: 84 14: 78 15: f8 16: fc 17: 78 18: 80 19: 00 1a: 00 1b: fe 1c: 00 1d: 00 1e: fe 1f: 00 20: 18 21: 18 22: 00 23: 00 24: 00 25: c0 26: 00 27: 00 28: 00 29: 00 2a: 00 2b: 00 2c: 00 2d: 2f 2e: 2f 2f: 2f 30: 00 31: 00 32: 00 33: 85 34: 2f 35: 2f 36: af 37: 00 38: 00 39: 00 3a: 84 3b: 00 3c: 00 3d: 00 3e: 2f 3f: 2f 40: 2f 41: 85 42: 00 43: 00 44: 00 45: 2f 46: 2f 47: af 48: 84 49: 2f 4a: 2f 4b: af 4c: 2f 4d: 2f 4e: af 4f: 09 50: 2f 51: 49 52: 12 53: 00 54: d8 55: 26 56: 89 57: 00 58: 00 59: 92 5a: 2f 5b: 49 5c: 92 5d: 89 5e: 00 5f: 00 60: 00 61: 00 62: 00 63: 00 64: 00 65: 01 66: 02 67: 00 68: 00 69: 00 6a: 00 6b: 00 6c: 00 6d: 00
rk3326_m2g:/ # tinymix Mixer name: 'rockchip,tlv320aic3x-codec' Number of controls: 117 ctl type num name value 0 INT 1 Left Line Mixer Line2R Bypass Volume 118 1 INT 1 Right Line Mixer Line2L Bypass Volume 118 2 INT 1 Left HP Mixer Line2R Bypass Volume 118 3 INT 1 Right HP Mixer Line2L Bypass Volume 118 4 INT 1 Left HPCOM Mixer Line2R Bypass Volume 118 5 INT 1 Right HPCOM Mixer Line2L Bypass Volume 118 6 INT 2 Line Line2 Bypass Volume 71 71 7 INT 2 HP Line2 Bypass Volume 71 71 8 INT 2 HPCOM Line2 Bypass Volume 71 71 9 INT 2 Mono Line2 Bypass Volume 71 71 10 INT 2 Mono PGA Bypass Volume 71 71 11 INT 2 Mono DAC Playback Volume 71 71 12 BOOL 1 Mono Playback Switch On 13 INT 2 PCM Playback Volume 127 127 14 INT 1 Left Line Mixer PGAR Bypass Volume 30 15 INT 1 Left Line Mixer DACR1 Playback Volume 80 16 INT 1 Right Line Mixer PGAL Bypass Volume 118 17 INT 1 Right Line Mixer DACL1 Playback Volume 100 18 INT 1 Left HP Mixer PGAR Bypass Volume 118 19 INT 1 Left HP Mixer DACR1 Playback Volume 118 20 INT 1 Right HP Mixer PGAL Bypass Volume 118 21 INT 1 Right HP Mixer DACL1 Playback Volume 118 22 INT 1 Left HPCOM Mixer PGAR Bypass Volume 118 23 INT 1 Left HPCOM Mixer DACR1 Playback Volume 118 24 INT 1 Right HPCOM Mixer PGAL Bypass Volume 118 25 INT 1 Right HPCOM Mixer DACL1 Playback Volume 118 26 INT 2 Line PGA Bypass Volume 45 45 27 INT 2 Line DAC Playback Volume 100 100 28 INT 2 HP PGA Bypass Volume 71 71 29 INT 2 HP DAC Playback Volume 71 71 30 INT 2 HPCOM PGA Bypass Volume 71 71 31 INT 2 HPCOM DAC Playback Volume 71 71 32 BOOL 2 Line Playback Switch On On 33 BOOL 2 HP Playback Switch Off Off 34 BOOL 2 HPCOM Playback Switch Off Off 35 BOOL 2 AGC Switch Off Off 36 ENUM 1 Left AGC Target level -5.5dB 37 ENUM 1 Right AGC Target level -5.5dB 38 ENUM 1 Left AGC Attack time 8ms 39 ENUM 1 Right AGC Attack time 8ms 40 ENUM 1 Left AGC Decay time 100ms 41 ENUM 1 Right AGC Decay time 100ms 42 ENUM 1 Headset Handset Input Switch on 43 ENUM 1 Handset Spk En Switch on 44 ENUM 1 Handset Fix Spk Pop Switch on 45 ENUM 1 Handfree Spk En Switch on 46 BOOL 2 De-emphasis Switch Off Off 47 INT 2 PGA Capture Volume 60 60 48 BOOL 2 PGA Capture Switch On On 49 ENUM 2 ADC HPF Cut-off Disabled Disabled 50 ENUM 1 Output Driver Power-On time 0us 51 ENUM 1 Output Driver Ramp-up step 0ms 52 BYTE 128 ELD 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 53 INT 1 AUDIO MODE 0 54 INT 1 AUDIO MUTE 1 55 ENUM 1 Left DAC Mux DAC_L1 56 ENUM 1 Left HPCOM Mux differential of HPLOUT 57 ENUM 1 Right DAC Mux DAC_R1 58 ENUM 1 Right HPCOM Mux differential of HPROUT 59 ENUM 1 Left Line1L Mux differential 60 ENUM 1 Left Line1R Mux differential 61 ENUM 1 Right Line1L Mux differential 62 ENUM 1 Right Line1R Mux differential 63 BOOL 1 Left PGA Mixer Line1L Switch On 64 BOOL 1 Left PGA Mixer Line1R Switch Off 65 BOOL 1 Left PGA Mixer Line2L Switch Off 66 BOOL 1 Left PGA Mixer Mic3L Switch Off 67 BOOL 1 Left PGA Mixer Mic3R Switch Off 68 ENUM 1 Left Line2L Mux single-ended 69 BOOL 1 Right PGA Mixer Line1R Switch Off 70 BOOL 1 Right PGA Mixer Line1L Switch On 71 BOOL 1 Right PGA Mixer Line2R Switch Off 72 BOOL 1 Right PGA Mixer Mic3L Switch Off 73 BOOL 1 Right PGA Mixer Mic3R Switch Off 74 ENUM 1 Right Line2R Mux single-ended 75 BOOL 1 Left Line Mixer PGAL Bypass Switch Off 76 BOOL 1 Left Line Mixer DACL1 Switch Off 77 BOOL 1 Left Line Mixer PGAR Bypass Switch On 78 BOOL 1 Left Line Mixer DACR1 Switch Off 79 BOOL 1 Left Line Mixer Line2L Bypass Switch Off 80 BOOL 1 Left Line Mixer Line2R Bypass Switch Off 81 BOOL 1 Right Line Mixer PGAL Bypass Switch Off 82 BOOL 1 Right Line Mixer DACL1 Switch On 83 BOOL 1 Right Line Mixer PGAR Bypass Switch Off 84 BOOL 1 Right Line Mixer DACR1 Switch On 85 BOOL 1 Right Line Mixer Line2L Bypass Switch Off 86 BOOL 1 Right Line Mixer Line2R Bypass Switch Off 87 BOOL 1 Left HP Mixer PGAL Bypass Switch Off 88 BOOL 1 Left HP Mixer DACL1 Switch Off 89 BOOL 1 Left HP Mixer PGAR Bypass Switch Off 90 BOOL 1 Left HP Mixer DACR1 Switch Off 91 BOOL 1 Left HP Mixer Line2L Bypass Switch Off 92 BOOL 1 Left HP Mixer Line2R Bypass Switch Off 93 BOOL 1 Right HP Mixer PGAL Bypass Switch Off 94 BOOL 1 Right HP Mixer DACL1 Switch Off 95 BOOL 1 Right HP Mixer PGAR Bypass Switch Off 96 BOOL 1 Right HP Mixer DACR1 Switch Off 97 BOOL 1 Right HP Mixer Line2L Bypass Switch Off 98 BOOL 1 Right HP Mixer Line2R Bypass Switch Off 99 BOOL 1 Left HPCOM Mixer PGAL Bypass Switch Off 100 BOOL 1 Left HPCOM Mixer DACL1 Switch On 101 BOOL 1 Left HPCOM Mixer PGAR Bypass Switch Off 102 BOOL 1 Left HPCOM Mixer DACR1 Switch Off 103 BOOL 1 Left HPCOM Mixer Line2L Bypass Switch Off 104 BOOL 1 Left HPCOM Mixer Line2R Bypass Switch Off 105 BOOL 1 Right HPCOM Mixer PGAL Bypass Switch Off 106 BOOL 1 Right HPCOM Mixer DACL1 Switch Off 107 BOOL 1 Right HPCOM Mixer PGAR Bypass Switch Off 108 BOOL 1 Right HPCOM Mixer DACR1 Switch On 109 BOOL 1 Right HPCOM Mixer Line2L Bypass Switch Off 110 BOOL 1 Right HPCOM Mixer Line2R Bypass Switch Off 111 BOOL 1 Mono Mixer Line2L Bypass Switch Off 112 BOOL 1 Mono Mixer PGAL Bypass Switch Off 113 BOOL 1 Mono Mixer DACL1 Switch On 114 BOOL 1 Mono Mixer Line2R Bypass Switch Off 115 BOOL 1 Mono Mixer PGAR Bypass Switch Off 116 BOOL 1 Mono Mixer DACR1 Switch On
免提MIC和SPK通路:
SPK:
tinymix "PCM Playback Volume" 127
tinymix "Line DAC Playback Volume" 100
tinymix "Right Line Mixer DACL1 Playback Volume" 100
tinymix "Right Line Mixer DACL1 Switch" 1
tinymix "Right Line Mixer DACR1 Switch" 1
tinymix "Line Playback Switch" 1
tinymix "Handfree Spk En Switch" 1
MIC:
tinymix "PGA Capture Volume" 60
tinymix "Left PGA Mixer Line1R Switch" 0
tinymix "Right PGA Mixer Line1R Switch" 0
tinymix "Left PGA Mixer Line1L Switch" 1
tinymix "Right PGA Mixer Line1L Switch" 1
tinymix "PGA Capture Switch" 1
tinymix "Left Line1L Mux" 1
tinymix "Left Line1R Mux" 1
tinymix "Right Line1L Mux" 1
tinymix "Right Line1R Mux" 1
dump出来的音频:
本地MIC通话时录制的音频:
对端送过来的音频:
