Other Parts Discussed in Thread: TAS5711
请教各位:
现在TAS5711 设置成2.1 MODE时,在放左右声道测试时,发现只有一个声道有低单出来,而放另外一个声道时,低音就没有出来,请问寄存器里面该如何配置呢? 功放设置成2.1 AD模式。
请教各位:
Hi:
请参考如下配置:
1B 00 Oscillator Trim
03 A0 System Control Register 1
04 05 Serial Data Interface Register
06 00 Soft Mute Register
07 2A Master Volume Register (0xFF = Mute)
08 30 Channel 1 Volume
09 30 Channel 2 Volume
0A 30 Channel 3 Volume
0E 91 Micro Register
10 02 Modulation Limit
19 30 Shutdown Group Resister
1A 95 Split Capacitor Charge Period
1C 02 Back-end Error Register
20 02 01 77 72
21 00 00 42 03
25 01 01 32 45
11 AC Inter-Channel Delay Channel 1
12 54 Inter-Channel Delay Channel 2
13 00 Inter-Channel Delay Channel 3
14 00 Inter-Channel Delay Channel 4
17 00 Offset Register (Absolute Delay)
05 84 System Control Register 2 (active)
