Other Parts Discussed in Thread: TAS5825M, ,
There is a speaker measure funtion in the Tas5825M app
Can I also have this function in Tas5825pevm ?
在下面链接 TAS5825M Process Flows 中第18部分,有讲到这个功能需要用到 Learning Board 和 Learning Board App,如下截图,在 TAS5825P datasheet中并没有提到有speaker measure功能,因此,我认为这个功能是在Learning Board 和 Learning Board App中实现的;
TAS5825M Process Flows (Rev. A) https://www.ti.com/lit/an/slaa786a/slaa786a.pdf
我看到您将这个问题也发布在了E2E英文论坛,也可以等待看一下E2E工程师的回复:
