Part Number: TAS5822M
Hi Ti TEAM
Will change the BST pin of TAS5822 chip from 0.47uf to 2.2uF affect the chip
thanks!
Harrison
Hello, we recommend to use 0.47uF bootstrap capacitor to connect the appropriate output pin (OUT_X) to the bootstrap pin (BST_X).
You mean that you change the 0.47uF to 2.2uF and affect the chip, how does it affect? Generally, we used the recommended bootstrap capacitor or it would have OC risk.
