Hi,
The audio amp is not so similar with power supply, that doesn't have a clear definition of the peak power. The amp is possible to output larger power, but will clipping too much due to your supply restriction, it would be pointless. You could take 10% THD as maximum power, with 24V PVDD and 6ohm load, TAS5825 could give 2*52W for short time.
Thanks
