Part Number: TAS5558
Hello!
We are currently developing a digital audio system, initially using the TAS5624DDVEVM for decoding and power amplification. Currently, the interface section uses the Input-USB Board3 based on TAS1020B. However, the TAS1020B is now discontinued. Does your company have a replacement chip for the TAS1020B, or a solution to replace the Input-USB Board3?
Our goals are:
- The interface section can use your company's PurePath Studio or PurePath Console to configure the TAS5624DDVEVM.
- The interface section can receive USB audio from a PC.
- The interface section can receive S/PDIF signals and analog signals from a CD.
To achieve the above goals, please recommend the appropriate chips or solutions from your company.
Thank you very much!
Sun Hongbin February 23, 2024
