Part Number: TAS6511-Q1
Hi TI support team,
Thanks for your reading, totally I haveTWO questions:
1.we choose TAS6511 as the speaker IC. When the system goes up, run the register initialization as following:
but now we have a case that the speaker had no voice at all sometimes. when the case happened, we checked I2S input signals, it was no problem, and then we use I2C tool check the register values as below:
2.use this IC we hardly to pass 1140 standard test, does TAS6511 do ANY unlinear DSP to the voice signal? we asked local FAE, no respond at all so ask here.
Thank you for your support.
Xia
