Part Number: LMX2487
After the PLL is initialized, R5 and R0 are alternately configured at a frequency of 200Hz to implement 2FSK modulation of the frequency. It is found that the PLL may occasionally malfunction, resulting in failure to lock. Is the PLL's failure to lock related to the alternate configuration of R5 and R0?
