Part Number: LMX2595
Other Parts Discussed in Thread: LMX2592,
Hello, I observed a phenomenon that puzzled me.
When my LMX2592's reference signal is set to 125MHz, there is a strong 3.5GHz spurious output. Also, when I tested with a trial version of LMX2595, using 125MHz reference provided by SMW200A, I observed the same phenomenon. It's preliminarily determined that this spurious signal is generated by the PLL. Can this spurious signal be eliminated or reduced?
