Part Number: LMX2430
LMX-2430 ENGINEERING REPORT .xls
Error "close call sensitivity "was detected out of spec at 857.15MHz with NG ratio 15%(NG 10/70 pcs)
have already done the ABBA test, the NG unit is OK after change new IC
The TI forum aims to address technical issues encountered by customers during the use of TI products. We suggest that you contact the customer support department as follows, and customer service will provide assistance for you.
