Part Number: CDCE6214Q1TM
Hello, may I ask if this model has a default output configuration or if it needs to be configured entirely by oneself
The requirement is to power on the chip and output 100M differential clock from OUT4,
thank you
thank you
请参考这款芯片评估板的用户指南,里面有一些示例,www.ti.com.cn/.../snau244a.pdf
