Part Number: AFE4300
We are using the AFE4300 chip to perform bioimpedance measurements on the human body. However, during testing in a hospital environment, we consistently observe abnormally high impedance readings. After thorough investigation, we suspect the issue is caused by electromagnetic interference (EMI) from nearby large-scale medical equipment (e.g., MRI, CT, etc.).
This interference appears to affect the analog front end, causing a shift in measured impedance values, particularly an increase in resistance. The same setup in a non-hospital environment performs as expected, which further supports our EMI hypothesis.
We would like to ask:
Has TI observed similar EMI-related issues in AFE4300 applications?
Are there recommended PCB layout strategies, shielding, or filtering techniques to mitigate such interference?
Would adjusting the PGA gain or sampling frequency help reduce sensitivity to this kind of EMI?
Any guidance or suggestions from the TI team would be greatly appreciated.
