Other Parts Discussed in Thread: ADS1246
ADS1246连续转换模式怎么设置。谢谢!
START_1246一直保持高电平的话应该是连续转换吧。
然后怎样连续读取数据呢?ADC_CMD_RDATAC是什么时候发送的。
The ADS1246/7/8 can be configured to convert continuously by holding the START pin high, as shown in Figure 68.
With the START pin held high, the ADC converts the selected input channels continuously. This configuration continues until the START pin is taken low. The START pin can also be used to perform the synchronized measurement for the multi-channel applications by pulsing the START pin.
START 一直保持高电平的话应该是连续转换.
The conversion completion is indicated by the DOUT/DRDY pin going low.
这个时候就可以通过 SPI 接口读取转换结果了
