我在总线上挂了三个ADS1112,A1,A0分别接的GND,GND;
VCC,NC;VCC,VCC;结果就只有地址0X90有反应,理论上地址应该分别为0X90,0X9A,0X9D,快帮忙吧,头都大了,谢谢
* Filename: adc.c
* Revised: Date: 2012-08-05 19:50 (七)
* Revision: $
* Writer: $Wuming Shen.
* Description: ADS读写程序
* Notes:
* QQ:276193028
* E-mail:shenchangwei945@163.com
* All copyrights reserved to Wuming Shen.
* INCLUDES
#include "Global.h"
#include "STC12C5A60S2.H"
#include "ADC.h"
#include "Uart.h"
* CONSTANTS
INT8U code ADS_ADDR[3] = { 0X90, 0X9A, 0X9C };
* MACROS
* TYPEDEFS
* LOCAL VARIABLES
sbit ADS_SDA = P0^0; /*I2C的ADS_SDA线定义*/
sbit ADS_SCL = P0^1; /*I2C的ADS_SCL线定义*/
//sbit ADS_SDA = P1^1; /*I2C的SDA线定义*/
//sbit ADS_SCL = P1^0; /*I2C的SCL线定义*/
//sbit ADS_A0 = P0^0;
//sbit ADS_A1 = P0^1;
* GLOBAL VARIABLES
* LOCAL FUNCTIONS
BOOL ADS_Config ( INT8U addr, INT8U cfg );
* GLOBAL FUNCTIONS
* EXTERN VARIABLES
* EXTERN FUNCTIONS
* @fn &:main
* @brief &:First function called after startup.
* @return &:don't care
* 名 称:DDS_Init()
* 功 能:
* 入口参数:无
* 出口参数:无
* 作 者:无名沈
* 创建日期:2011-04-07
* 修 改:
* 修改日期:
void ADS_Init( void )
* 描述:配置转换精度为16位
* BIT 7 6 5 4 3 2 1 0
* NAME ST/DRDY INP1 INP0 SC DR1 DR0 PGA1 PGA0
* DEFAULT 1 0 0 0 1 1 0 0
* DR1 DR0 DATA RATE RESOLUTION
* 0 0 240SPS 12 Bits
* 0 1 60SPS 14 Bits
* 1 0 30SPS 15 Bits
* 1(1) 1(1) 15SPS(1) 16 Bits(1)
#define ADS_ACC_12_BIT 0X80
#define ADS_ACC_14_BIT 0X84
#define ADS_ACC_15_BIT 0X88
#define ADS_ACC_16_BIT 0X8C
//ADS_A0 = 0;
//ADS_A1 = 1;
ADS_Config(ADS_ADDR[0], 0x8c); //0x84 14BOOL;0x8c 16BOOL;
ADS_Config(ADS_ADDR[1], 0x8c); //0x84 14BOOL;0x8c 16B
ADS_Config(ADS_ADDR[2], 0x8c); //0x84 14BOOL;0x8c 16BOOL;OOL;
* 名 称:DDS_Init()
* 功 能:
* 入口参数:无
* 出口参数:无
//发起始位
#define start() { ADS_SDA=1; \
ADS_SCL=1; \
ADS_SDA=0; \
ADS_SCL=0; \
//发停止位
#define stop() { ADS_SDA=0; \
ADS_SCL=1; \
ADS_SDA=1; \
ADS_SCL=0; \
//发应答位
#define mack() { ADS_SDA=0; \
ADS_SCL=1; \
ADS_SDA=0; \
ADS_SCL=0; \
//发非应答位
#define mnack() { ADS_SDA=0; \
ADS_SCL=1; \
ADS_SDA=0; \
ADS_SCL=0; \
//应答位测试
BOOL sack(void)
BOOL ack = 0;
INT8U timeOut = 20;
ADS_SDA = 1;
ADS_SCL = 1;
do {
ack = ADS_SDA;
} while (ack && --timeOut);
ADS_SCL = 0;
return (ack );
* 名 称:ADSWriteByte()
* 功 能:发一字节数据
* 入口参数:无
* 出口参数:无
* 作 者:无名沈
* 创建日期:2011-04-07
* 修 改:
* 修改日期:
void ADS_WriteByte(INT8U dat)
INT8U i;
for (i=0;i<8;i++) {
ADS_SDA = dat & 0X80; // 高发送低位
dat = dat << 1;
ADS_SCL = 1;
ADS_SCL = 0;
* 名 称:ADSReadByte()
* 功 能:收一字节数据
* 入口参数:无
* 出口参数:无
* 作 者:无名沈
* 创建日期:2011-04-07
* 修 改:
* 修改日期:
INT8U ADS_ReadByte(void)
INT8U dat,i;
dat = 0;
// ADS_SCL = 0;
for (i=0;i<8;i++) {
ADS_SDA = 1;
ADS_SCL = 1;
dat |= (INT8U)ADS_SDA; // 先收低位
dat <<= 1;
ADS_SCL = 0;
return (dat);
* 名 称:ADCReadData()
* 功 能:读取AD转换值
* 入口参数:无
* 出口参数:无
* 作 者:无名沈
* 创建日期:2011-04-07
* 修 改:
* 修改日期:
INT16S ADS_ReadData( INT8U addr, INT8U ch, INT8S times )
//INT8U addr;
INT8U dataH; // AD高8位
INT8U dataL; // AD低8位
INT8U cfgReg;
float result = 0.0;
INT8S cnt = 0;
INT8U timeOut = 20;
bit cpu_sr;
* 描述:
//addr = addr;//ADS_ADDR[ch/2];
//ch = 0;//ch%2;
UART_Printf(0,"Waddr:0x%X ch:%d\r\n",(INT16U)addr,(INT16U)ch);
* 描述:
if ( !ADS_Config( addr, 0x0C | ( ch << 5 ) ) ) { //0B10001100
UART_Printf(0,"Config Err\r\n");
return FALSE;
addr += 1;
UART_Printf(0,"Raddr:0x%X ch:%d\r\n",(INT16U)addr,(INT16U)ch);
* 描述:
do {
timeOut = 10;
again:
cpu_sr = EA; // 保存当前中断使能状态
EA = 0; // 关闭中断
* 描述:开始读
start(); // 发起始位
ADS_WriteByte( addr ); // ED0的读地址
if ( sack() ) {
EA = cpu_sr; // 恢复中断状态
return FALSE;
* 描述:读取数据
dataH = ADS_ReadByte();
mack(); // 发应答位
dataL = ADS_ReadByte();
mack(); // 发应答位
cfgReg = ADS_ReadByte();
mnack(); // 发非应答位
stop(); // 发送停止位
UART_Printf(0,"H:0x%x L:0x%x R:0x%x\r\n",(INT16U)dataH,(INT16U)dataL,(INT16U)cfgReg);
* 描述:
if ( cfgReg & 0X80 ) { // 判断是否有新的AD采样值,最高位为1表示无新值
if ( --timeOut <= 0 )
return 0xffff;
OSTimeDly(OS_TICKS_PER_SEC/15); // 16位精度为15次每秒
goto again; // 重新读取
result += (float)( ( (INT16S)dataH << 8 ) + dataL );
} while ( ++cnt < times );
* 描述:
if ( times > 0 )
result /= times;
return ( INT16S )result;
* 名 称:ADS_Config()
* 功 能:设置ADS1100
* 入口参数:无
* 出口参数:无
* 作 者:无名沈
* 创建日期:2011-04-07
* 修 改:
* 修改日期:
BOOL ADS_Config( INT8U addr, INT8U cfg )
bit cpu_sr = EA;
EA = 0; // 关闭中断
//addr = ADS_ADDR[addr];
start(); /*发起始位*/
if ( sack() ) {
stop();
return FALSE;
ADS_WriteByte( cfg );
if ( sack() ) {
stop();
return FALSE;
stop();
return TRUE;
* end of file
