I want to use ADS6145 as a part of my data acquisition system,should a single ground is enough or should I use separate digtal ground and analog ground?
if I use separate digtal ground and analog ground,how can I link the two ground?
-ps I plan to use four layers pcb with two signal plane and a power plane and a ground plane
