【TI招聘】研发类相关职位--虚位以待
TI is hiring!
点击职位后相关链接,即可在线申请该职位。
1. Analog Design_Signal Chain  https://sjobs.brassring.com/TGWEbHost/jobdetails.aspx?partnerid=25329&siteid=5227&areq=6484BR
Job Description: Seeking an analog IC design engineer for precision products. The ideal candidate will have a Master’s degree, along with a theoretical background and practical experience in mixed-signal IC design. This engineer must be capable of hand (i.e. pen and paper) analysis and experience with the use of software tools such as Cadence Virtuoso, AMS, ***, etc. is required.
 Basic Qualifications
* MSEE with 5+ years in analog/mixed-signal IC design
* Analog circuit design experience with amplifiers, comparators, bandgap references, IO buffers, precision data converters.
* Experience using Cadence Virtuoso and ***
* Lab equipment proficiency is necessary.
* Fluent in verbal and written English.
* Experience in working with US or Europe design team is a plus
2. Analog Design_Power  https://sjobs.brassring.com/TGWEbHost/jobdetails.aspx?partnerid=25329&siteid=5227&areq=6486BR
Job Role Summary: Design the most advanced integrated analog and mixed signal power management IC for power management market.
Required basic Qualifications:
• MSEE with analog-mixed signal IC design in BiCMOS process for a minimum 3 years experience.
• High current and low current designs, opamps, gm/voltage amps, comparators, gate drivers, oscillators, high speed level shifters, current limit, LDO, NVM, power LDMOS design, and basic digital logic design.
• Understand the BICMOS process, device physics, and power electronics. Skilled with ***, Cadence Analog Artist/Virtuoso/Silicon Ensemble design.
3. Test Engineer  https://sjobs.brassring.com/TGWEbHost/jobdetails.aspx?partnerid=25329&siteid=5227&areq=6482BR
Job Description: Here, you will have lots of opportunities to influence the product development activities and enhance your career growth in the fast growing business in TI China. As part of the team, you have the opportunity to be creative, technical and innovative while creating one of the coolest applications.
This position provides the opportunity to work with customers to understand and address their issues through customer returns. It also offers opportunities to interact and learn from various experts throughout the IC development cycles—from design through packaging, test, planning and customer support.
4. Systems/Applications Engineer_Signal Chain
                              https://sjobs.brassring.com/TGWEbHost/jobdetails.aspx?partnerid=25329&siteid=5227&areq=6480BR
Job Description: Join the Integrated Signal Chain Product Line as an Analog Systems Engineer and fuel Texas Instruments’ growth by partnering with strategic customers to define products that will bring value in a Sensor Signal Chain.
The ideal candidate will have strong mixed signal experience with amplifiers, power, data converters, and microcontrollers/DSP/FPGAs. Excellent communication skills, board-level circuit design, and laboratory experience are also required. The candidate must have a MSEE preferred and 7+ years experience in the target market areas specified above.
5. Product Engineer https://sjobs.brassring.com/TGWEbHost/jobdetails.aspx?partnerid=25329&siteid=5227&areq=6591BR
Job Description: As a product engineer, you’ll support the development and implementation of strategies that achieve profitability targets on assigned TI product lines through new product development, cost reduction, capacity expansion and yield enhancement projects.
This engineer must be able to jump in to test and troubleshoot issues. Responsibilities include developing production, creating and managing product documentation, and product development support, and involves interfacing with Design, Test Engineering, Quality Engineering, and others.
6. Layout Engineer https://sjobs.brassring.com/TGWEbHost/jobdetails.aspx?partnerid=25329&siteid=5227&areq=6592BR
Job Description: Basic understanding of Silicon process technology. Basic understanding of both analog and digital circuit topology. Understand matching technique and parasitic components come from various layout structures. Have DRC/LVS experience, parasitic extraction and assembly rule checks.
Basic qualifications:
Experience of whole chip layout work desired, including floor plan, ESD structure, top level routing, digital core place and routing. BCD layout experience is very helpful.
7. Applications Engineer https://sjobs.brassring.com/TGWEbHost/jobdetails.aspx?partnerid=25329&siteid=5227&areq=6495BR
Job Description:
• Bench validation and characterization on power management IC products
• Define and develop product supporting hardware and software (EVMs, software, tools)
• Design-IN/WIN support of worldwide key accounts and field sales of WLED backlight driver products
• Application notes, technical articles, customer training on WLED backlight driver ICs
• Support design, systems and product engineers during new product development
