Part Number: ADS1110
Other Parts Discussed in Thread: ADS1115,
我在arm-linux下使用libi2c和gpio模拟i2c,尝试读取ADS111x的数据,但是存在台阶形状毛刺,具体如下图所示。使用的设备为Licheepi Nano,所用的芯片为F1C100S。
可以看到,输入位1.5v时,D14因该为1,但是次数没有被上拉,形成了一台台阶状的毛刺;同时低八位也存在两个台阶毛刺。但是Config位却能够被正确读取。代码如下:
#define NUMS 10
char readbuf[NUMS];
int main(int argc, char** argv)
int file = open("/dev/i2c-0", O_RDWR);
// addr = 1001 xxx
int addr = 0b1001000;
if (file < 0)
printf("openfile error!\n");
exit(1);
if (ioctl(file, I2C_SLAVE, addr) < 0)
printf("ioctl error!\n");
exit(1);
// Debug Gain 1
readbuf[0] = 0x0C;
if (write(file, readbuf, 1) != 1)
printf("write error!\n");
exit(1);
if (read(file, readbuf, 3) != 3)
printf("read error!\n");
exit(1);
printf("%x %x %x\n", readbuf[0] & 0xff, readbuf[1] & 0xff, readbuf[2] & 0xff);
close(file);
exit(EXIT_SUCCESS);
同时,我使用GPIO模拟I2C,仍然存在上述问题,波形如下图所示:
代码如下,gpio.h:
struct gpiod_chip* gpiochip0;
struct gpiod_line* line_SCL;
struct gpiod_line* line_SDA;
int PE11Num = (4 * 32) + 11;
int PE12Num = (4 * 32) + 12;
bool i2cInit()
gpiochip0 = gpiod_chip_open("/dev/gpiochip0");
line_SCL = gpiod_chip_get_line(gpiochip0, PE11Num);
line_SDA = gpiod_chip_get_line(gpiochip0, PE12Num);
int reqSCL = gpiod_line_request_output(line_SCL, "SCL", 1);
int reqSDA = gpiod_line_request_output(line_SDA, "SDA", 1);
return !(reqSCL | reqSDA);
bool i2cSDAConf(bool toOutput)
int reqSDA;
gpiod_line_release(line_SDA);
if (toOutput)
else
int reqSDA = gpiod_line_request_input(line_SDA, "SDA");
return !reqSDA;
void i2cSDALevel(bool toHigh)
gpiod_line_set_value(line_SDA, toHigh);
void i2cSCLLevel(bool toHigh)
gpiod_line_set_value(line_SCL, toHigh);
void i2cDelay()
for (int i = 0; i < 1000; ++i) { /* do nothing */ }
void i2cStart()
i2cSDALevel(1);
i2cSCLLevel(1);
i2cDelay();
i2cSDALevel(0);
i2cDelay();
i2cSCLLevel(0);
i2cDelay();
void i2cEnd()
i2cSDALevel(0);
i2cDelay();
i2cSCLLevel(1);
i2cDelay();
i2cSDALevel(1);
void i2cACK()
// make sure the SDA is output before send
i2cSDAConf(1);
i2cSDALevel(0);
i2cDelay();
i2cSCLLevel(1);
i2cDelay();
i2cSCLLevel(0);
i2cDelay();
void i2cNACK()
i2cSDAConf(1);
i2cSDALevel(1);
i2cDelay();
i2cSCLLevel(1);
i2cDelay();
i2cSCLLevel(0);
i2cDelay();
bool i2cSDARelease()
// i2cSDALevel(0);
return i2cSDAConf(0);
bool i2cWaitAck()
return !i2cGetSDA();
void i2cSend(u8 data)
i2cSDAConf(1);
for (int i = 0; i < 8; ++i)
if (data & 0x80)
i2cSDALevel(1);
else
i2cSDALevel(0);
i2cDelay();
i2cSCLLevel(1);
i2cDelay();
i2cSCLLevel(0);
i2cDelay();
data <<= 1;
// 释放SDA
i2cSDARelease();
bool i2cGetSDA()
i2cSCLLevel(1);
i2cDelay();
bool level = gpiod_line_get_value(line_SDA);
i2cSCLLevel(0);
i2cDelay();
return level;
u8 i2cReceive()
i2cSDARelease();
u8 data;
data <<= 1;
data |= i2cGetSDA();
return data;
u8 i2cReceiveDebug(u32* biasDebug)
i2cSDARelease();
u8 data;
data <<= 1;
*biasDebug <<= 2;
// 查看pull寄存器状态
static int dev_fd;
unsigned char *map_base;
dev_fd = open("/dev/mem", O_RDWR);
map_base = (unsigned char *)mmap(NULL, MAP_SIZE, PROT_READ | PROT_WRITE, MAP_SHARED, dev_fd, GPIO_PAGE_OFFSET);
*biasDebug |= (*(volatile u32*)(map_base + GPIO_BASE_OFFSET + rPE_PULL0)) >> 24 & 0b11;
munmap(map_base, MAP_SIZE);
return data;
void i2cRelease()
gpiod_chip_close(gpiochip0);
void i2cClear()
i2cSDARelease();
for (int i = 0; i < 32; ++i)
i2cSCLLevel(0);
i2cSCLLevel(1);
main
void ADS1110_ReadData()
if(!i2cInit())
printf("I2C init error\n");
i2cRelease();
exit(1);
i2cClear();
i2cSDAConf(1);
i2cStart();
u8 addr = 0b10010001;
i2cSend(addr);
if (!i2cWaitAck())
printf("none ACK received\n");
printf("%d\n", gpiod_line_direction(line_SDA));
i2cRelease();
exit(1);
u8 data[3];
data[0] = i2cReceive();
i2cACK();
i2cACK();
i2cNACK();
i2cEnd();
i2cClear();
i2cRelease();
printf("%x %x %x\n", data[0] & 0xFF, data[1] & 0xFF, data[2] & 0xFF);
同样的,使用ADS1115进行测试,也存在如上问题。
