Other Parts Discussed in Thread: ADS122C04
Hello everyone,
my solution circuit is the one I sent out. The external reference voltage uses a 5V voltage reference, and then calls the AD three-way test. Now the communication is normal, and the data written into AD is correct and can be collected. To the voltage, just collect the voltage and calculate it to be about 20mv related to the actual voltage。But using ADS122C04IPWR on the same board can get accurate data。
Have you encountered this situation? If so, how to solve it? Thanks!
