Other Parts Discussed in Thread: ADS8364
我用ADS8364和FPGA做一个电压的采样电路。硬件电路如PDF上的。程序如下:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity aa is
port (rst,clk,adeoc:in std_logic;
adb:in std_logic_vector(15 downto 0);
adclk,adrd,adwr:out std_logic;
hold:out std_logic_vector(2 downto 0);
ada:out std_logic_vector(2 downto 0);
led1:out std_logic_vector(4 downto 0);
led2:out std_logic_vector(15 downto 0);
led:out std_logic);
end aa;
architecture behav of aa is
constant s0 :std_logic_vector(12 downto 0):="0000001100000";--启动转换
constant s1 :std_logic_vector(12 downto 0):="1110001100001";--进入17个周期等待转换结束,不检测EOC
constant s2 :std_logic_vector(12 downto 0):="1110001100010";
constant s3 :std_logic_vector(12 downto 0):="1110001100011";
constant s4 :std_logic_vector(12 downto 0):="1110001100100";
constant s5 :std_logic_vector(12 downto 0):="1110001100101";
constant s6 :std_logic_vector(12 downto 0):="1110001100110";
constant s7 :std_logic_vector(12 downto 0):="1110001100111";
constant s8 :std_logic_vector(12 downto 0):="1110001101000";
constant s9 :std_logic_vector(12 downto 0):="1110001101001";
constant s10 :std_logic_vector(12 downto 0):="1110001101010";
constant s11 :std_logic_vector(12 downto 0):="1110001101011";
constant s12 :std_logic_vector(12 downto 0):="1110001101100";
constant s13 :std_logic_vector(12 downto 0):="1110001101101";
constant s14 :std_logic_vector(12 downto 0):="1110001101110";
constant s15 :std_logic_vector(12 downto 0):="1110001101111";
constant s16 :std_logic_vector(12 downto 0):="1110001110000";
constant s17 :std_logic_vector(12 downto 0):="1110001110001";
constant s18 :std_logic_vector(12 downto 0):="1110001110010";
constant s19 :std_logic_vector(12 downto 0):="1110000110011";--读ch1数据
constant s20 :std_logic_vector(12 downto 0):="1110011110100";
constant s21 :std_logic_vector(12 downto 0):="1110010110101";--读ch2数据
constant s22 :std_logic_vector(12 downto 0):="1110101110110";
constant s23 :std_logic_vector(12 downto 0):="1110100110111";--读ch3数据
constant s24 :std_logic_vector(12 downto 0):="1110111111000";
constant s25 :std_logic_vector(12 downto 0):="1110110111001";--读ch4数据
constant s26 :std_logic_vector(12 downto 0):="1111001111010";
constant s27 :std_logic_vector(12 downto 0):="1111000111011";--读ch5数据
constant s28 :std_logic_vector(12 downto 0):="1111011111100";
constant s29 :std_logic_vector(12 downto 0):="1111010111101";--读ch6数据
constant s30 :std_logic_vector(12 downto 0):="1110001111110";
signal clk_ad :std_logic;
signal Q: std_logic_vector(12 downto 0);
signal clkcnt : std_logic_vector(16 downto 0);
signal readst:std_logic_vector(4 downto 0);
signal ch1,ch2,ch3,ch4,ch5,ch6:std_logic_vector(15 downto 0);
begin
process(rst,clk) is
begin
if rst='0' then
clkcnt <= "00000000000000000";
elsif(clk'event and clk = '1') then
if(clkcnt = "11111111111111111") then
clkcnt<= "00000000000000000";
else
clkcnt <= clkcnt+1;
end if;
end if;
end process;
adclk <= clkcnt(15);
clk_ad<= clkcnt(15);
led<=clk_ad;
COM:process(clk_ad,rst)
begin
if rst='0' then
Q<=s0;
elsif clk_ad'event and clk_ad='1' then
case Q is
when s0=>Q<=s1;
when s1=>Q<=s2;
when s2=>Q<=s3;
when s3=>Q<=s4;
when s4=>Q<=s5;
when s5=>Q<=s6;
when s6=>Q<=s7;
when s7=>Q<=s8;
when s8=>Q<=s9;
when s9=>Q<=s10;
when s10=>Q<=s11;
when s11=>Q<=s12;
when s12=>Q<=s13;
when s13=>Q<=s14;
when s14=>Q<=s15;
when s15=>Q<=s16;
when s16=>Q<=s17;
when s17=>Q<=s18;
when s18=>Q<=s19;
when s19=>Q<=s20;
when s20=>Q<=s21;
when s21=>Q<=s22;
when s22=>Q<=s23;
when s23=>Q<=s24;
when s24=>Q<=s25;
when s25=>Q<=s26;
when s26=>Q<=s27;
when s27=>Q<=s28;
when s28=>Q<=s29;
when s29=>Q<=s30;
when s30=>Q<=s0;
when others=>Q<=s0;
end case;
hold<=Q(12 downto 10);
ada<=Q(9 downto 7);
adrd<=Q(6);
adwr<=Q(5);
readst<=Q(4 downto 0);
end if;
end process;
process(clk,readst)
begin
if(clk'event and clk='1')then
if readst="10011" then
ch1 <= adb(15 downto 0); led2<=ch1;
elsif readst="10101" then
ch2 <= adb(15 downto 0);-- led2<=ch2;
elsif readst="10111" then
ch3 <= adb(15 downto 0);-- led2<=ch3;
elsif readst="11001" then
ch4 <= adb(15 downto 0); --led2<=ch4;
elsif readst="11011" then
ch5 <= adb(15 downto 0); --led2<=ch5;
elsif readst="11101" then
ch6 <= adb(15 downto 0);-- led2<=ch6;
else
ch1<="0000000000000000";
ch2<="0000000000000000";
ch3<="0000000000000000";
ch4<="0000000000000000";
ch5<="0000000000000000";
ch6<="0000000000000000";
end if;
end if;
end process;
end behav;
但输出数据似乎误差很大。求指教!有懂得帮忙看看,是否有错吗?
我现在只使CH1的数据输出。
