采用IO模拟I2C读写时序,程序如下图所示
#include "stm32f10x_lib.h"
#include "ads1115.h"
//#include "ap_i2c.h"
static void Confige1115 (unsigned char port);
static void PointRegister (void);
static u16 ReadData (unsigned char chn, unsigned char cnt);
unsigned char WriteIntBuf[4], WritepointBuf[2], count = 6,ReadBuffer[64];;
void delay (unsigned int delay)
while(delay--);
* Function Name : Confige1115
* Description : 延迟时间
* Input : None
* Output : None
* Return : None
* Attention :获取ADS1115模拟转换结果
u16 data_get;
float dianya;
float Get_ATOD (unsigned char channel,unsigned char cnt)
static unsigned char chn;
chn = channel;
Confige1115(channel);
delay(1000);
PointRegister();
delay(1000);
data_get=ReadData(chn,cnt);
delay(1000);
if(data_get>=0x8000)
dianya=((float)(0xffff-data_get)/32768.0)*4.096;
else
dianya=((float)data_get/32768.0)*4.096;
return dianya;
* Input : None
* Output : None
* Return : None
* Attention :配置ADS1115
static unsigned char chnel, i;
switch (port)
case 0: //0通道
chnel=0xC2;
break;
case 1: //1通道
chnel=0xD2;
break;
case 2: //2通道
chnel=0xE2;
break;
case 3: //3通道
chnel=0xF2;
break;
default:
break;
WriteIntBuf[0] = CMD_Write;//0x90
WriteIntBuf[1] = CMD_CONF_REG;//0x01
WriteIntBuf[2] = chnel;// tongdao
WriteIntBuf[3] = CONF_L;//0xe3
if(!(TWI_START()))
for(i=0;i<4;i++)
TWI_SendByte(WriteIntBuf[i]);
delay(20);
TWI_STOP();
* Function Name : PointRegister
* Input : None
* Output : None
* Return : None
* Attention :指向ADS1115指针寄存器用于准备读取数据
unsigned char i;
WritepointBuf[0] = CMD_Write; //90
WritepointBuf[1] = CMD_POINT_REG; //00
if(!(TWI_START()))
for(i=0;i<2;i++)
TWI_SendByte(WritepointBuf[i]);
delay(20);
TWI_STOP();
* Function Name : I2C_delay
* Input : None
* Output : None
* Return : None
* Attention : CH1 PA4 CH2 PA7 CH3 PA6 CH4 PA5
static u16 ReadData (unsigned char chn,unsigned char cnt)
u16 data_rece;
switch(chn)
case 0: //0通道
if(!(TWI_START()))
if(count == 0xff)
count = 6;
TWI_SendByte(CMD_Read);
delay(20);
ReadBuffer[cnt * 8] = TWI_ReceiveByte();
TWI_SendACK();
ReadBuffer[(cnt * 8) + 1] = TWI_ReceiveByte();
TWI_SendACK();
TWI_STOP();
data_rece=ReadBuffer[cnt * 8]*256+ReadBuffer[(cnt * 8) + 1];
//ReadBuffer[56]|=(GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_4) << count);
break;
case 1: //1通道
if(!(TWI_START()))
{ TWI_SendByte(CMD_Read);
delay(20);
ReadBuffer[(cnt * 8) + 2] = TWI_ReceiveByte();
TWI_SendACK();
ReadBuffer[(cnt * 8) + 3] = TWI_ReceiveByte();
TWI_SendACK();
TWI_STOP();
data_rece=ReadBuffer[(cnt * 8) + 2]*256+ReadBuffer[(cnt * 8) + 3];
//ReadBuffer[57]|=(GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_7) << count);
break;
case 2: //2通道
if(!(TWI_START()))
delay(20);
ReadBuffer[(cnt * 8) + 4] = TWI_ReceiveByte();
TWI_SendACK();
// I2C_delay(20);
ReadBuffer[(cnt * 8) + 5] = TWI_ReceiveByte();
TWI_SendACK();
TWI_STOP();
data_rece=ReadBuffer[(cnt * 8) + 4]*256+ReadBuffer[(cnt * 8) + 5];
//ReadBuffer[59]|=(GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_5) << count);
break;
case 3: //3通道
if(!(TWI_START()))
delay(20);
// I2C_delay(20);
ReadBuffer[(cnt * 8) + 6] = TWI_ReceiveByte();
TWI_SendACK();
// I2C_delay(20);
ReadBuffer[(cnt * 8) + 7] = TWI_ReceiveByte();
TWI_SendACK();
TWI_STOP();
data_rece=ReadBuffer[(cnt * 8) + 6]*256+ReadBuffer[(cnt * 8) + 7];
//ReadBuffer[58]|=(GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_6) << count--);
break;
default:
break;
return data_rece;
