按照DAC8831开发板设计了PCB,生成正弦波,单极性输出,直接测得DAC8831的输出引脚,结果输出波形如图所示,这个是什么问题
一开始直接用SPI就是这个现象,后来猜想是时序问题,就用IO口模拟,代码如下
SET_LDAC();
delay(10);
// SPI start
SET_SYNC();
delay(10);
CLR_SYNC(); //bring CS low
delay(1);
//Write out the ControlWord
for(i=0; i<16; i++)
SET_SCLK();
delay(5);
if(0x8000 == (ValueToWrite & 0x8000))
SET_SDIN(); //Send one to SDI pin
else
CLR_SDIN(); //Send zero to SDI pin
delay(5);
CLR_SCLK();
delay(5);
ValueToWrite <<= 1; //Rotate data
delay(50);
// SPI ends
SET_SYNC();
delay(1);
CLR_LDAC();
delay(1);
SET_LDAC();
delay(1);
