有没有用过ADS7864的朋友 求教!!!
Other Parts Discussed in Thread: ADS7864, ADS8363
最近在调一块ads7864的板子,发现内置输出的基准电压时而不准,不知道是什么问题
 还有就是采样保持之后去读输出数据,总是有时能读到  ,有时读不到,或者读出的不对,怀疑是时序的问题,求教各位高手,能不能给个详细的例程演示!
  • 1、REF问题
    请再REFout管脚接两个电容,10uF和0.1uF。
    2、读输出数据
    跟你的应用的模式有关系,Cycle mode还是FIFO mode, 根据中断来读取还是查询读取。
    软件流程是怎么样的?
    没有ADS7864的,
    给一个类似的ADS8363的,是16位版本的,可以参照一下。
    这个是中断读取的函数:
    void IRQ_TIME0(void)
       int16 i = 0;
       uint32  bak1 = 0;               /*中断嵌套设置*/
       bak1 = VICIntEnable;         /*备份初始中断使能设置*/
       VICIntEnClr = (1<<4)|(1<<5)|(1<<9)|(1<<13); /*屏蔽当前优先级以及比当前优先级别低的中断*/
       VICVectAddr = 0x00;                /*重写向量中断地址重置优先级别*/
       T0IR = 1;                        /*清除定时器0中断标志*/
       T0TCR = 0x00;                /*重新设置采样频率*/
       T0TC = 0;
       T0PR = 0;
       T0MCR = 0x03;
       TimerAD = Pinlvf*64/100;
       if(TimerAD>3840 || TimerAD<2560) TimerAD = 3200;
       T0MR0 = Fpclk/TimerAD - 87;    /*重置采样频率*/
       T0TCR = 0x01;
       //AD CONVST引脚:P1.23
       IO1CLR = IO1CLR | (1<<23);      /*启动AD转换*/
       Delay(1);
       IO1SET = IO1SET | (1<<23);
       Delay(5);
       Convnum--;
       if(Convnum > 200) Convnum  = AD_NUM - 1;
       EnableIRQ(); /*开中断,允许高优先级别中断打断当前中断*/
       /*读取U6的采样值*/
       low_ad  = AD_RESULT1;
       high_ad = AD_RESULT1;
       ADresult[CH_UC][Convnum]  = low_ad + (high_ad<<8);
       ADresult[CH_UB][Convnum]  = low_ad + (high_ad<<8);
       ADresult[CH_UA][Convnum]  = low_ad + (high_ad<<8);
       ADresult[CH_ICm][Convnum]  = low_ad + (high_ad<<8);
       ADresult[CH_IBm][Convnum]  = low_ad + (high_ad<<8);
       ADresult[CH_IAm][Convnum]  = low_ad + (high_ad<<8);
       /*读取U5的采样值*/
       low_ad  = AD_RESULT2;
       high_ad = AD_RESULT2;
       ADresult[CH_UN][Convnum]  = low_ad + (high_ad<<8);
       ADresult[CH_US][Convnum]  = low_ad + (high_ad<<8);
       ADresult[CH_IN][Convnum]  = low_ad + (high_ad<<8);
       ADresult[CH_ICp][Convnum]  = low_ad + (high_ad<<8);
       ADresult[CH_IBp][Convnum]  = low_ad + (high_ad<<8);
       ADresult[CH_IAp][Convnum]  = low_ad + (high_ad<<8);
       Delay(1);
       Yxchaxun();                    /*遥信采集*/
       if (t_tap >= 3)                /*16点录波*/
          Report_gzlb();       /*故障录波*/
          t_tap = 0;
       else
          t_tap++;
       soft_freq(ADresult[CH_US],Convnum);/*软件测频*/
       /*计算零漂值*/
       s_pr_num--;
       if (s_pr_num < 0)
          s_pr_num = SPRNUM - 1;
          for (i = CH_NUM- 1; i >= 0 ;i-- )
              s_pr[1][i] = s_pr[0][i]/SPRNUM;
              s_pr[0][i] = 0;
       else
              s_pr[0][i] += ADresult[i][Convnum];
       VICIntEnable = bak1;  /*恢复初始中断使能设置*/
