Part Number: ADS1256
在前面测试2.5v和3.3v是正常的,当测量接地时,会显示负值,而且每次接地时,负值都不一样。求大佬帮忙解惑。
您好
当测量接地时
Can you clarify what it means "to measure grounding"? How are the signals applied to the ADC?
Can you also provide the register settings and a larger picture of the schematic (or just a PDF of the schematic)? I cannot make the image you provided bigger so the schematic is hard to read
