Other Parts Discussed in Thread: DLPC350
Use an external signal to trigger 4500 projection. There is no problem when the external signal is detected. At present, the DLP does not process the external input trigger signal. How can I solve this?
Please post your question on E2E design support forum: https://e2e.ti.com/support/dlp-products-group/dlp/f/dlp-products-forum
不好意思,我不该使用英文,我想咨询如何使用外部信号触发DLP4500投射?
你好。用英文也是可以支持的,只是建议把英文的帖子发到TI的全球工程师论坛,这样也许会更快捷地帮你解答。
如果要了解DLP4500的外部信号触发,你可以参考DLPC350的Programmer guide以及DLP4500 EVM user guide。链接如下:
