接口返回报文如下:
500 Native SSL error SSL handshake with transact.ti.com:443 failed: SSSLERR_SSL_CONNECT (-57) SAPCRYPTO:SSL_connect() failed SapSSLSessionStart()==SSSLERR_SSL_CONNECT SSL:SSL_connect() failed (536875120/0x20001070) => "received a fatal TLS1.0 protocol version alert message from the peer" >> ---- SecuSSL ErrStack: ---- 0x20001070 | SAPCRYPTOLIB | SSL_connect SSL API error received a fatal TLS1.0 protocol version alert message from the peer 0xa0600278 | SSL | ssl3_connect received a fatal TLS1.0 protocol version alert message from the peer 0xa0600278 | SSL | ssl3_read_bytes received a fatal TLS1.0 protocol version alert message from the peer << --------------------------- SSL:SSL_get_state()==0x2120 "SSLv3 read server hello A" SSL NI-hdl 129: local=192.168.120.160:9394 peer=223.119.222.67:443 cli SSL session PSE "/usr/sap/ECQ/DVEBMGS02/sec/SAPSSLC.pse" Target Hostname="transact.ti.com" Error: -14 Version: 7420 Component: ICM Date/Time: Mon Jan 9 17:28:38 2023 Module: icxxconn.c Line: 2198 Server: sapdqs_ECQ_02 Error Tag: {00044e54}
