Part Number: TI-API
v2 ASN API 错误代码的含义是什么?
E2E原帖:e2e.ti.com/.../faq-ti-api-v2-backlog-advanced-ship-notice-asn-api-error-codes-and-meanings
Part Number: TI-API
| 具体场景 | 错误详情 | 补救步骤 |
| 缺少标识符 | {
"errors": [
"errorCode": "ERR-BKG-ASNR-API-0010",
"type": "ERROR",
"reason": "Missing Identifier",
"message": "The identifier customerPurchaseOrderNumber, wayBillNumber, or orderNumber cannot be null or empty. Enter a valid Identifier and resubmit request."
标识符不能为空。 输入一个有效的customerPurchaseOrderNumber 或 wayBillNumber 或 OrderNumber,然后重新提交请求。 如果需要进一步的帮助,请联系 TI API 支持(api-portal.ti.com/support)。 |
| 只需一个标识符 | {
"errors": [
"errorCode": "ERR-BKG-ASNR-API-0011",
"type": "ERROR",
"reason": "Only One Identifier Required",
"message": " Only one of the identifiers customerPurchaseOrderNumber, wayBillNumber, or orderNumber is required. Enter only one of the valid Identifiers and resubmit request."
只需要一个标识符。 输入以下有效标识符之一:customerPurchaseOrderNumber 或 wayBillNumber 或 OrderNumber,然后重新提交请求。 如果需要进一步的帮助,请联系 TI API 支持(api-portal.ti.com/support). |
| 无效的 requestCommercialInvoicePDF或 requestWaybillPDF | {
"errors": [
"errorCode": "ERR-BKG-ASNR-API-0040",
"type": "ERROR",
"reason": "Invalid requestCommercialInvoicePDF or requestWaybillPDF",
"message": " requestCommercialInvoicePDF or requestWaybillPDF – X must have value of either true or false. Field will default to false."
如果需要 PDF,则 requestCommercialInvoicePDF 或 RequestWaybillPDF 值必须为 true 或 false。 输入 X 以接收 PDF;否则该字段将默认为 false。 如果需要进一步的帮助,请联系 TI API 支持(api-portal.ti.com/support). |
| TI API 由于系统维护暂不可用 | {
"errors": [
"errorCode": "ERR-BKG-ASNR-API-0500",
"type": "ERROR",
"reason": "TI API unavailable for scheduled system maintenance",
"message": " This TI API is currently unavailable due to system maintenance. Please resubmit the request after maintenance is completed or contact TI API Support (https://api-portal.ti.com/support) for more information."
TI 服务器维护正在进行中,目前不可用。 请尝试稍后重新提交请求。 如果问题仍然存在,请联系 TI 客户支持(提交请求)。 |
| 找不到 customerPurchaseOrderNumber 的货物数据 | {
"errors": [
"errorCode": "ERR-BKG-ASNR-API-020",
"type": "ERROR",
"reason": "No shipment data found with customerPurchaseOrderNumber",
"message": "Verify and correct the customerPurchaseOrderNumber or use the orderNumber or wayBillNumber and resubmit request."
未找到货件数据。 请输入有效的customerPurchaseOrderNumber 或使用 OrderNumber 或 wayBillNumber。 只有已完成的订单才有可用的发货数据。 如果需要进一步的帮助,请联系 TI API 支持 (api-portal.ti.com/support). |
| 找不到 orderNumber的货物数据 | {
"errors": [
"errorCode": "ERR-BKG-ASNR-API-0021",
"type": "ERROR",
"reason": "No shipment data found with orderNumber",
"message": "Verify and correct the orderNumber or use the customerPurchaseOrderNumber or wayBillNumber and resubmit request."
未找到货件数据。 请输入有效的 OrderNumber 或使用 customerPurchaseOrderNumber 或 wayBillNumber。 只有已完成的订单才有可用的发货数据。 如果需要进一步的帮助,请联系 TI API 支持 (api-portal.ti.com/support). |
| 找不到wayBillNumber的货物数据 | {
"errors": [
"errorCode": "ERR-BKG-ASNR-API-0022",
"type": "ERROR",
"reason": "No shipment data found with wayBillNumber",
"message": "Verify and correct the wayBillNumber or use the customerPurchaseOrderNumber or orderNumber and resubmit request."
未找到货件数据。 请输入有效的 wayBillNumber 或使用 customerPurchaseOrderNumber 或 OrderNumber。 只有已完成的订单才有可用的发货数据。 如果需要进一步的帮助,请联系 TI API 支持 (api-portal.ti.com/support). |
| 发货仍在进行中 | {
"errors": [
"errorCode": "ERR-BKG-ASNR-API-0023",
"type": "ERROR",
"reason": "Shipment in process, ASN information unavailable at this time",
"message": "Shipment information is unavailable at this time. Please try again at a later time."
未找到货件数据,因为货件仍在处理中。 请稍候再试。 如果需要进一步的帮助,请联系 TI API 支持 (api-portal.ti.com/support). |
| 发货完成,目前 ASN 不可用 | {
"errors": [
"errorCode": "ERR-BKG-ASNR-API-0024",
"type": "ERROR",
"reason": "Shipment complete, ASN information unavailable",
ASN 信息尚未就绪。 请稍候再试。 如果需要进一步的帮助,请联系 TI API 支持 (api-portal.ti.com/support). |
| 无效的soldToAccountNumber | {
"errors": [
"errorCode": "ERR-BKG-ASNR-API-0030",
"type": "ERROR",
"reason": "Invalid soldToAccountNumber",
"message": " soldToAccountNumber is incorrect. Verify and correct the soldToAccountNumber and resubmit request."
soldToAccountNumber 无效。 请输入有效的 soldToAccountNumber。 如果需要进一步的帮助,请联系 TI API 支持 (api-portal.ti.com/support). |
| 缺失soldToAccountNumber | {
"errors": [
"errorCode": "ERR-BKG-ASNR-API-0031",
"type": "ERROR",
"reason": "Missing soldToAccountNumber",
"message": "The soldToAccountNumber cannot be null or empty. Enter a valid soldToAccountNumber and resubmit request."
soldToAccountNumber 缺失,不能为空。 请输入有效的 soldToAccountNumber 并重新提交请求。 如果需要进一步的帮助,请联系 TI API 支持 (api-portal.ti.com/support). |
| 缺失业务合作伙伴的 soldToAccountNumber | {
"errors": [
"errorCode": "ERR-BKG-ASNR-API-0032",
"type": "ERROR",
"reason": "Missing business partner's soldToAccountNumber",
"message": "The Business Partner's soldToAccountNumber cannot be null or empty. Enter a valid soldToAccountNumber and resubmit request."
业务合作伙伴的 soldToAccountNumber 缺失,不能为空。 请输入有效的业务合作伙伴的 soldToAccountNumber 并重新提交请求。 如果需要进一步的帮助,请联系 TI API 支持 (api-portal.ti.com/support). |
| 缺少业务合作伙伴 | {
"errors": [
"type": "ERROR",
"reason": "Missing business partner",
"message": "Business Partner cannot be null or empty. Enter a valid Business partner and resubmit request."
业务合作伙伴缺失,不能为空。 请输入有效的业务合作伙伴并重新提交请求。 如果需要进一步的帮助,请联系 TI API 支持 (api-portal.ti.com/support). |
