BQ40390RSMR new PO#C012024040900007 can't feed in TI system
Hi Team,
CPN and MPN linkage setup well. Customer still can't feed in new PO#C012024040900007 into TI system. Can you pls help to check and advise solution. Thank you.
Soldto-179696
CPN:DE01000429
MPN: BQ40390RSMR
Input error: "Invalid CPN/Revision number combinationcustomer LineItemNumber 1: Invalid CPN/Revision number combination customerLine ItemNumber 1. Correct and resubmit."
