Cosmx(soldto-179696) can't send PO#C012024110100050 into production environment
Hi Team,
COSMX (SOLDTO-179696) can't feed in PO#C012024110100050 (MPN: BQ40370RSMR) into TI production system. CPN-MPN linkage is correctly setup in system.
Pls help to investigate the root cause and help to process it. Thanks.
API order failure information as below:
订单号:C012024110100050,推送TI失败。
TI返回信息:
订单行号 1:状态:Rejected
错误信息:Invalid CPN/Revision number combinationcustomerLineItemNumber 1: Invalid CPN/Revision number combination customerLineItemNumber 1. Correct and resubmit. For help, contact TI API Support api-portal.ti.com/support
