Part Number: DP83822HF
I am currently conducting the development of network communication based on the STM32H7 and DP83822HF chips.
Previously, I had already implemented communication based on the driver files of LAN8742 (lan8742.c/lan8742.h), but now the PHY chip has been replaced with DP83822HF. I even failed to successfully initialize this chip because after initialization, I couldn't read any correct register data.
Where should I obtain the driver file for this chip? On the official website, only DP83848 is mentioned as being related. Can I directly use it?
