Part Number: TDA4VEN-Q1
Other Parts Discussed in Thread: ADS7142
Issue description: SBL hang at reading EEPROM GT24C64EM sometimes at boot.
- TDA4VEN WKUP_I2C0 connect to HCPS(TPS62875), DOMS(MPQ4323), PMIC(TPS65223), ADC(ADS7142) and EEPROM(GT24C64EM).
- GT24C64EM don’t have RESET pin, Power by VDD_IO_3V3.
- Suspect as there is conflict of I2C transition on WKUP_I2C.
- Disconnect I2C connection between TDA4VEN and HCPS(TPS62875) ONLY, system can’t boot up.
- Disconnect I2C connection between TDA4VEN and DOMS(MPQ4323) ONLY, system can’t boot up.
- Disconnect I2C connection between TDA4VEN and PMIC(TPS65223) ONLY, system can’t boot up.
- Disconnect I2C connection between TDA4VEN and ADC(ADS7142) ONLY, system boot up OK.
- Disconnect I2C connection between TDA4VEN and HCPS(TPS62875), DOMS(MPQ4323), PMIC(TPS65223), system boot up OK.
